My dishwasher will not start all the lights on the control panel are on but when I press the start button and close the door nothing happens
It is likely the door latch microswitch is faulty and preventing the controller from confirming if the door is shut or not. Or it is possible the door latch mechanism is preventing door from shutting. It looks like this.
Prima Door Interlock
SOURCE: Power going to dishwasher but nothing happens??
Gina, you probably blew a thermal fuse that sits on the control board. Easy fix. Have your husband first check the wiring to the dishwasher. Remove the toe panel and make sure the wire nut connections are good. If that is ok, he will have to remove the inner door screws to get to the control board. Lift out the inner door. Remove the control board cover, it just snaps off. He will see the thermal fuse on the upper right side. I will attach a photo of what it looks like...Catriver...post back
SOURCE: prima lpr 600 dishwahser
Control Lock means that the entire dishwasher is locked, for child safety purposes. It's normally cleared by holding the "No Heat Dry" button in for 4 seconds or more. It is locked again by the same procedure -- holding the "No Heat Dry" button for 4 seconds (or more. I'd suggest trying this on yours...
SOURCE: Maytag Dishwasher Doesn't Start
on a dishwasher an ohmmeter is almost useless. the best way to check is to look for voltage. at the door switch check for voltage to ground on both sides. if you have 120 on both sides of the switch then follow the wire over to the control board. if you have 120 going into the control board and nothing coming out of the control then you nood to start looking for a broken neutral. however the likelyhood that its the control panel may be a better idea especially if you are hitting buttons and nothing happens. try reseating any ribbon cables
SOURCE: My Frigidaire dishwasher will not start.
This solution worked for me too. Thanks for the money saving solution!!
SOURCE: I cannot unlock the controls on the panel
Try turning the circuit breaker off for 30 minutes. Then turn back on and see. If it keeps locking you may need new control console. Hope this helps.
Hello - Yes, it does have a child lock control. It is design to prevent children from accidently change the dishwasher cycle or starting the dishwasher. It locks the dishwasher controls by pressing and releasing the DELAY TIME icon for 3 seconds. Do you see an indication lock light on your dishwasher illuminate? It will usually appear when the controls are locked and no new selections can be made until the lock is released. To unlock the controls, press the DELAY TIME icon under the indicator light goes out.
