NexxTech 4-Port Ethernet Broadband Router (N4PROUTER) Logo
B
Breaker Posted on Jan 09, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
N4prouter port how do i port forward?? picked this up at a swapfest cheap so i don't have a manual so what do i do??
kishore_0077
Level 2:
New Friend:
  • Expert 86 Answers
  • Posted on Jan 09, 2014
kishore_0077
Expert
Level 2:
New Friend:
Answers
86
Questions
0
Helped
14260
Points
150
Der is lot of software available for u to automatically port forward.... Just google port forward software...u will get to know...
N4prouter port forwarding
Contact Nexxtech on the web. Look for Support/Downloads/Manuals.
Netflix tech support said to ask you how to get my router onto ports 80 and 443. How would I, or we?
Please provide more information as to you issue such as :
a. model number
b. manufactured by/model
c. You have checked the user manual 1st.
Please give detailed information as to your issue to better assist you in your resolution of the problem you are having.The more information given will help determine the resolution and guide you to the proper fix for your issue.
Thank you.
1helpful
The disk will not work need install guide software download for Mod# N4PROUTER please
Are you trying to set up the router. You can do it manually without the CD. Make sure that your computer is able to go online through the modem. If your computer is not able to go online through the modem then you will need to call ISP first. If your computer is able to go online through the modem then you need to connect the computer to the router and the modem to the router. open the set up page of the router and change the settings of the router according to the ISP.
Problems getting a connection with vista operating system
This could possibly be an issue with the drivers provided by vista for your NIC. Try looking for updates for it or just tell me the model name of it.
My N4PROUTER isnt working :(
isolate your problem. maybe it has something to do with your computer. try connection your pc directly to your modem. if it gets online there. the problem is with your router. try unplugging and replugging your router then restart your pc.
N4prouter
This is a quick fix to your problem.
Go into the xbox live network configuration and manually set the IP address there.
The IP address consists of 4 octets (4 sets of numbers) separated by periods.
You will only want to change the last number.
For instance, if the current IP address is 192.168.1.3 you would only change the 3.
I would suggest using a number like 237 to avoid conflicting with the other computers and devices on the network.
Let me know how it goes.
My n4prouter set up
Connect a computer to the router via Ethernet cable, then you should be able to log into the router to set it up by opening a web browser and putting "http://192.168.1.1/" or "http://192.168.0.1/" (without the quotes) into the address line. The default username and password is usually "admin" and "admin" or username "admin" with no password. From there you should be able to configure the router and retrieve or change the WEP key.
Let us know how you make out.
Top NexxTech Computers & Internet Experts
john h
 Mikey
Mikey
ADMIN Andrew
ADMIN Andrew
Are you a NexxTech Computer and Internet Expert? Answer questions, earn points and help others
