I'm replacing the water pump on a 2000 GMC Jimmy, but unable to remove the fan. I took off the 4 bolts but still am unable to remove it properly.
Here is a link that I hope will make your job easier.
http://www.handymanlyness.com/archives/auto/repair/cooling_system/
water_pump/GMC/V6/Jimmy_wpr.html
Gooc luck and hope this helps. It's what i used to change mine and was very helpful.
While still on motor use a hammer and screw driver...put slot screw driver on an edge of the nut holding fan on and a quick hit with hammer..that should free the nut to hand screw off
If its clutch fan,you need too hold the shaft and unscrew it!!!!!!
