Question about Android Coby Kyros Mid7014-4g 7" Tablet
Take the password off cause I forgot it
I would like to remove the password off my tablet I forgot it
Posted by clyde chesser on
AC Rutland
    New Friend:
But how do I get into gmail to change password? Main screen before sign in screen shows bars. when I walked over to unsecured public wifi area, a star replaced the circle over the bars. but can't get to screen to connect to network unless I know my password and can sign in. Catch 22? It's been awhile since I used my tablet . Acer W3-810
Posted on May 19, 2015
brissa martinez
    New Friend:
If you remember your gmail you can unlock it like that. all you have to do is try your password for about 5 times until it says you have to wait 30 seconds to try your password again then look down where it says forgot password? press on that and it will take you to a screen that tells you to put in you gmail and if you put it in correctly and pressed sign in it will unlock your phone and you also get to choose what kind of password you want
Posted on Jan 12, 2014
  • AC Rutland May 19, 2015
    But Ican't reset password until I am connected to WiFi. I am in area with open wifi and the bars changed to star icon above them-- but how to connect so that I can access Gmail to change password?
I need to know how to by pass the password
A factory reset will completely wipe your tablet's memory, and return it the way it was when it came out of the factory. If your device has a removable memory card, it would be a good idea to turn it off and remove the card before resetting, as there is a chance the files stored on here will also be deleted.
press the helpful button and follow me on fixya for more tips and info
below are links to sights that may help
Recover Android Device in case of Forgot password pattern unlock an...
Help Forgot Android tablets password
How to unlock an Android phone tablet
Feb 03, 2016 | Tablets & eReaders
How can I reset my tablet?
    1. Here's how to execute a factory reset:
      1. Turn your tablet off and remove the SD card, if there is one.
      2. Press and hold the combinations below until you feel the device vibrate: Power button + Volume up and down (if there is a physical Home button) Power button + Volume up + Home button (If there is a physical Home button)
      Forgot your tablet's password? - TechAdvisory.org
      www.techadvisory.org/2013/03/forgot-your-tablets-password/
    Feedback
  1. Forgotten Pattern, PIN or Password on an Android device
    acer.custhelp.com/.../forgotten-pattern,-pin-or-password-on-an-android-...
    What can I do if I set a Pattern, PIN, or Password on my Lock screen but forgot it? ...If you do not have Android Device Manager installed, the tablet must be reset ...
Nov 29, 2015 | Tablets & eReaders
How do I unlock a tablet whose password I forgot
check whether your tablet has a hard reset available from any external buttons, ... a hard reset should set the machine to factory default and clear any passwords but you will almost certainly lose any data on the memory.
If you supply details of make and model and repost the query we might be able to track down a mothod of achieving access
Nov 11, 2015 | Tablets & eReaders
Change pin number
hard reset by recovey options
Nov 14, 2014 | Tablets & eReaders
Forgot my password for my mid tablet pc how do i reset it
Here's a video null suggested as a solution to your problem from YouTube:
How To: Remove Forgotten PASSCODE Unlock For Android Devices | SmartPhones & Tablets! Password
Apr 22, 2013 | Coby Kyros Internet Touchscreen Tablet...
How do i remove the password on my 7 inch tablet android
After trying password for 5 times, it shows a "forgot password" option. Click on it. Provided the gmail id and password you first used to logn into your tab. It will remove the password from the device thus unlocking it.
Apr 13, 2013 | Tablets & eReaders
I have a craig touch screen tablet and i forgot my dot password how do i reset it?
Unlock windows password,the easiest way I ever use is to adopt Windows Password Reset ,just a few steps:
Step 1: Download and install Windows Password Reset
Step 2: Burn Windows Password Reset Std ISO file to CD/DVD
Step 3: Put in your newly created CD and remove your Windows Password.
For more details,go to: http://www.windowspasswordreset.net
May 27, 2012 | Tablets & eReaders
Android Coby Kyros Mid7014-4g 7" Tablet Logo
218 people viewed this question
Top Android Tablets & eReaders Experts
Mr.Mike
Lawrence Oravetz
Phil Whisenant
Phil Whisenant
Are you an Android Tablet and eReader Expert? Answer questions, earn points and help others
