Question about KitchenAid 24 in. KUDI01FLSS Stainless Steel Built-in Dishwasher
I have the same dishwasher with the same problem.  Can anyone help?
Posted by halhelp on
  • DMI941 Nov 18, 2007
    Same Situation: Cleaning Lite blinking continuously. Durty dishes in the DW. It will not reset. I turned the Breaker off to hopefully cancel something but it just keeps blinking.
Anonymous
Open the dishwasher door, press in rapid sequence the following keys: Hi Temp Scrub, Energy Saver Dry, High Temp Scrub, Energy Saver Dry. Close the door until it latches and press the Cancel key. The machine should reset itself. It worked for me when I had the same problem
Posted on Jan 14, 2008
Anonymous
The blinking clean light on that DW (kudi01flss) was solved thanks to the dude (nothappy2008) who wrote about how to reset the lite by pushing the Hi temp scrub, energy saver dry, high temp scrub, energy saver dry, then shutting the door, then open it and press the cancel key. The lite cleared!! How the hell did you know that?? It stated in the troubleshooting section in the manual that it was a heater problem, and that was it. Was it printed on the tech sheet that's in the unit?? Hat's off to you dude!!
Posted on Aug 20, 2009
  • journeys end Apr 10, 2011
    Thanks to Nothappy2008 and the affirmation of nimrod1, my husband and I gave your fix a try. It looks like you are a miracle worker and kudos to you both! We thank you from Maine!
What are the dimensions?
You are missing a digit in the model number. KitchenAid Dishwashers have a number (0-6) after the SS.
The KUDI01FLSS0 installation guide gives the dimensions of the dishwasher opening and the unit itself on various pages. See http://www.kitchenaid.ca/assets/pdfs/literature/Installation%20Instructions%20-%208524480.pdf . The top vent and the front vent KUDI01FLSS model washers are slightly different. The front vent dishwasher dimensions are 33 7/8" H (with the wheels removed) x 23 7/8" W x 24 7/8" D (including the handle). The top vent model is only 24 1/2" deep. With the wheels in their lowest position, the opening for the dishwasher must be 34 1/2" high (from floor to the bottom of the counter top).
I hope this helps. Other KitchenAid appliance manuals are available here: http://shared.whirlpoolcorp.com/product_literature/search.jsp?siteCd=KAD . Use the search box to enter the model number and use the drop down menu to select Consumer.
Aug 14, 2012 | KitchenAid 24 in. KUDI01FLSS Stainless...
My kitchenaid kudco3fvss has a dented front door panel. how do I remove it from the door?
Go to www.applianceart.com
These guys make dishwasher covers in a variety of colors, textures, and designs. They also have stainless options.
Put a cover on your dishwasher and your dent has now been removed.
Hope this helps.
Jul 26, 2011 | KitchenAid 24 in. KUDI01FLSS Stainless...
Water stays in dishwasher
Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
Dishwasher Problems - Water will not drain out
heatman101
Nov 05, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
I own a KUDS01FLSS3 KitchenAid and the bottoms on top have worn through. What is the panel number for the panel?
I'm not sure what panels you are looking for. I know Appliance Art sells custom stainless panels for the dishwashers that allow you to slide out old panel and insert new one. They also have stainless steel "rolls" for wrap-around dishwashers. www.applianceart.com
Sep 16, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
Looking for stainless steel Ariston dishwasher door panel
Not sure if that model is available but I know these guys have the cheapest stainless options - ApplianceArt.com
Apr 23, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
I cannot change cycles and the dishwasher won't turn on.
Micro controller problem. Take help from authorized service center help.
Apr 11, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
How do I clean the KitchenAid 24 in. KUDI01FLSS? I can't wash dishes until it's cleaned.
Use 1-2 packets lemon kool-aid (unsweeted of course) and run it with no dishes in it.
The citric acid will dissovle most gunk
Oct 20, 2009 | KitchenAid 24 in. KUDI01FLSS Stainless...
Kitchenaid dishwasher kudp01flss6
I managed to do it without removing the door, bit fiddley but have a look at http://www.howtofixanything.co.uk/howto-260.html
Mar 01, 2009 | KitchenAid 24 in. KUDI01FLSS Stainless...
Kitchenaid KUDS01FLBL2 dishwasher will not run
Juan, I found this http://fixitnow.com/wp/2007/01/20/blinking-clean-light-on-whirlpool-built-dishwashers/
It should help you out with the issue you are having with your dishwasher. Watch the video too!
Best of luck
Feb 25, 2009 | KitchenAid 24 in. KUDI01FLSS Stainless...
KitchenAid 24 in. KUDI01FLSS Stainless Steel Built-in Dishwasher Logo
999 people viewed this question
Top KitchenAid Dishwashers Experts
Michael Thomas
Michael Thomas
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
