Question about Xerox Phaser 6180 MFP/N Letter-Size Color Multifunction
Connect 6180 MFP scanner to Toshiba laptop
Does anyone know how to connect the Xerox scanner to the laptop? It is already connected via a parallel port and printing works fine.
Posted by Shayna on
J. Mishra
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 12 Answers
Press the document to be scanned on the Platen glass. Press the Scan button, an Utility will appear. Select required size and resolution. Upon scanning document, save it in compatible format and attach it to email.
Posted on Jan 09, 2014
Is there a cable available to connect my HP 5470c scanner to my Toshiba laptop. What and where can it be purchased? My computer will take USB cables but the cable with the scanner is obviously not the...
This model HP5470C was supplied with a parallel and USB cables to connect to computers.
For PCs the manual recommends using the parallel cable and for Apple computers to use the USB cable.
If the Toshiba does not have a parallel printer port then try using the USB cable.
For a manual for your scanner go to this WEB site.
http://h20000.www2.hp.com/bizsupport/TechSupport/DocumentIndex.jsp?lang=en&cc=us&prodClassId=-1&contentType=SupportManual&prodTypeId=15179&prodSeriesId=28456
Mar 30, 2011 | HP Scanjet 5470c Flatbed Scanner
Xerox 6180 MFP N error 016-782 Windows 7 x64
did you get a solution to this problem. i have the exact same situation.
Feb 16, 2010 | Xerox Phaser 6180N Laser Printer
Usb 1.0 or usb 2,flatbed scanner compatability
Find a USB device, such as a memory-stick, that is "USB 2.0" and connect it to a USB port. If Windows XP pops-up a window ("this device will perform better when connected to a USB 2.0 port"), then you have connected it to a USB 1.1 port.
Yes, you can connect a scanner, if it has a USB connection. Not all laptops have a parallel-port ("old-style" printer) port, but some scanners require a parallel-port.
Jan 29, 2010 | Computers & Internet
Can I use Xerox Work centre XK50cx with Sony FS550?
Hi Jaci,
Copy and paste the link below into you browser and type in the word "scanning". With all Xerox machines there are many ways to setup scanning. Hopefully you can pick out the best way for you!
Best of luck!
http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE?New,Kb=x_rpss_en,Company={683D76C8-B5C5-416E-9754-DD015FDB4F2E},ts=x_main_en,ques=ref(Country):str(USA),ques=ref(Prod_MFIJ_XK50cx):str(XK50cx),question=ref(ProdFamily):str(Prod_MFIJ_XK50cx),varset=Xcntry:USA,varset=Xlang:en_US,varset=prodID:XK50cx,varset=prodName:%20WorkCentre%20XK50cx
Mar 30, 2009 | Xerox WorkCentre XK50cx InkJet Printer
Xerox 6180 MFP port set up problem
I have the solution. I own a Xerox 6180 MFP, and I could not send over port 25. My ISP said they weren't blocking port 25, and my web server wasn't supposed to be blocking port 25, but something in EXIM (that has something to do with email) was blocking it, WHICH CAUSED THE PROBLEM. The solution is:
For your SMTP login name and password don't enter your email address's u/p. Instead enter your website's cPanel (or whatever) u/p. For me it's the same u/p I use to log into www.yadayada.com/controlpanel to control my website. THEN choose "SMTP AUTH (Login)" as the 'email send authentication' type.
I'm still using ports 25 and 110. And I still am entering my SMTP server address as whatever I use (mail.yadayada.com). The only thing I'm really changing is the above. Other than that, follow Xerox's instructions to do it over port 25.
Oh. And for your POP3 server address, in case you don't know, don't enter mail.yadayada.com. For some reason you gotta just enter yadayada.com here (where 'yada' is your domain).
Jan 23, 2009 | Xerox Office Equipment & Supplies
Xerox M20I SCANNER
You can only do scanning on an M20i with a USB or parallel cable. That machine does not support scanning via an ethernet cable.
Oct 25, 2008 | Xerox WorkCentre M20i All-In-One Laser...
We have a Xerox M20 Copier/Scanner/Fax/Email which we have always used strictly as a copier. We need to use it as a scanner, to reduce paper in the office and access/share documents electronically. I...
To scan a document to file (Scan to File), the WorkCentre must be directly connected to the workstation using a USB or parallel connection. Scan to File is not supported over an Ethernet connection.
Sep 22, 2008 | Xerox Office Equipment & Supplies
How to break Toshiba SP4600 Laptop CMOS PASSWORD
reset the bios by unpluging to battery.
Apr 19, 2008 | Computers & Internet
Xerox DocuPrint P8ex
In order for me to deal with this query for you i need get some informations:
- what operation system does you computer have?
- Are you gonna connect via parallel, USB, or External Ethernet Adapter
Fran10
Apr 10, 2008 | Xerox DocuPrint P1202 Laser Printer
Xerox Phaser 6180 MFP/N Letter-Size Color Multifunction Logo
53 people viewed this question
Top Xerox Computers & Internet Experts
Michael Thomas
Michael Thomas
JMJr
EKASYS IT SERVICES
EKASYS IT SERVICES
Are you a Xerox Computer and Internet Expert? Answer questions, earn points and help others
