I tried to process soft cheese and the shaft melted and cracked in half length wise and I cannot remove it and the small black part on the bottom is no longer stantionary. How do I get it off to replace it? and should the little black crown be replaced as well? and should it be stationary and how do I do that?
Find your model number on the list and look for parts Kitchenaid Food Processor Replacement Parts Accessories Sears PartsDirect
Posted on Dec 20, 2017
SOURCE: part removal and replacement
The black plastic clutch has a left-handed brass threaded insert. Temporarily remove the motor to hold the shaft and remove the brass insert by rotating clockwise.
Posted on Jul 12, 2008
SOURCE: cuisinart DLC-8 Plus Motor Shaft Cover broken.
I wrote in December with my problem and went on the web sites mentioned. A cover only cost $69.00. A new bowl and cover was $99.00. I only needed the cover. The new cover did not work and I ended up going to Macy's when they had the DLC-8S on sale for $99.00 and bought a new one. I took my blades with me and they fit the new machine. DON'T WASTE YOUR TIME AND MONEY (unless you find an old machine at a yard sale) THE PARTS COSTS AS MUCH AS A NEW MACHINE ON SALE. ees
Posted on Feb 12, 2009
SOURCE: The drive shaft extending vertically from the
I just called Cuisinart customer service. Depending on your model, it sould be under warranty. They sent me a new shaft sheath immediately with no expense.
Posted on Jan 19, 2010
SOURCE: Cracked plastic sheath on the motor drive shaft
The shaft is spinning inside the sleeve. So is should not be hard to
remove. With a DLC-7SP, I grabbed the spindle with some pliers, channel
locks might do well and put a handle of a screwdriver between the pliers
and the top deck and pried. Second attempt and it pulled up easily.
Place the screwdriver beside one of the top deck screw covers to
transfer force directly to the motor. Otherwise top deck would probably
break.
Clean the old shaft to remove any contamination.
New one can be driven on with a hammer and block of wood.
Posted on Jan 29, 2011
Check the thrift shops,flea markets and yard sales. I found a work bowl for $3.50 at Habitat for Humanity store...looks like new.
Boy, now that I know....if I see a cheapy at yard sale etc I will pick up a spare! I love my DLC 8 Plus.
Posted on Feb 12, 2011
Aug 29, 2014 | Magimix 5100 Cuisine Systeme Food...
Jul 08, 2010 | Cuisinart DLC-7SFP Pro Food Processor
Dec 09, 2009 | Cuisinart Little Pro Plus LPP 3 Cups Food...
Oct 14, 2009 | Food Processors
Aug 03, 2009 | Cuisinart DLC-5 Food Processor
Mar 09, 2009 | Cuisinart Food Processors
Dec 11, 2008 | Cuisinart DFP-11 Deluxe Food Processor
Nov 16, 2008 | Cuisinart DLC-8S Pro Custom Food Processor
Mar 25, 2008 | Cuisinart DLC-10S Pro Classic Food...
Aug 25, 2015 | KitchenAid Food Processors
332 people viewed this question
