Question about Xterra Fitness Xterra FS220e Elliptical Trainer
Xterra FS220e shows ERR and won't start
When I plugged it in, I got a code that said ERR and nothing more. I can't get the machine to start properly
Posted by Ellen Gerads on
Im getting error PF when trying to start my whirlpool carbio. Also getting error code f25 what does this mean?
There is or should be a booklet on the inside of the machine between the tub and on the front panel. Tells you what the err codes mean. First thing to check on these machines is the drive belt pulley located on the bottom of the machine. I went through a lot of headache and confusion trying to run diagnostic modes and watching how to videos to get my machine to start going through the cycles until the end. The lid lock keeps coming on and off so you think it's that and try fixing it to no avail. And on and on trying to find the err code in diagnostic. I finally gave up and when I was loading it on to the truck to take it to the scrap yard I notice the drive belt has come off and cut completely through the guard. Causes problems the err codes don't catch. The belt pulley comes loose causing this. Start there. Trust me on this one.
Jan 01, 2017 | Whirlpool Washing Machines
Lg washer de code
Try unplugging. Hold in start/pause button for 5 seconds, plug back in and see if this resets the unit.
if that doesn't work try pushing in on door while trying to start load, if hinge is issue or gasket is issue, that can cause DE err
Good luck.
Nov 05, 2016 | LG Washing Machines
Err Machine will not start
Is it latch-locked properly?
Jul 12, 2015 | Kenmore Washing Machines
My Electrolux time manager washing machine wont start jus flashes red with Err
Hey Beverley, thanks for your post!
I see that your Electrolux washer is displaying the error code "ERR". Typically a number follows the "ERR" but if no number followed the "ERR" error code then your washer has detected an error. I would perform a reset on your washer which can be done by unplugging the power cord or flipping the household circuit breaker for roughly ten minutes.
If that does not help correct the issue it could be a problem with your control panel or wiring harness. I would recommend seeking out assistance from a professional in order to properly diagnosis and repair your washer. I hope this is helpful to some degree. -Matt
Oct 04, 2014 | Washing Machines
Why do i get 'err on display and buttons do nothing
err is error......should be a number or code after err.......
cheers
Jun 19, 2014 | Zanussi Washing Machines
Erorr code -Err 1 is showing on our machine. Any ideas? Thanks.
Is this a Haier Washing Machine?
'coz I found an answer on their site..
"Q. The display shows Err 1. A. The door is open or not properly locked shut. Open and close the door, or firmly push the door shut until you hear a 'click'. If the problem continues, call the customer help desk or an approved service engineer."
Src: http://www.haier-uk.co.uk/support/faq
Hope this helps.. :)
Jun 09, 2011 | Washing Machines
How do I reset my Frigidaire Affinity Front Load Washing Machine? When I press a button the ERR code comes on and then it turns off.
My Fridgidaire Affinity front load washer has a ERR pause and I can't reset it. How do I clear this
Jan 17, 2010 | Washing Machines
Machine stuck on pause/err
un plug the washer for 5 minutes and re try
May 28, 2008 | Frigidaire ATF6000ES Front Load Washer
ATF6700FS - Affinity? 3.5 Cu. Ft. I.E.C. Capacity Washer Won't Start
ERR=An error has been detected
PAU=Cycle has been intrupted
58=High current on motor phase
To clear latest stored error code:
• Turn the Program Knob to the start position, Spin Only.
• Press Start/Pause to start the cycle and save it.
• Press Cancel to stop the cycle and turn off the LEDs.
• Press Cancel again to turn on the LEDs.
• Within 5 seconds, press and hold the Option and Start/Pause buttons until LEDs start sequentially chasing, then release buttons.
• Turn the program knob clockwise 7 clicks from the Start Position. The control will signal the last error code.
• Press and hold the Options and Start/Pause buttons for 3 seconds. The code will be cleared.
• Exit Diagnostic Mode to return the washer to normal operation.
a) Unplug the power cord, wait 5-8 seconds, then reconnect the power cord OR
b) Turn the program knob clockwise 2 or 3 clicks after the Start Position. Press Options and Start/Pause buttons
together for a few seconds until wash cycle LEDs appear.
Feb 25, 2008 | Washing Machines
Zanussi Washing machine
when any of the buttons are pressed ERR is displayed.
Jan 24, 2008 | Washing Machines
Xterra Fitness Xterra FS220e Elliptical Trainer Logo
Top Xterra Fitness Exercise & Fitness Experts
Tom Chichester
ray gallant
Marvin
Marvin
Are you a Xterra Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
