Question about Wharfedale Diamond 8.3 Main / Stereo Speaker
Need to find out active or passive crossover
Need to know if this speaker has active or passive crossover
Posted by Cleveland Ma on
  • Cleveland Ma
    Cleveland Ma Jan 08, 2014
    wharfedale modus one three, Not Diamond 8.3. Don't know how to modify the question
stormwind13
    New Friend:
  • 77 Answers
Should be passive.
Posted on Jan 17, 2014
I have a pioneer dxt-x4869bt sterio do I need a certain hook up subwoofers
Unless your Pioneer has a dedicated subwoofer output or output for bass speakers the signal for subwoofers will need to be generated by either a passive or an active crossover from the regular speaker outputs and then the resulting output will probably need boosting by an additional amplifier if a passive subwoofer is to be used. An active subwoofer might not require the additional amplification.
Feb 14, 2016 | Pioneer Car Audio & Video
Fuse location in pv215
Are talking about a lamp in the crossover module...?
Jul 22, 2013 | Peavey Pv 215 Pv215 Dual 15" 2-way Passive...
I have amplifier 4ohms .i want to match a spaekers to build up onkyo amplifier
The 4 ohms impedance can be matched depending on waht WATTAGE is required by you.
Also the type of speakers that you desire is also important. You can buy 4 ohms speakers or use two 8 ohms speakers in parallel . But the important factor is the choice of your music and the wattage. If there is a use of passive crossover network or active crossover network we need to consider to buy the matching speakers.
Aug 01, 2011 | Kitchen Ranges
How do i connect my pv2600amp to my peavey subs and top speakers, i have the leads but what do i do?
Line outs Left and Right from mixer to power amp Left and Right inputs,
Power amp outs to Subs(if they have passive crossovers built in check specs on subs).
From Subs then to Main spkrs. Make sure power amp is set in stereo mode using this way.
Alternative: You will need at least a 2-way stereo crossover unit inline after mixer and before power amps if the subs don't have a built in passive crossover. Most of them do have passive crossovers in the subs these days. Then separate amps or one channel would drive the subs and the other the main speakers. True stereo would require at least a 2 way crossover and two stereo power amps if hooking them up this way.
There is another option as is common with many sub setups. Send the signal to the mains using L/R outputs from mixer and a separate Mono output to the subs only. Putting only bass/kick and low frequency outputs in this send would help too.
Oct 13, 2009 | Peavey PRO-12 (00497070) Main / Stereo...
I have an auto amp with no crossover for subwoofer. i am wanting to know if i can hookup a passive crossover for sub speakers through amp to speakers say from radioshack or other home speaker system? i...
You could go with a type of passive crossover, and that should allow you to also control gain as well as the bass input, and you can also go with a low pass filter as well. These are quite inexpensive at Wal-Mart and other places, and just run in-line with the wiring. There is no real cutomizability with the latter option, but it could be a means to get better sound while you save for a stronger crossover.
Sep 26, 2009 | Car Audio & Video
Need to find out how to connect acoustics 4050 amplifier bought a system at a swap meet with no directions also have infinity passive crossovers trying to install in 69 chevelle
http://mobile.bostonacoustics.com/Manuals/GT40Man.pdf
try this site to see if it's for your model, but if not it should still give you the basics for installation. Now for the crossovers, if they are passive they will go between your head unit and amps or speakers. if you can tell me the make and model of the crossovers, i can tell you exactly how to hook them up. Let me know if this helps :)
Apr 28, 2009 | US Acoustics Car Audio & Video
I am building my own speaker for he first time.i have 2 subb woofers/mid and tweeter but only ave three way cross over what would be the best and safest way of wiring up the speakers?
Hi first thing: do you have a passive or active crossover??
  1. Passive crossover: you can connect the two output together to your subwoofer to have in the same time the low bass and the mid range of frequency.
  2. Active crossover: NO solution you have choose one out put of your crossover, i guess the best is the low output, but the choice is in your hand try the the two output(low/mid) once and choose the best for you
Let me know, bye
Apr 22, 2008 | Audio Players & Recorders
Bypassing the 150 watt blown amp with passive crossover
I'm purchasing 2 infinity 3-way passive crossovers on eBay with the same crossover freqs as my two overture 3's with blown amps. For 19.99 each, it's worth a try. Good luck to you!
Jan 06, 2008 | Infinity Overture 2 Speaker
Car stereo crossovers
you should be able to remove the passive in-line crossover, but since it is blocking everything below 3500 hz, there is no need. leaving the passive crossover in place will also help protect the tweeters if something fails in your setup as any amped frequency below 3500 can seriously damage them.
Nov 11, 2007 | Infinity Kappa 10.7t 1'' M.M.D. Dome...
How to wire in a cross over
You didn't say if it was active or passive, but here is both:
Passive crossovers are easy to install. By definition, the only type of connections they require are to your speaker line. They typically get installed between the end of the speaker wire and the speaker. Connection should be fairly simple, just like hooking up the speaker itself.
Now F-Mod crossovers modify the audio signal before it is amplified. They accept the patch cord from your receiver on one end, and then plug directly into the preamp inputs on your amplifier. They are also easy to install, and don't require additional wiring.
 An active crossover requires a little more work. You have to connect 12-volt power, ground, and a turn-on lead. The active crossover gets installed between your receiver and your amplifier. A lot of active crossovers have both speaker-level and preamp inputs, so they can usually work with either type of connection. The outputs will be preamp connections to your amplifier. Hope that helps.
Oct 05, 2007 | CTG 2 ft. Stranded Wire Crossover Cable...
Wharfedale Diamond 8.3 Main / Stereo Speaker Logo
153 people viewed this question
Top Wharfedale Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Wharfedale Audio Player and Recorder Expert? Answer questions, earn points and help others
