Question about Alba Televison & Video
Alba tv flashing blue light tv turned itself off
Watching tv screen goes blank and tv turns off the blue light now flashing fast
Posted by amanda on
tv repair
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 45 Answers
If it turns off after a while that's a transistor going hot.
You need a technician to test it for you. If you want to do it yourself
let me know. Good luck.
http://www.tvrepair.localdomain.me
Posted on Jan 08, 2014
Testimonial: "i would try myself under instruction if not too complex"
5 Related Answers
dennis bullard
  • 4090 Answers
SOURCE: Hisense tv turns on and off
STOP!
The unit has a fault on its power board and sustain board.
It turns off because the sensor is preventing some component from bacoming overheated and catching fire or damaging further components. Seel professional repair.
Please rate my help++++Thanks for using FIXYA
Posted on May 13, 2010
David Cunliffe
SOURCE: alba 42"lcd tv watching tv it just went off,
Alba is now a product of Argos, their low cost help line number is 08456040105
Posted on Nov 19, 2010
ginko
Ginko
  • 19396 Answers
SOURCE: HITATCHI ULTRAVISION P50S601...POWER LIGHT BLINKING...WONT COME O
The TV is on protect mode.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Posted on May 22, 2009
jerryg50
Jerry Greenberg
  • 1691 Answers
SOURCE: Blue color spread over the pictures
This sounds classic to a thermo problem where a part(s) are becoming thermo sensitive with aga and use. When the set is cold and then warmed up, the defective part(s) is changing characteristics.
Some components became thermo sensitive that are driving the display. Or an embeded component in the display itself became thermo sensitive. It is very possible that the fault is on the board that does the X - Y addressing or on the backplane electronics of the display screen itself.
Using the set with defective components is a bad idea. If the part(s) fail completely and go shorted or opened, other more costly damage can be done.
The service rep for the manufacture of your set is equiped and trained to be able to troubleshoot and service your set.
You will have to take the set in to have it serviced.
Jerry G.
Posted on Apr 17, 2008
Chi Chu
  • 8457 Answers
SOURCE: tv has blue/white lines going through the screen
Ur main video board backlight,is dying must be replace to solved this prob.
Posted on Oct 19, 2009
My kobo wont turn on
Try this, it worked for me
Turn off phone
Remove battery
Wait 10 seconds
Plug in charger
Insert battery
Turn on phone
Dec 12, 2017 | iPhone Apps
Alba LCD32HDF TV won't come on blue light just keeps flashing. Tryed unplugging it but won't come on
just had the same problem blue light flashing no sreen what i did was press the standby button on the side of tv very fast about twenty times and it came on but now have a little black shadow on the left hand side
Aug 09, 2012 | Televison & Video
ALBA tv screen turns itself off, but the volume stays on, what's wrong with it? how do I correct it?
Might be some loose solder terminal/s at its horizontal output section. The set should be checked.
May 11, 2012 | Proton MM2701VT 27" TV
Alba 42"lcd tv watching tv it just went off,
Nov 18, 2010 | Televison & Video
TV SREEN GOES BLANK, BUT AUDIO CONTINUES NORMAL,
Try unplugging for 36 hours. I had the same problem but with no sound and picture
Mar 03, 2009 | Sony KP-53HS10 TV
I have PHILIPS 42pfl5332d/37. I was watching tv, and suddenly the screen goes blank. There's a blue light that turns on when the tv's on, however when the screen went blank, that blue light turned orange...
I don't have that problem, my problem is that I lost my remote control, so I can't configure de channels.. I just have 4.. =S.. I can see the menu, but in the part that say start configuration, I cant activated without the control, I don't know what to do.. aNybody Knows??
May 19, 2008 | Televison & Video
Sony 57" rear prijection TV has a fast flashing light and will not turn on
turn on tv, after a few minutes picture goes black, but still have sound. red light blinks 5 times,turn set off same thing happens when you turn set back on. some times it want do it for 10 min.
Apr 25, 2008 | Sony KP-57WS500 57" Rear Projection...
Televison & Video Logo
474 people viewed this question
Top Alba Televison & Video Experts
 Grubhead
Grubhead
Muntejaya Ginting
Muntejaya Ginting
Are you an Alba Televison and Video Expert? Answer questions, earn points and help others
