Question about Lenovo 3000 Y410 Notebook
No sound audio driver is installed, cant hear anything speakers are ok
Posted by Chris Michelle on
domingo rosario
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 95 Answers
Go to control panel click on sound and devices and check to make sure your sound is hook up!!!!
Posted on Jan 13, 2014
3 Related Answers
Anonymous
SOURCE: No sound at laptop speaker but audio output is ok
I have lenovo notepad 3000n100 with winXP sp2.
I downloaded realtek audio from ibm site and installed.
Now sound is coming at my output port but the in-built laptop speaker is not giving any sound output.
The hardware is ok as the sound was coming at in-built speaker before formatting. The previous audio driver set up file i have lost.
Plz help.
Posted on May 20, 2009
Anonymous
  • 5 Answers
SOURCE: Lenovo R61 Speaker Replacement
look up on lenovo.com
Posted on Jul 07, 2009
jgroves705
Jeffrey Groves
  • 573 Answers
SOURCE: I recently installed Windows 7 Ultimate but it
KVV:
IBM Provides all of the drivers available for your laptop at this web site:
http://consumersupport.lenovo.com/us/en/DriversDownloads/drivers_list.aspx?CategoryID=6
You may be able to use the Vista drivers with Windows 7.
Thanks for using FixYa
Posted on Jan 22, 2011
When i plug in the speakers no sound is coming out it doesn't work correctly i cant hear anything i'm playing.
Hi taceeg06,
Have you check all the Volume setting on you computer?
On the lower right side look for the computer Icon check if there is a red X on the speaker Icon, if there is then it can be that here is something wrong with the speaker driver or it does not detect the speakers.
If you do not see the speaker Icon then the Driver for the Audio card is not installed on the computer and you may need to re install that Audio Card Driver to be able to regain the audio from your Speakers.
Also the speakers should connect to the Green Audio Jack behind the computer, if it is then still no Audio you can try the Audio Jack in front of the computer as well to check the Audio Card in the Machine, if the front and back audio jacks do not detect nor produce sound when the speakers are connected then re installing the driver for the Audio card may work, unless during the installation an error shows that the there is no audio device detected then it means the Audio Card is busted.
Let us hope not since it is very seldom an Audio Card could go busted.
I hope this helps.
Have nice day,
mvincentc
Jun 12, 2011 | Insignia 2.0 Speaker System (2-Piece)
I cant hear anything out of my speakers how do i fix this problem?
the drivers might have been corrupted by something or you might have got a virus run your antivrus program and test for a virus then
you might have to uninstall then reinstall either the sound drivers or the sound card make sure you have both of these devices baked up to a disc before uninstalling
a yellow? question mark means you need to install/update driver right click to install driver
as for the sound
control panel sounds and audio,volume you can adjust the volume or
advanced,speakers select appropriate speakers or
audio you will find 3 drop down lists make sure you have selected the right speakers or control panel,administrive tools,computer management,device manager scroll to sound,video and game cotrollers could be a yellow question mark? right click to re-install drivers
hope this helps
Dec 14, 2010 | Logitech Z313
My computer keeps saying there is something wrong with my sound card or audio device does that mean that it is something internal. I've tried the troubleshooting and even tried the control pannel settings.
if you cant hear anything coming out of your computer speakers there is something wrong here what to do
if your computer came with a disk the sound drivers could be on it
control panel sounds and audio,volume,advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make the necessary adjustments there or control
panel,administrive tools,computer management,device manager,sound video and game controllers could be a yellow question mark? right click to re-install drivers
hope this helps
Dec 01, 2010 | HP (400745-001) Sound Card
I cant hear anything from my speaker it said that theres a problem with my sound drivers
Completely uninstall the drivers for your soundcard. Go to the manufacturers website and download the most recent drivers/install. Install this (following the instructions from the manfactuere) on your computer. You should now find that when your speakers are turned on and you play a sound source, thigs should be ok.
Sep 03, 2010 | Computers & Internet
I have a dell computer and the speakers are attacked to it but i cant hear anything. i checked if the cables were in the right place but they are and i still cant hear anything. i went to control panel and...
If everything is grayed out in the audio devices property in the control panel, that means there's a problem with your audio driver, first step I would take is to reboot your machine, hopefully it will come back.
If that fails, most Dell computers come with a Application CD, put the CD in the CD rom drive and have it reload the audio drivers back in.
Also make sure your speakers are plugged into the green port on back of your computer
Feb 17, 2010 | Dell Audio Players & Recorders
Cant hear sound after changing the operatin system
You need to reinstall all mobo drivers for that system. Go to vendors site and download / install.
NB = Always install chipset drivers first.
Dec 04, 2009 | Intel Computers & Internet
Can't hear sound
re-install drivers, if it works, ok otherwise check speakers on other system. if the speakers are ok, then the sound section of mother board might gone out of order, need an extra PCI sound card.
Feb 02, 2009 | Intel Motherboard
Cant hear sound from headphones and microphone is not working
speaker working ok but microphone is not working please give me solution
Sep 11, 2008 | Toshiba Satellite A100-S8111TD Notebook
Sound
did u install sound card drivers
if u install correctly go to control panel and sound
check there whether audio device is showing or not. if not u didnt install ur audio otherwise u installed correctly but the problem is in ur speaker.
Feb 23, 2008 | Logitech Z-3e Computer Speakers
No sound
May be the driver for yur sound card are not installed....
Feb 03, 2008 | Dell Dimension 4600 PC Desktop
Lenovo 3000 Y410 Notebook Logo
Top Lenovo Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
efs_perpends
efs_perpends
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
