TX-P50XT50B plazma wont power on after being unpluged for hours please help me
TX-P50XT50B plazma wont power on after I have unplugged it last time it took 12 hours to come on can some one help me please
  • Televison & ... Master
  • 727 Answers
This kind of problems usually are caused by bad capacitors in the power supply board. I do not know if you can handle it your self or not. If not, please consult someone qualified to do it.
Posted on Jan 09, 2014
4 Suggested Answers
Anonymous
SOURCE:
pwrblnc
Ricky Kendall
  • 4 Answers
SOURCE: TV will not Power Up / Blinking Green Light on Power Button
May be the same problem Magnavox is having with their 27MF231d. I found the fix on this site and it took care of the same problem with my set. Not the easiest thing to do, but it worked. If you do not know how to solder, get some help with this one. If you take it to a Magnavox Authorized repair location, they will just replace the bad capacitor with another bad capacitor of the same type and voltage. The problem is they have a 25w capacitor where a 35w capacitor should be. Mine was bulging, with black tar looking stuff coming out of it. It was obviously bad. Follw the instructions below.
1. Remove all screws around perimeter, one screw at the lower right at (Side A/V), and 2 1”round plastic knob s.
2. Remove back cover
3. At lower left side remove 2 screws for On/Off switch cut tie wrap that holds wire down for free movement.
4. Disconnect wire connector to side A/V at lower right side
5. Disconnect wire connector to right side circuit Board
6. Disconnect wire connector to left side circuit board
7. Remove the 2 mounting brackets upper left and upper right 2 screws each.
8. Remove 3 screws each side of the metal box in the middle
9. Fold back metal tape off bottom and top of metal box
10. 1 wire connector at top of box I left connected
11. Flip metal box over towards top of Tv. Be careful of wire at top thats still connected.
12. On left side in box is power supply board
13. Towards bottom of board you should see the numbers C2081 and C2074
14. Remove the six screws holding down power supply board
15. Flip board down towards bottom of Tv.
16. Unsolder capacitors replace with new 1200uf 35v and 2200uf 35v 105°C radial capacitors
17. Capacitors should be around 1/2” to 5/8” dia. X 1.25 long appox. 2 Wires come out of one end should be .030 dia.
18. Reassemble in reverse order and enjoy
Posted on Feb 28, 2009
Dave Rogers
  • 4 Answers
SOURCE: My TX-47 was/is in power saver mode. A few days
sound like you have the white out feature on the screen saver menu
Posted on Jan 27, 2010
milkburp
Adam Halfhill
  • 416 Answers
SOURCE: power wont turn on the red light in front of tv is blinking
You need some capacitors changed on your power supply. Easy job if you can use a soldering iron. I have a tutorial in my Tips & tricks. Remove the rear cover and locate the bad capacitors (little plastic wrapped canisters with swollen tops) near the top right of the tan PCB board on the left-mid side of the TV. Note the values written on then (1000uf or 2200uf) then head to radio shack and purchase the replacement parts. Ask for 16v or 25v parts (16v fit better). Replace the parts, put the rear cover back on and you are all set. I hope this was helpful.
Posted on Mar 21, 2010
I have a white westinghouse 40 inch tv model vr4090 and the tv wont come on it shows the power indicator turn from red to blue but no picture or sound
Westinghouse tx-42f430s wont turn on fix repair - YouTube
? 5:29
https://www.youtube.com/watch?v=DdfLu5RdVEQ
May 12, 2014 - Uploaded by After Hours Tv & Pc repair
Westinghouse model # 32H1G1 won't turn on , but If I unplug the TV and wait for a ... -tx-42f430s-42-inch-lcd-tv-appears-bricked-595806.html ... I have a Westinghouse 40" TV that is working, but sometimes it won't turn on.
Westinghouse LED LCD TV Repair - YouTube
? 12:32
https://www.youtube.com/watch?v=DGg5iuFEfdM
Feb 8, 2014 - Uploaded by INSIDEHARDWARE CHRIS
Westinghouse Model: LD-4680 Similar (LD4655VX LD4255VX ...Samsung LCD TV Repair - TV Won't Turn On - How to Replace Power Supply ...
40 inch Westinghouse lcd tv black screen help - YouTube
? 1:39
https://www.youtube.com/watch?v=tKLRihGgZAs
Nov 21, 2011 - Uploaded by Jason Flynn
Dec 19, 2015 | Westinghouse Televison & Video
Sony 42 inch plazma display on screen ...fan problem powering down
if the fans are stopping you will need to replace them
Apr 29, 2014 | Televison & Video
Panasonic tx-p50xt50b
Apparently there is an internal power supply problem that is causing your TV to shut down unpredictably
Mar 08, 2013 | Televison & Video
Cannot reset time or date on ICF-CL75iP
Solution NO, Same problem YES! Our power was out for about 8 hours and now we cannot set the time or date! Surely someone has a solution! Please Help!
Jan 29, 2013 | Sony Dream Machine FMAM radio with...
My clock radio wont keep the time once I set it the clock advances 2 to 3 hours ahead
I took the back up battery out and unplugged the unit for about 20 minutes before powering the clock back up. Once I powered the clock up I re-inserted the backup battery.
Jan 17, 2010 | Emerson Smartset Clock Radio
Works fine before unplugging, stops working when plugged in again
Westinghouse WST3504 User Instructions Before Calling For Service
YOU CAN OFTEN CORRECT OPERATING PROBLEMS YOURSELF
AND TRY THE SOLUTIONS LISTED FOR EACH PROBLEM
Note: If the Microwave Oven still does not work properly, please contact Service and Repair
located on Warranty page. 19
BEFORE CALLING FOR SERVICE Possible Causes
• Is the power cord plugged in?
• Is the door closed?
• Is the cooking time set?
Feb 01, 2018 | Westinghouse WST3504 Microwave Oven
Intermatic hb65r residual outdoor timer
Here is the instruction manual for your model:
HB65R Timer
Hope this helps!
Also consult this website for sunrise, sunset information for your area:
Sunrise sunset calendar
Dec 05, 2008 | Hardware & Accessories
Door wont open
After unplugging the microwave, I took the side/top panel off by removing the screws on the back*. Inside I found the piece that had broken off the part that pushes the door release. I then glued this piece back on using "Extreme Power" medium advanced performance instant adhesive. I bought this glue in a hobby shop in Richardson, Texas. I waited 12 hours for the glue to set. The door has been opening for the last two days.
*With the cover off, you can open the door by pushing the door release.
Nov 02, 2008 | Panasonic NN-C994S Convection/Microwave...
TV won't come on
I have a 32 inch tv was working great then went into standby mode and wont turn back on. I have unplugged and am waiting please help!!!!
May 18, 2008 | Sony FD Trinitron WEGA KV-36HS510 36" TV
Televison & Video Logo
102 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
