At this point I am only wanting to use the reciever to play music stored on my pc...am not setting up home theater at this stage
SOURCE: Denon AVR 2105/885 needs repair
Take it to any Circuit City Store. They have an Authorized Service Center in Dallas. Any Circuit City would take it and send it for service.
SOURCE: Denon Avr-1803- multiple room audio difficulties!
it is true pre amp check your cables and confirm in (avr-1100)that you select the right input.
SOURCE: No video
The Denon does not down scale you can not plug a DVD or other device in to the Denon using HDMI and have it come out Component, if your projector only has Component video inputs you must use Component video connections from the DVD and Cable box to the Denon
SOURCE: Is there any way you can connect two subwwofers to this receiver?
Certainly... the easiest way is to purchase an RCA Y adapter to split the pre-out subwoofer connection to both subs.
Here's a link to what you need: (Best Buy)
http://tinyurl.com/ctp44j
This will not, however, give you a discrete left and right sub. You'll need a receiver with 7.2 capability to do that.
Make sure the phase is set the same on both subwoofers, or they'll cancel each other out and you'll end up with less bass than you had before with one sub.
If this answers your question, would you rate it for me?
