Question about Apple iPad 16 GB 3G Tablet PC
Forgot reset password
ITunes has been disabled, we forgot the password to reset anything... or unlock the restrictions...
Posted by Andrea Debevec on
arcada
    New Friend:
  • 94 Answers
You can reset your iTunes password from the iTunes web site, and the associated em address. and restore the iOS device on your computer with the iTunes app
Posted on Jan 20, 2014
Kattambally
    New Friend:
    Problem Solver:
  • 15 Answers
If you've forgotten the passcode to unlock the iPad then you will need to connect the iPad to the computer that you normally sync to and you should then be able to reset the iPad and restore/re-sync your content to it (http://support.apple.com/kb/HT1212) - you may need to put the iPad into recovery mode to be able to reset it : http://support.apple.com/kb/ht1808
Posted on Jul 22, 2014
3 Related Answers
princeers
SOURCE: haven't used my ipad in a while, and forgot my password to unlock. help
click on Safari, click on open book icon, top of page, find iPad help on drop down menu...(last one)
Posted on May 28, 2012
atptsoi
Anthony Tsoi
  • 137 Answers
SOURCE: forgot restriction passcode on apple iPad 2
There is no way to unlock it as a passcode also prevents other people from unlocking it to access your data. What you could do is put it into recovery mode and then do a restore which will wipe all data, assuming you have a backup, you can just restore the data.
Posted on Nov 03, 2012
Anonymous
SOURCE: Ipad disabled b/c son forgot his password...help us get in?
If your son cannot remember the passcode, you will need to restore your iPad using the computer you last synced your iPad with. Using the last computer you synced with allows you to reset your passcode and re-sync all your data, apps, etc.
To begin the process, connect the iPad to your computer using the USB cable or lightning cable. Open iTunes and select the restore option.
If you restore on another computer, you can still unlock the device and remove the passcode, but your data and apps will be wiped.
Hope that helps!
Posted on Apr 03, 2013
I cannot remember my password to get into my tablet
hi John.
i think you will have to do a hard reset to sort this out.
Just tap the Power button to select Reboot System Now.
  1. Make sure tablet is powered off.
  2. Hold down Volume + button and Power button at same time.
  3. When screen comes on let go of Power button.
  4. When the large Android shows on screen let go of Volume + button.
  5. Use Volume - button to scroll to Wipe Data/ Factory Reset.
More items...
What do I do if I forgot my password to unlock to my tablet? - Trio ...
https://support.triotablets.com/.../201746559-What-do-I-do-if-I-forgot-my-password-to-...
How do I unlock my tablet if I forgot the password?Manual Factory ResetTurn off your Android device. ...Press and hold the "power", "volume down", and "camera" buttons simultaneously. ...Release the buttons once your Android device is powered on. ...Scroll using your "Volume up and down" button until you find the "wipe data/factory reset" option.More items...Recover Android Device in case of Forgot password/pattern unlock an ...visihow.com/Recover...in...Forgot_password/pattern_unlock_an_Android_deviceSearch for: How do I unlock my tablet if I forgot the password?
or before you do anything go to this link and have some more off a read up.
cannot remember my password to get into my tablet Google Search
Dec 03, 2017 | Tablets & eReaders
I forgot my unlock code for my old ipad1 haven't used in in months
If your iPad is disabled, the only way to unlock it is to completely erase and reset it. If you have a backup, you'll be able to restore it, otherwise you'll lose all of your data. There is no way to unlock a disabled iPad unless you use the correct passcode or you erase it. And the following guidance will show you how to unlock a disabled iPhone with iTunes.
Step 1. Connect your iPad to the computer with via a USB cable that your iPad has trusted.
Step 2. Launch iTunes. If you've synced your iPad with iTunes, then no "enter password" is required.
Step 3. iTunes will automatically sync your iPad and create a backup file. If it doesn't, you should sync your iTunes and create a backup file manually by clicking "Back up Now" in the Summary window.
Step 4. In the Summary window, you can see the option "Restore iPhone". Click it to reset your iPad. Once the reset process is complete, you'll be taken through the iPod's initial setup process.
Step 5. Select "Restore from iTunes backup" during the setup process. This will load the backup that you created so that all of your data is restored.
http://www.leawo.org/tutorial/how-to-unlock-a-disabled-iphone-with-without-itunes.html
Feb 18, 2017 | Apple iPad Tablets & eReaders
My iPad Air has been disabled because I forgot my password. How can I enable it again?
If you plug your device into your computer and boot up iTunes on it, look around and find a reset button click on this and your tablet to reset it. Resetting is the only way to re enable your iPad.
Aug 04, 2015 | Apple - iPad Air 2 Wi-Fi 64GB
Don't remember password for ipad
You don't need to know your password for the iPad. As long as you know the password for your iTunes account, you used to setup the account on the iPad for. Connect the iPad with the computer and open iTunes and give in the password for the iTunes account. Apple will unlock the iPad and you can setup a new pass code for the iPad.
When you forgot your iTunes password, you have to contact Apple and prove you are the legal owner of the account.
Use this link to find more support for that:
Apple ID Support
Feb 16, 2015 | Tablets & eReaders
I forgot my password and now my mini ipad is disable
it's now in DFU mode and must be plugged up to the computer and connected to iTunes.
Jul 18, 2014 | iHome Ipad/ipod/iphone Rechargeable Mini...
I forgot my icloud password
Go to settings and then iTunes and App Store. Once you're there, tap on your Apple ID and tap on "Forgot password." That should reset your password.
Mar 12, 2014 | Apple iPad 2
Can not sign in
open itunes in your pc or laptop, click store>> then click view accounts>> then enter your account>> then in password filed click forgot.. this open itunes site in your browser>>> on the lower left, click reset password
hopes this will help
Mar 04, 2014 | Apple iPad 2
How to reset your restriction code
The only way to reset your restriction code is if you know the existing code. Since it appears you do not know the existing code you will need to restore your iPad to remove the code.
Simply, connect your iPad to your computer and open iTunes. Perform a backup so you can later re-add all your apps. Then perform a restore. This should remove the restriction code.
Hope that helps!
May 28, 2013 | Apple iPad (16 GB) WiFi Tablet PC
My ipad is disabled how do i fix it
Try connecting it to iTunes, turning off the ipad, then hold both the lock and the home button for 10 seconds, then relese the lock button while continuing to hold the home button until iTunes recognizes the iPad. Then you should be able to reset it without problem.
Dec 02, 2011 | Apple iPad 64 GB 3G Tablet PC
Apple iPad 16 GB 3G Tablet PC Logo
1,094 people viewed this question
Top Apple Tablets & eReaders Experts
John mullen
gaucherre
Shaukat Bhutto
Shaukat Bhutto
Are you an Apple Tablet and eReader Expert? Answer questions, earn points and help others
