The refrigerator worked for about a year and one day the freezer would not freeze and the fridge was warm and Haier will not respond.
SOURCE: fridge not staying cold
Solo, firt make sure you do not have a build up of frost on the freezer inside panel. This would indicate a defrost problem. Your post states that the cooling problem is intermitant which leads me to believe that the automatic damper is at fault. It could have a build up of ice on it which is causing it to bind, or it could just be going bad. Your model does have the manual defrost timer which could be sticking at times, that is why I suggest checking the back freezer panel for frost buildup. Catriver..post back.
SOURCE: Maytag MZD2766GES side-by-side Refrigerator warm
SOURCE: fridge not staying cool, freezer still freezing
Try defrosting freezer, sometimes when the defrost thermostat fails it causes ice too build up behind the walls of the freezer then it restricts the air flow to the refer side. If it works after defrosting then you probably need to get a new defrost thermostat.
SOURCE: my fridge won't cool down or freeze
Your condenser is likely dirty clean it. the compressor could be tripped out on over load (to hot) unplug the fridge a couple hours should do it . plug it back in make sure the thermostat is on and set correctly if that does not work you will need service. Tom
SOURCE: Kenmore Elite Trio Refrigerator not cooling
No, it is not a failed condenser. You need to see if the compressor is running though. When it runs you shaould have a fan in the freezer running, a fan underneath the fridge running, and the compressor should be running. I would be willing to bet that either the compressor is bad, or the start relay on the compressor.
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
