Tv popping noise
It does not turn on
Patrick d
TV popping noise. It is an automatic reminder to get the oil changed in your car. But only if it's a full moon. Hey, I'm trying to be helpful here!! Sharp flat screen static buildup.
Posted on Sep 30, 2014
  • Patrick d
    Patrick d Sep 30, 2014
    Sound card, may have a capicitor going out. Loose connection. Static build up. Static electricity can be dangerous. Follow trouble shooting recommendations in the back of your manual to be Jon the safe side..
What might be the problem with tv making popping noise when turned on
you must have a wire ( sound plug ) not connect properly ,
sometime those plug loose with time ,
when powered the make connection and those sound happen !
Apr 05, 2015 | RCA L32HD31 32 in. LCD HDTV
Samsung UA46B8000XY TV partly flooded making popping noise. Water reached 50 mm up screen. Dried out for a week. At turn on the display works but then turns off and get popping noise..
You have severe damage in TV. the power supply part and circuits board were get problem. Please check carefully the defective parts inside TV. And get repaired at repair shop or dealer is better options
Regards
Jan 24, 2011 | Samsung Televison & Video
RCA HD50LPW164 turned on TV made a pop
the loud pop you heard was probably a capacitor blowing its top. The grinding noise is likely high voltage arching that was occuring due to rising voltage since capacitor isn't there to smooth it out.
Nov 02, 2009 | RCA HD50LPW164 50" Rear Projection HDTV
3232 polaroid tv,makes popping noise when i turn it on.
this sounds like the problem most LCD tv's get with swelled up capacitors in the power supply board. look for circular cylinder shaped parts rapped in plastic with writting on the sides, and metal tops, if the top is rounded over, not flat, it is bad. replace them.
Jun 25, 2009 | Polaroid FLM-3232 Television
Tv went out after loud pop and has clicking noise does not turn on
If you have a Sony DLP, then the loud pop you heard is your lamp.  The lamps last approx. 4K-6K viewing hours.  Read your manual for replacement part number to reorder and very simple to replace yourself.
Apr 22, 2009 | Televison & Video
Sony Bravia XBR-2 32-inch LCD with popping noise problem
Unfortunately, we have the same problem. We hear popping and our sound goes lower. It is not the cable box for us, it's definitely the TV; however, it happens, on our set, after its been on for a few minutes and then goes away after half an hour or so -- however, this evening its been happening for the past hour and the TV has been on for the evening.
Jun 10, 2008 | Westinghouse LTV-27W2 27 in. HD-Ready LCD...
Has anyone heard of something like this where the cable box/service is causing popping sounds? yes & it is common problem. And is this something I should be concerned about causing damage to the TV's speakers? not at all. The Sony tech-support representative (over the phone) diagnosed it further to a problem not with the TV but with the cable box/service because there were no popping sounds when I played a DVD on my Playstation 2 that is attached to the TV. they are right that your problem is not due to tv. it is due to cable box/service? yes but not defective it reqires to change the way you have connected tv to cable.please call tech to get it connected in such a way so that you do not get popping sound when you you put off cable box.
Sep 23, 2007 | Sony FD Trinitron KD-36XS955 36" TV
Popping noise
If the popping sound is NOT coming through the speakers, you probably have high voltage arcing. Probably close to the high voltage (flyback) transformer. If this is the case then other parts could be damaged if allowed to continue. If the popping is coming through the speakers then you could have a problem any where in the signal circuits. Like a loose connection. You'd need to have it checked out to find the problem.
Feb 27, 2007 | Sanyo AVM-3680G 36" TV
Televison & Video Logo
155 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
