Question about Samsung SCX Office Equipment & Supplies
Margin cut off - SCX Samsung Office Equipment & Supplies
My brother printer cuts off the right margin
how much if just border cutting from word then set the borders around the text
Jan 14, 2013 | Brother MFC-7360n Laser Printer
Left margin cuts off
Try changing the left margin size in the page setup. Decrease the left margin size.
You could also try printing in Landscape instead of Portrait just to see if it captures the left margin.
May 31, 2012 | Samsung CLX-3175FW Multifunction Laser...
I am a teacher. We have Dell computers with windows 7 on them. Recently our school district downloaded Microsoft Office 10. Since the new microsoft office, my xerox phaser 8500 is printing strange. ...
Hi fsaltzman,
You need to check the margin settings in the print preview option, make sure you decrease the margins that are set by default and try printing a test page , this should work fine.
On the File menu, you need to click Page Setup, and then click the Margins tab.
Here you can adjust the margins as per your convenience.
To View page margins :-
  1. You need to go on the Tools menu, select Options, and then select the View tab.
  2. Under Print and Web Layout options, select the Text boundaries check box.
The page margins appear in your document as dotted lines.
You can use these dotted lines to correct your margins so that your student's assignments are not cut off and there is no large margin as you have mentioned in your question.
You can view page margins in either Print Layout or Web Layout view only, and they do not appear on the printed page.
Hope this helps
May 11, 2011 | Office Equipment & Supplies
Only copies half a page. Right margin cuts off
check paper trays to make shure paper is tight in guides. registration settings off
Jan 09, 2010 | Sharp Office Equipment & Supplies
Printing Legal size brochure (landscape) that gets cut off
readjust the margins in the printer page set up just before printing
Sep 08, 2017 | HP Inkjet 1200D Printer
Top of words are cut off
Often times, some documents might have their margins or header/footers set to high for the printer to handle. Try opening the document and checking the margins, one inch all around is usually the default margin settings.
Jun 26, 2009 | Konica Minolta PagePro 1400 Laser Printer
My paper is cutting off the word on the right hand side of th
Go to the Application your working in,
Click tools or edit, view, page layout, margin's,
you can manipulate the margin's,
1.5 all the way round, usually for standard printing
or, check printers properties setup too...
Hope this helps.
Regards.
Apr 16, 2009 | HP PSC 2510 All-In-One InkJet Printer
Printed Tape Cuts Off Letters
I was having the ame issue. Found the solution on the user manual (posted online). Press Function, scroll to "Margin", press "Function", use arrows to select "#" or "##", then press Function again. Now it should print with a margin, thus not cutting off your letters. Mine was set to "-", which is basically no margin.
Dec 29, 2008 | Brother P-Touch 1180 Label Printer
Printer cuts off top 1 inch of PDF document
Go to the printer properties and try setting it up with border less printing.
Cheers
May 23, 2008 | Lexmark X4270 All-In-One InkJet Printer
35 people viewed this question
Top Samsung Office Equipment & Supplies Experts
Muntejaya Ginting
Muntejaya Ginting
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
