Dell Vostro 1710 Laptop Logo
A
Anonymous Posted on Jan 08, 2014
Screen is black three lights 9 a lit - Dell Vostro 1710 Laptop
1helpful
On the top border of the screen there is a 9 inch part of the edge that is dark and it fades down into the screen.
There may be screen damage and that entire part of your screen may just contain dead pixels.
I posted a problem on how to remove panel but I solved it. Now as I mentioned the tv comes on goes green then black no picture just sound. I followed instructions on adjusting G screw but it doesnt work...
Its possible one of two thing have occurred, you have maladjusted the G screen control on the high voltage screens and focus assembly. Turn down (counterclockwise) all three of the screen drivers. Adjust each until a light appears in the each lens, red green and blue. Go slow or lines will appear if set too high. If all three lamps stay lit after this adjustment the look at your screen with color level down to zero using your remote and the picture menu. Adjust the three color drives to get a good black and white balance appearing on the screen. Now adjust the color level from the picture menu back up to normal range.
If you still get green diagonal lines after this adjustment then I would suspect that the green lens has a heater to cathode short in the tube.
1helpful
2answers
My hp laserjet m4345 mfp has all three lights flashing and wont work
Try performing a cold reset. press and hold "6" while booting and counting RAM. Release when all 3 led's are lit. Use "3" and "9" and navigate to "Cold Reset". Press 6 to enter.
2answers
TV or control doesn't work need help know
ok my tv is doing the same thing and i need help if you found a solution please email me at [email protected]
7helpful
Tv2 light does not come on
hi hammonhph! I will be more than glad to assist you in this concern. Lets program the remote for tv2, lets make sure that the battery's are brand new, please go to the front panel of the receiver, make sure that u have the remote2 with, turn on the the tv1, you got picture, on the front panel of the receiver, you got 1 green and the blue light is off.. push the power button on the front panel of the receiver once to turn off the green light, once its off the tv will show a black, blue or snowy screen, push the up button on the fron panel of the receiver until it shows the system information screen, look for the primary and secondary remote address, primary and secondary remote address should show a number on the white box ex.. 1 and 1 on the green box, secondary is ex 2 on the white box and 2 on the blue box, how to reporgram the remote to the receiver.. press and hold the sat button and wait until all lights lit up, once it all lit up, release it and press any number from (1 to 15) but for this ex is press 9, then press the pound button (#) that is under number 9, once you press the pound button the sat button will flash 3 times and then press the record button once, record button is under the cancel button or view tv button, once you are done check the secondary remote address, it should be 9 on the white box and 2 on the blue box, save the settings by using the remote 1, selct done on the screen and it will go back again to black, blue or snowy screen, press the sat button once on the remote 2 and the big red power button, the blue light should turn on, just in case the blue light dont turn on, press the power button on the front panel of the receiver for 10sec to reset the receiver, it will acquire the sat signal and go to a progress, and it will download the programming guide, check if blue light is not on, press the big red power button on the remote2 to turn on the blue light and it should work. if just incase the blue light dont turn on, the remote is bad and you need to call 1-800-333-3474 for the replacement of the remote..please feel free to get in touch if you have any query..
My Envision 9410 Monitor flashes on and off. You see the picture fine, but then it goes to a black screen and then back to seeing desktop. The power light goes on and off while this is happening. Is...
Its either going to be the inverter or the lcd going back and it can't keep the screen lit.
Also I've seen it where the capacitors on the power board go puffy and they need to be replaced.
It will be one of those three things.
Screen is black but sound works
possible lamp is burned out,look in your manual for info.
Toshiba setellite black out
Sounds like the back light on the screen isn't working properly which will need to be replaced if this is the case. Check for a very dark image on the screen when it is booting up in a well lit room, if you can see the computer start up then it is the back light.
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
