Question about Samsung RS2578BB Side by Side Refrigerator
He solenoid valve in the door that goes to the water dispenser is bad, but I don't know how to get to it.
Posted by dennis bogush on
Paul G
    Scholar:
  • 161 Answers
I'm sorry to say , you have to remove the door inner skin to get to it
it's a real pain but it's the only way.
Undo all the screws you can feel and see, once you have done that gently remove the skin from the rubber gasket. Once you replaced it put it all back and all should be good.
Posted on Jan 11, 2014
  • dennis bogush Jan 12, 2014
    Thanks a lot, Paul it's a real pleasure to hear from somebody that finally knows what they're talking about since my icemaker works fine and I never really used the water that much. I think I'm going to wait until the icemaker goes out to lunch and then I'll pull the back often fix both at the same time. Thanks again, Dennis bogush
1 Related Answer
bobalix
  • 471 Answers
SOURCE: leaking water dispenser, how do I get to the solenoid valve in the freezer door?
Most solonoids are in the back of the unit where the water connects to the refrigerator there is a usually a fiberboard cover that you remove to gain access to the soloniod. Hope this helps.
Posted on Dec 31, 2013
Testimonial: "This solenoid is in the freezer door, it is right above where the water comes out, does anybody know how to pull out that part, it looks like it should be able to come out from the front, but I'm not sure."
Leaking water dispenser, how do I get to the solenoid valve in the freezer door?
Dec 31, 2013 | Samsung RS2578BB Side by Side Refrigerator
Water line not working
The door switch controls a solenoid valve. I don't know exactly where it is. The solenoid valve is bad, or the switch is bad. If it works intermittently, it is more likely the switch - usually. However, if you are hearing a buzz, I would think that would be the solenoid valve buzzing, indicating a problem with the mechanical valve part of the solenoid valve. Likely, it needs to be removed, taken apart and cleaned.
If this has been helpful, please take a sec to rate me. Thanks!
Don
Mar 04, 2012 | Garden
Water dispenser does not work. When I depress the water dispense actuator, I have pressure at the bottom of the door,but none from the dispenser tube spout. I ran a wire up the tube from the bottom of the...
It could be the water valve side for the dispenser. So a couple of problems can be had with this description. 1. The electric solenoid for the valve is bad so it doesn't open the valve. 2.The valve itself could be bad so the solenoid opens it but nothing flows. 3. The water line could be frozen inside the door so no water flows. 4. The dispenser switch is bad or the plastic holder that holds the switch is bad so the switch fell out of its proper position. 5. The circuit board is bad.
Easy way to check is to pull out the fridge and take the water line off that valve by pressing down on the little ring around the line while pulling up on the line (tube thing). It should pull out easily(to reinsert just push the tubing back in without holding the little ring down, it goes in by itself and self-seals). With the tube out of the solenoid valve have someone operate the water dispenser lever and see if water shoots in your face ha ha. Read further if you're testing by yourself...
You can also do the same test from the front underside where the tubing has a coupling just under the door hinge area (so you can take the door off without cutting the tubing). Pull the lower skirt off the front of the refer and you should see the tubing and little coupling, it works the same, push down on the ring area and pull the tubing out. That way you don't have to move the fridge and can operate the dispenser lever yourself to see if water flows out the disconnected coupling. If water flows then the valve/switch/circuit board are working fine of course and your tubing is frozen at the door. You will need to defrost the tubing somehow, usually means a hairdryer blowing up into the dispenser area or turning off the whole refer and leaving the door open for a day.
If nothing happens (no water still) then you need to check if the solenoid is working electrically. Pull the fridge out and pull the wire plug off the ice maker valve and put the wire plug from the dispenser valve on the ice maker valve. Watch inside the ice maker and push the door dispenser lever, if water flows into the icemaker then the electrical door switch/circuit board is OK and the problem is likely the solenoid valve to the dispenser is bad or a frozen line in the door still. You get the idea, you can swap wires/valves and even tubing (if their the same size) around till you logically find the part not working. Remember in troubleshooting you're not really trying to find the broken part... you're trying to find ALL the other parts are working, which by process of elimination will lead you to the last part that ISN'T working.
If you are comfortable with electrical troubleshooting using a multimeter you can check for 110 vac at the plugs when the switch is press also but that depends on your tools and skill level, etc.
See this link for a diagram of that door assy and the parts involved.
Typically I'd be suspicious of the valve itself being bad or the circuit board, next on the list is the switch, and last would be the frozen line.
Jun 18, 2011 | GE GSS25LGM Side by Side Refrigerator
Water not coming out of front dispenser
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} If you can't hear the solenoid on the water inlet valve(it's on the back where the water supply hooks up) when you try the water then the water switch on the dispenser is at fault.
If you do hear it Your water line could be frozen in the door. You can disconnect the line at the bottom before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it does, leave the door open till it thaws.
If it doesn't come out there disconnect it at the water inlet valve and see if it comes out there. The valve could be bad.
A strainer before the inlet valve can also get stopped up restricting flow.
Jan 02, 2010 | Hotpoint Refrigerators
Water dispenser just stopped dispensing water? Have changed filter only 3-4 weeks ago - any suggestions
Nov 18, 2009 | Whirlpool Refrigerators
Water leaks from dispenser
Bad water filter or weak water inlet solenoid. Water line to back of fridge goes to inlet solenoid valve. Check it first. Would help to know the manufacture date. If it has a filter at bottom of fridge it will cause leaks and low pressure to dispenser if not changed each year.
Sep 11, 2009 | Refrigerators
Water dispencer in fridge not working nut ice
Your water line could be frozen in the door. You can disconnect the line under the unit before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it does leave the door open till it thaws.
If that's not it disconnect the line to the water dispenser at the water inlet valve on the back where the water supply comes in and try the dispenser. if you hear the valve work but water doesn't come out, the valve is bad. If you don't hear the valve, the dispenser switch is bad.
Jul 10, 2009 | Jenn-Air JCB2280HES Side by Side...
The water will not stop coming out of the door dispenser
1 of two things. 1)the switch at the dispense flap has failed. 2) the water valve solenoid that the sitch activates has failed. you will need to pull the unit away from the wall and remove the bottom panel...on the right side you will see the valve assembly. remove the power connection to the vavles....then turn your water on...water out of dispenser means bad solenoid/valve....no water means bad dispenser switch.if its the switch you can leave the solenoid to the dispenser unplugged until you get the part.
Jun 11, 2009 | GE Profile Stainless Bottom-Freezer...
Water dispenser on front of refrigerator door does not dispense water. Ice Cube maker continues to make ice cubes. Defrosting doesn't fix problem.
Water dispensing solenoid is bad. You need to replace the solenoid valve. This typically is independent of the ice maker.
Jun 02, 2009 | Frigidaire FRS26R4A Side by Side...
Water dispenser will not work when lever is pressed. we had an intermittent problem with it before it stopped working altogather.I was going to look at it but was afraid to pop off the trim on the outside...
This could be a bad water valve in the frig. This frig has a double water valves. One for the ice maker and one for the water dispenser. It should be in the lower back. Where the water line goes in. You can check this valve easily. Find the double water valve on the frig. Turn off water supply to frig first. Swap the plastic water lines going from the water valve into the frig. Turn water supply on. Then see if the water dispenser works. Sometimes you will have to operate the water dispenser for a little while to get the air out of the line. If it works now then the problem is in the water valve solenoid and needs to be replaced.
Nov 08, 2008 | Kenmore 53642 / 53644 Side by Side...
Samsung RS2578BB Side by Side Refrigerator Logo
120 people viewed this question
Top Samsung Refrigerators Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
