Question about Bissell 8910 ProHeat Clear View Upright Vacuum
Bissell model 8910 carpet cleaner
Need instructions on how to replace belts
Posted by stephaniej on
  • 5 more comments
  • Anonymous Apr 29, 2008
    How do I replace the belt on my Bissell ProHeat carpet cleaner
    I have taken 2 screws out o the clear cover on top of the shampooer
  • autumnmist Sep 09, 2008
    hank12's solution to the "replacing the belt" problem on the Bissell model 8910 sounded great except...I can not get access to the other two skrews that are deeper inside the machine on the pump. The skrewdriver is at a 45 degree angle and it is impossible to reach them. Any suggestions? This seems impossible!
    autumnmist
  • Anonymous Jan 19, 2009
    my bissel pro heat 2 carpet cleaner brush bar does not turn? help
  • Anonymous Mar 08, 2009
    replace belt
  • Hathora777 May 11, 2010
    Thanks for the awesome instructions! It's alive! Alive!! lol
  • Anonymous Mar 25, 2014
    not working
    my Bissell carpet cleaner model # 9500 12074G was bought on November 22, 2013
Anonymous
Depending on which style you have, it may have a opening on the right side as you look at the front of the machine. If not you may need to remove the cover. If it does it says "belt access" and has two 1/8" (about) slots in the cover. with a small screw driver or something similar insert tool into slot and gently pry(if you are looking from the side) the left slot up and towards the right and the right slot up and to the left. It will slowly (or quickly depending on how hard you have to push) pop up and you can slide it off and see the pump. I think it is easier to just remove the 4 screws that hold the pump in place so you can replace both belts at the same time and not struggle with having to stretch the new belts. The last time I did this the Sprocket(small metal peice with teeth that turns the brushes) had broken off. I cleaned and dried everything and used 30 second epoxy to glue the sprocket back on and it works fine lasts a long time. Once you have removed the 4 screws holding the pump you can use a flashlight and screwdriver, knitting needle, pen etc. to hook the belt from the brush on to the pump shaft(sprocket) very easy. You may need to tilt and angle the pump a little to gt the belt over the lip on the sprocket. Like I did when I did this you will need to put the smooth belt on over the pump shaft first then put on the brush belt and screw the pump back into place (4 screws just snug because you can easily strip the plastic mounting holes) and put smooth belt on the electric motor shaft. you may need to stretch the belt a little because it has no gears it is just friction that turns the pump. Clean and dry everything this will make this repair last longer. If you will take a few minutes after each use to clean at least around the belt area they will last a long time. You can even put a belt conditioner on them for added life. Have a wonderful day!!!!!
Posted on Nov 10, 2007
Anonymous
I have a Bissell model 7950 so I am not sure if they are exactly the same but here's what I did to replace the pump belt. There are two red retainers holding the brush assembly in place. Remove the retainers and the brush assembly should move freely except for the belt on the right hand side. Remove that belt and you will see a shaft that holds the brush belt and the pump belt. Slip the smooth pump belt on and then put the brush belt back on and secured the red retainers. Turn the machine over and you will be able to pull the belt up over the drive shaft. I replaced the pump belt, started to clean the carpet and then the brush belt broke. At least I know know how to fix it!! Hope this helps.
Posted on Jan 20, 2009
How do i replace the brush belt to my bissel pro heat carpet cleaner?
Follow the link below for belt change instructions on bissell.com.<br /> <a href="http://www.bissell.com/VideoRating.aspx?id=1555">http://www.bissell.com/VideoRating.aspx?id=1555</a>
Aug 25, 2010 | Bissell 8910 ProHeat Clear View Upright...
How do i disassemble bissell proheat model 8910 carpet cleaner to check motor
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that will give you all the information you need to fix your Bissell Proheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
Nov 06, 2009 | Bissell 8910 ProHeat Clear View Upright...
Replaced pump in the 8910 and can't get cover back on
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
heatman101
rtwes
May 17, 2009 | Bissell 8910 ProHeat Clear View Upright...
Need free manual down load for Bissell 8910 pro heat carpet cleaner
BISSELL User’s Guides can be downloaded at www.bissell.com
On the front page under Customer Service click on User’s Guides and enter the model number of your unit.
User Guide will be displayed as a PDF file.
Mar 08, 2009 | Bissell 8910 ProHeat Clear View Upright...
Model Bissell Carpet Cleaner
I just needed the same info and found the model number - you have to turn the whole unit over. It's underneath the the vacuum unit, near the brush. Hope this helps.
Dec 22, 2007 | Bissell 8910 ProHeat Clear View Upright...
Bissell 8910 ProHeat Clear View Upright Vacuum Logo
1,491 people viewed this question
Top Bissell Vacuums Experts
Marvin
Marvin
Mike
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
