I heated up my coffee this morning and when it was finished I opened it as usual to enjoy my steamy cup and when I closed the microwave door it turned on again- lit and turning. I hit cancel but it kept going. I opened it, and it stopped. I closed it and it started on again. after several attempts of unplugging, canceling, open and shutting and banging, it is still turning on every time the door is closed. help!
SOURCE: KitchenAid KCMC155J
Sounds like a classic bad door switch or switch holder. If you or a friend decide to work on it, we have *critical* safety info, info on door switch testing and replacement, and oven disassembly info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your base model number (without the suffix) here: http://tinyurl.com/gv383
SOURCE: GE JE1860 microwave won't turn off sometimes
You probably have a sticking relay on the control board.
We repair these on a regular basis for customers nationwide with our guaranteed $39.95 service.
We have full details of our service, plus *critical* safety, disassembly, and troubleshooting info at our site.
You'll find a link to our site in our listing here on FixYa: http://tinyurl.com/yzjozk
It is possible that you might have a bad door switch but I don't think so. In case you or a friend want to check that first, here are some links:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
http://www.microwavedisplay.com/doorsw.txt
We're happy to help and we appreciate your thoughtful rating of our answer.
SOURCE: Microwave still runs when door is open
Is this by any chance a combination microwave? It is is-what you are hearing/seeing is the fan running to cool it down. If it is not a combi then indeed you hav a problem-probably linked to the door catch.
SOURCE: when i shut the door
Hi
It could be due to a faulty fan on your microwave, check whether the fan is running. Check and clean all the exhaust vents. If the fan is running then it could be due to faulty control board of the microwave. Hope this helps... Please post back with model# if you need more information.
Daniel
SOURCE: Jenn-Air Microwave vent grill opens and closes
I have this same problem occasionally. Pull the vent grill open and look for a white cam that rotates when the microwave is on. To the right of that cam, there are two gray switches. The bottom switch should have a red tab that pops out. When the vent grill opens and closes continuously, the red tab is stuck in. Take a flat screwdriver or tooth pick and push gently in on the red tab to release it. It must get stuck due to grease or dirt accumulation. Good luck.
