NC 510 RECHARGEABLE BATTERY NEEDS TO BE RECHARGED WITH SUNPAK QBC-5 QUICK CHARGER. HOW LONG DOES IT TAKE TO ACHIEVE THE THE CORRECT CHARGE LEVEL ?
Sunpak uses different power sources on their high-power handle mount (a.k.a. hammerhead) flash guns. The most common is the battery basket that holds 4 or 6 AA or C batteries depending on the type of the unit. One can insert Nickel-Cadmium or Nickel-Metal-Hydride rechargeable batteries instead of the primary cells, this way reducing the "consumables" costs at the expense of the smaller number of flashes per battery set. (Actually, NiCd or NiMH cells would probably give smaller number of flashes compared with the alkaline cells, but the recycle time between the flashes can be shorter. The reason is that at charging the flash capacitor inside the flash current counts more than voltage. Sunpak sells Ni-Cd battery packs named CL-2 for their flashes that utilize 6 AA-cells, and CL-3 for their 622 series (4 C-cells). The charger for these is the QBC-5. It recharges the exhausted batteries in 3 hours. As a solution assuring the shortest duration between flashes Sunpak offered the Powerpak, a shoulder holster that held a dry (non-rechargeable) battery of 510V, it charged the flash capacitor directly, omitting the transistor inverter in the flash body. As such battery became obsolete, the Poverpak has been superseded with the NC510 and later the TR-II PAK, which utilizes 10 Ni-Cd rechargeable batteries as a power source, and a powerful (more capable than the one in the flash) transistor inverter. NC510 and TR-II PAK use the same connection to the flash and the same outlook as the original Powerpak but, being rechargeable, are more economical. QBC-5 also serves a charger for the NC510 and TR-II PAK. You may ask, how the same charger can be used for 4, 6 and 10 cell NiCd packs. Well, the charger is specially designed for that, although charging time differs at the different battery packs. The NC510 and the TR-II PAK needs 10 hours to be recharged, when exhausted. The best way to avoid damages (overcharging degrades NiCd and NiMH cells) is to check temperature of the batteries. Charging must be cut off if the battery becomes hotter than 45 ?C (115 ?F). If after 10 hours of charge the NC510 does not power (the otherwise working) flash, then it must be serviced. Replacing the batteries is an easy job that can be done at home, with some soldering skills; NiMH cells with solder tabs are available at many web-based supplyers. Don't solder the cells directly, heat damages them. Avoid touching parts inside, when the pack is turned on: electrocuting is fully possible. Better find a professional, if you are not familiar with the electronics.
SOURCE: Problem with AF-360FGZ Flash
I use 2500 rechargeables and it is ready to fire almost instantly. Are you trying to light up a big area and therefore using full discharge with each fire? Maybe this is why, but I don't know as I have never had the problem. I am quite surprised by how quickly my AF360FGZ is ready to fire again.
SOURCE: Amperege of 580 EX-II
Interesting Question!
The rating in milliamps is a matter of battery capacity and charging rates. The higher the better as you will get more flashes per charge as long as you have the correct charger to match the batteries’ capacity and use the correct charging times. Aside from this issue of duty cycle between charges- this has no effect on the power of the flash unit as to output. This cant burn out or damage the circuitry.
The issue here is VOLTAGE. Most AA alkaline batteries provide 1.5 volts. Most rechargeable AAs provide 1.2 volts. We are looking at a voltage differential of 1.2 volts (a 20% deficit) if 4 batteries are required. This MAY cause slower recycling times in order to attain a full charge for each shot. In SOME units that can cause a bit if overheating due to strain on the step up circuitry.
It so best to check with the manufacture or distributor of you flash unit before purchasing you rechargeable batteries and charger. If you units have a built in charging circuit this can definitely be problems if there is a mismatch in charging rates and voltage. If this is the case be sire to check your manual or with the manufacturer or distributor- there must be a list of compatible batteries.
Ed
SOURCE: Sunpak 622 Recycle Time w/ Batteries vs AD-26
I have made Nimh pack which has 2900MAH cells and is very fast recycling.But beware that it will heat up Xenon(it needs cool down time before you fire full power repeatedly.Also its capacitor will be short life due to electrolytic(Same as fast battery chargers ruins the battery life).
And when its production is seized,I care it more.
