We don't want to lose her info on her Ipod....can we restore without losing it
SOURCE: forgot my passcode
Using the Restore function for your iPod touch is part of standard troubleshooting procedure. Restoring your device will erase all data from your iPod touch, including songs, videos, contacts, photos, calendar information, and any other data. All iPod touch settings are restored to their factory condition.
Whenever you restore your iPod touch, Apple highly recommends that you perform a sync prior to restoring in order to back up any changes since your last sync. If you have movie rentals on the device, see this document before restoring.
Use the following steps to restore your iPod touch:
Make sure you have the latest version of iTunes installed and running before attempting to update.
Connect your iPod touch to your computer.
Select your iPod touch when it appears in iTunes under Devices.
Select the Summary tab.
Select the Restore option.
When prompted to back up your iPod touch's settings before restoring, select the Back Up option. If have just backed up the device, it is not necessary to create another.
Select the Restore option when iTunes prompts you (As long as you've backed up your device, you should not have to worry about restoring your iPod touch).
Once the restore process has completed the iPod touch restarts and displays the Apple logo while starting up
SOURCE: how to unlock ipod whn u forget the passcode
Check this out:
http://www.wikihow.com/Reset-a-Lost-iPod-Password
SOURCE: my ipod nano 3gen 8gb is on screenlock and is
Unlock Screen Lock and Volume Lock for Windows Vista
First you need to click on My Computer with your iPod connected.
The click on the iPod, click organized, select folder and search options, now click View the click to show hidden files and folders then click apply.
You should now see a folder named iPod_Control, click into this, then click device, now delete the file named: _locked to reset the screen lock and delete _volumelocked
Hope this helps
SOURCE: ipod touch 8gb need help to unlock passcode
go to a corner shop that says unlocking and they do it for a fiver
