Question about Digital Audio TRIO MP3 Player
Unit charged but wont come on
The unit will not open to play music; screen stays black...Loaded to computer and it has no response. Any suggestions as to what I should do?
Posted by Joaney Batchler on
Nuwan Chinthaka
    New Friend:
  • 170 Answers
Dear Joaney,
if it is recognize by computer as flash driver the usb part is working.
charging means charging circuit is ok.
please check the power button for disconnection and no contact.
let us know the results
regards,
nuwan
Posted on Jan 08, 2014
Unit powers up but display is frozen and no nothing after that. No remote or button response except for display off.
The display microprocessor(computer within your unit) may be bad. This IC is responsible for processing any and all IR(infra red) commands from the remote, as well as scanning all the push buttons on the front of the unit. If you're interested in having your unit repair, please visit me website at audioserviceclinic.com. You may contact me there. Thank you.
Powering unit up & charging issues.
You need to use the correct charger for your tablet. No fix necessary.
The screen going black is the screen saver, saving you power. No fix required.
Any other issues , take this up with the manufacturers website here Company Contact us
I charged my swimP3 but it won't turn on when disconnected from the computer.
The Swimp3 Player does need to be charged for at least 3 hours for the best experience. Here are some tips that could help solve your problem:
Problem: The player doesn't turn on.
Suggestion: Charge the battery in the player for at least three hours, this will allow it to fully charge. You can charge it by plugging it into the USB port on your computer or by using a USB wall charger (sold separately). If you do choose to use a computer to charge it, be sure your computer is turned on. If there is no power to the computer, then no power is going to the USB port to charge the Swimp3 player.
Additional Tip: The charging answers are in the Green Indicator Light.
If the green light is flashing off and on, then your SwiMP3 player is charging
If the light is solid green, the SwiMP3 player is fully charged
If you have no green light - then it is not receiving a charge - check the connection, make sure its plugged in properly, or check to see that there is power from the computer or USB wall charger.
Problem: I have charged my player, the light is solid green, but no music plays.
Suggestion 1: Have you loaded music onto the player? Try adding a few mp3 or wma files and test it again.
Suggestion 2: If the power is on, you loaded music, clicked the Play button and no music comes out, press and hold the RESET button for 4 seconds. It's kind of like rebooting your computer when it crashes. Many times a simple reset clears up any challenges.
If that doesn't work, then it could be the
* volume
* incompatible files or
* folders
Volume: On some units the factory volume setting is very low.
Solution: Try turning up the volume by pressing and holding the "+" PLUS button. If you click the "+" button it changes the song, pressing and holding the button will actually control the volume. And if its too loud, press and hold the "-" MINUS button to bring the volume back down.
Incompatible Music Files: If you have loaded a music file that is not compatible, it simply won't play. The SwiMP3 player works with mp3 or wma files, but not aac (like from iTunes).
Solution: Remove the incompatible files. Convert your other music files to mp3 or wma, and if you are importing your songs direct from itunes, you'll need to convert them to mp3s first.
Incompatible NON-Music Files: An MP3 player is similar to a Thumb Drive or Flash Drive because it can hold any kind of file that will fit in the drive's capacity. However, if you have loaded an incompatible file - including JPEGs, Cover Art, Word Docs, anything that is not an MP3 or WMA file, the player simply can't translate it into music.
Solution: Remove the incompatible files, leaving only your mp3 or wma files in your root directory.
Folders: The mp3 player is not able to open folders and play music files stored inside, to the Swimp3 player the folder is simply an un-playable file.
Solution: Open the folders, move or copy the music files into the root directory (remember, mp3 or wma - not aac), then delete the folders.
Michelle
Authorized Finis Dealer
Get Swimp3 Deals at WaterproofMusic.com
15helpful
2answers
Sansa clip has crashed. No response when I try to reset
Press the Power and Play (>||) button together for 20 seconds to reset the unit!
Monitor screen stays blank
HP desktop computer? Change the monitor cable. The cable from the monitor to the computer, may be bad.
Happens.
If this doesn't solve it then I suggest the GPU is bad. Graphics Processing Unit. If you have Integrated Graphics, (Also referred to as 'On-Board'), then I suggest buying an average, inexpensive graphics card, and installing it.
You'll have to see what expansion slot, your computer uses for graphics. It may be a PCI slot, or an AGP slot, or a PCI Express x16 slot.
Clear as mud on that last one? Let me give you some links, that might help clear up what an Expansion slot is, and the three types of expansion slots used for a graphics card.
1.Expansion slot:http://en.wikipedia.org/wiki/Expansion_slot
2.PCI (local bus):http://en.wikipedia.org/wiki/PCI_(bus)
3.AGP:http://en.wikipedia.org/wiki/AGP
4.http://en.wikipedia.org/wiki/PCI_Express
5.http://en.wikipedia.org/wiki/File:Asus_a8n_VMCSM02.jpg
The link above (No.5) shows a photo of an average motherboard. At the top right you will see two White slots. Those are PCI expansion slots.
Below the PCI slots is a PCI Express x16 slot. It is Black in color.
2helpful
2answers
Samsung mp3 player YP-F1 screen diplay won't turn on-even when fully charged
I have samsung yepp YP F1. After full charge, it only appear "loading" and somebody told me to reformat the unit. My question is how do i reformat the unit. thanks - - ronnie
2answers
Delstar 1GB MP4 Digital Player
Have you got that on ON position. Some time you have to hold th play button for few seconds to get it on
SSB
Mp3 music plays but
The Opal has a reset hole on the back of the unit in which a toothpick (non metallic) can be inserted to reboot the player.
If this does not work, I suggest that you reformat the player by using the WindowsTM format command on the unit. To reformat the memory
  1. Right click on the device within the Explorer or My Computer window
  2. Select the format command (full format) to reformat the internal memory of the device.
  3. Reinstall the firmware from http://download.rcaaudiovideo.com/downloads/opal_fwutility_v2.3.0.exe
2answers
Mp3 player wont play songs or anything
Only 2 suggestions here: 1) Make sure your HOLD switch is not enabled. 2) Try to update the firmware If neither of these work, time to send the unit back to Sandisk
Digital Audio TRIO MP3 Player Logo
Top Digital Audio Audio Players & Recorders Experts
ray gallant
Tom Chichester
Fred
Fred
Are you a Digital Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
