My old remote for logitech 360 remote..Cannot get the safe off or get it to work at all
SOURCE: harmony 520 remote is in safe mode.....how do I fix this
remove the batteries from the remote
hold down to the number 2 key
as you are holding down to the number 2 key (do not let go of this number key) put the batteries back in
now remove the batteries again and put it back in again without pressing any buttons
if this does nto fix the issue
do a firmware upgrade
SOURCE: Logitech Harmony universal remote stuck in safe mode
Just a message to all that have problems with there Logitec remotes. My remote went into something called a "safe mode" when my partner changed the batteries while holding the power button.... I pressed every single button to try and get out of it but nothing seemed to work, (I was getting pretty frusterated, there is nothing in the manual to tell you how to fix this problem), however, I have now learnt that as you replace the batteries you need to have the number 2 button held in as you replace the last battery. This works 100% so if you have any trouble with the "safe mode" then this is what fixes it.
Carly.
Testimonial: "Worked like a charm"
SOURCE: My Logitech Remote 550 is Locked in the Safe Mode.
Doing a firmware upgrade is the BEST way to recover from Safe Mode. A remote may go into safe mode itself for a variety of reasons.
However, if the remote fails to communicate with the PC when it is stuck in Safe Mode, please try the following.
1. Remove the batteries from the remote & check for any stuck buttons especially the Power button that may be causing the remote to stay in this state.
2. If it still will not apply firmware to get out of safe mode, then still without batteries hold down the #2 button while plugging into USB, and it should exit Safe Mode, and say something similar to 'Firmware Upgrade Success'. Even though it says this, still perform the Firmware upgrade since it was stuck in Safe Mode to begin with.
Hope this helps
Testimonial: "Great advice. Thanks for your time."
SOURCE: Logitech Harmony 670 remote stuck on Safe Mode.
1. Remove the batteries. While holding the 2 button down, connect the USB cable. The remote will boot into normal mode. Did this fix the problem? If no, please continue to troubleshoot.
ANSWER:
2. Update the firmware. Update the configuration. Did this fix the problem? If no, please continue to troubleshoot.
ANSWER:
3. There could be a stuck button on the remote causing the symptom. Remove the batteries from the remote. Push in, and massage each button ensuring it is not stuck down. Replace the batteries and Update the firmware. Update the configuration. Did this fix the problem? If no, please continue to troubleshoot.
ANSWER:
4. Remove the batteries from the remote. Manually place the remote into `Safe Mode` by holding off and plug in the USB. Upgrade the firmware in the remote. Update the configuration. Did this fix the problem? If no, please e-mail us back for further information about your issue.
ANSWER:
FIRMWARE:
1. Log into the Logitech Harmony Remote Software on your computer
2. Click on the Downloads button at the top-right corner of your screen
3. Click on the Firmware button. Follow the onscreen instructions to upgrade the firmware on your Harmony remote
4. Once the firmware upgrade is complete, click on the Update Remote button
5. Test your remote.
SOURCE: Logitech Harmony 550 stuck on Safe Mode
Hi everyone. So I can see that there are a lot of people who are having trouble with their Harmony remotes being stuck in safe mode. Here's how to fix it and get your remote working again:
1. Connect your remote to the computer.
2. Launch the Harmony Remote Software, and log in.
3. Click "Downloads" at the top and click "Firmware"
4. The remote will go through the firmware update.
5. Select "Yes", and click NEXT to update the remote.
Voila! Hope this can help
