Question about Oster 12-Bottle Wine Cellar - Black
E1 error code - Oster 12-Bottle Wine Cellar - Black
Teach me how to fix aircon says e1?
Hello, Mari-vick -
Without knowing the model number of your Aircon (an air conditioner, I believe), I can only provide you with generic instructions.
I hope you have the owner's manual and have checked there regarding the E1 error code.
If you do not have the manual, then . . .
Reasons for E1 error code, air conditioner:
1. Clean or replace the air filter. Note: Unplug the unit first. After cleaning or air filter replacement, plug the unit back in to the electrical outlet.
2. If the E1 error code still displays, it could mean one of the following problems:
- loose internal connections
- indoor and outdoor parts communications problem
- faulty control panel
Note: You may need an Aircon authorized repair technician for any such repairs.
Read more about the E1 error code on air conditioners and what may be malfunctioning here:
https://www.hunker.com/13407286/how-to-fix-an-air-conditioner-when-it-gives-you-an-e1-code
Best wishes.
May 08, 2018 | Heating & Cooling
Error E1 for washing machine
Lots of info on E1 for different makes.
  • How to repair a Samsung washing machine with error code E1 ... https://www.quora.com/How-do-I-repair-a-Samsung-washing-machine... How do I repair a Samsung washing machine with error ... If your Samsung Washing Machine is showing error code E1 then ... How do I clear bosch washing machine error ...
  • E1 error in washing machine? ' Yahoo Answers https://in.answers.yahoo.com/question/index?qid=20131129013237AA7oiKP
    • RESOLVED
    • 7 POSTS
    • 6 TOTAL ANSWERS
    2013-11-29 · E1 error in washing machine? ... Haier washing machine error code E1? LG Wave Series Washer LE error message? Washing machine error code? ...
  • My washing machine is displaying an error code. What does ... www.samsung.com/my/support/skp/faq/1033803 My washing machine is displaying an error ... E1. Water supply error. ... · Check that the level of the drain hose is not lower than the base of the washing machine.
  • Related searches for Error E1 for washing machine
  • Samsung Washing Machine 4E and E1 Fault - Help & Advice https://www.northlondonappliancerepairs.co.uk/error-codes/samsung...
    • 4.3/5
    • 46 RATINGS
    Samsung Washing Machine 4E and E1 Fault. Samsung washing machine Not filling in allocated time error code 4E and E1 Fault.
  • Help & Troubleshootings - Haier ZA Products Website www.haier.com/za/help_and_troubleshootings/faq/washing_machine Help & Troubleshootings. ... Too much water in the washing machine ... Error Code-control panel display "E1" Question : Error Code-control panel display "Lock"
  • Samsung washing machine error code 4E and E1 Fault Not ... www.youtube.com/watch?v=cFlnxeB0P0g
    • BY HOW-2-REPAIR.COM
    • 9 MIN
    • 19K VIEWS
    2015-11-24 · Video embedded · ... machine-error-code-4e-and-e1-fault-not-filling-in-allocated-time/ Samsung washing ... Samsung washing machine error code 4E and E1 ...
  • Samsung washing machine error code 4E, E1, Fault Not filling www.how-to-repair.com/help/samsung-washing-machine-error-code-4e... Samsung washing machine Not filling in allocated time error code 4E and E1 Fault This is essentially a fill timeout error which will normally mean that either the ...
  • Hoover error code E1 - White Goods Help www.whitegoodshelp.co.uk > ... > Washing Machine Error Codes Hoover error code E1. ... You need to watch the washing machine to see when it aborts to get an idea which of the three areas to look at.
  • Jul 01, 2016 | Washing Machines
    What is the error mean f1 E1 on my may tag front loader washing machine
    Barbara, F1 E1 error is your washer doesn't think the drain pump is working properly.bad CCU or pump.
    "I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
    have E1 and F1 error code fleshing and wate Sears PartsDirect
    http://forum.appliancepartspros.com/washer-repair/443358-f1-e1-error-fault-code.html
    Appliance Repair Forums
    Error code F1E1 null ShopYourWay
    Central Control Unit CCU Maytag MHW6000XW Washer
    Mar 07, 2016 | Washing Machines
    In the window then note comes up E1 ERROR . What is this. It does not sew.
    Consult the owner's manual. There is usually a list of error codes in the Troubleshooting section that discusses error codes and how to resolve them.
    Error Codes differ from brand to brand, so it is best to search for your machine's make, model plus "E1," ie:
    Frequently Asked Questions
    Why is my Kenmore sewing machine locked up with an E1 error code displayed...
    Simple Fix for Janome E1 Error
    Feb 14, 2016 | Sewing Machines
    Error code E1 and E4
    PDF]SERVICE Manual - Quietside
    https://www.quietside.com/archives/.../Service%20ACC1800C.pdf
    When error occurs in air conditioner, error code is displayed on indoor unit .... Display priority order at overlapping error : E1?E4?E5?P0?P0?P5?P6?t1? ...
    Midea air conditioner error codes
    airmaster.net/midea-air-conditioner-error-codes/
    Midea air conditioner error codes. Indoor unit error code explanation: R series: ... E1, Indoor / outdoor units communication protection. E2, Zero-crossing signal error ... E4, Outdoor unit temp. sensor or connector of temp. sensor is defective.
    [PDF]Download the Fault Error Code Booklet - Samsung
    Dec 05, 2015 | Heating & Cooling
    E1 error code on omega dishwasher
    E1 error on LG Dishwasher - YouTube
    ? 2:40
    www.youtube.com/watch?v=2qcwAyHI9ik
    Aug 24, 2012 - Uploaded by 62spindrift My fix for E1 error on LF Dishwasher. ... Maytag Maxima steam Washer has F8 & E1 error code - Pressure sensor & no water detected ...
    Aug 28, 2015 | Dishwashers
    E1 error code LFWC38F6LS
    Good Morning Chris,
    I see that you are receiving an E1 error code on your wine cooler, model# LFWC38F6LS, even though your wine cooler is still working. This could possibly be a false error code, caused by a miscommunication between the different control boards inside your appliance. I suggest resetting it by either unplugging it or cutting the power at the circuit breaker for 2-3 minutes. If when you bring power back to your wine cooler, you are still receiving the E1 error code, I suggest contacting either the manufacturer or your local authorized technician. Hope this is helpful.
    -Best Regards-
    WP
    Mar 18, 2014 | Frigidaire 38-Bottle Two-Temperature Zone...
    I constantly got E1 Error code on my Kenmore Elite H3 GAS dryer
    E1 error code indicates an open thermistor or open thermistor circuit. A thermistor is a component that relays the temperature in the dryer to the control board. If the thermistor has failed, Error code E1 will be displayed.
    You need to call a repair person to fix it.
    Dec 18, 2008 | Kenmore Elite HE4 Electric Dryer
    Kebc207 oven error code E1 F2
    This is information from the Tech Sheet.
    Fault Code F2 - Error Code E1: Code Explanation: Keypad keytail not connected. Recommended Repair Procedure: 1. Check keypad connector for firm connection. 2. Press CANCEL. If error code returns after 60 seconds, replace keypad. 3. Replace control.
    Jul 15, 2008 | KitchenAid KEBC207 Electric Double Oven
    Oster 12-Bottle Wine Cellar - Black Logo
    50 people viewed this question
    Top Oster Furniture Experts
    Tom Chichester
    Marvin
    Marvin
    Are you an Oster Furniture Expert? Answer questions, earn points and help others
