Question about Humminbird Ice35 Ice Fishing Flasher ()
Unresponsive Took out my ice 35 this yr for the start of its third season and I seem to have problems I can't get 2x and not sur about 10x either also can't go up or down after starting I also can't turn if off either seems like once I turn on and set to either 1x or 4x everything stops working the dial has no effect when turned
1 Related Answer
Anonymous
  • 29 Answers
SOURCE: Once my line is down in the water when ice fishing
Make sure the transducer is level and also make sure your beam is set to wide. If you have theses suggestion in place there should be no reason that you can not see your jig.
Joby @ Humminbird
Posted on Jan 05, 2011
(2x-10)(x-1)
Use FOIL, first, outside, inside and last.
First 2x * x = 2x^2
Outside 2x * -1 = -2x
Inside -10* x = -10x
Last -10 * -1 = 10
Thus, we have 2x^2 -2x -10x + 10
Collecting like terms, we get 2x^2 -12x + 10
Good luck,
Paul
Nov 29, 2016 | Office Equipment & Supplies
What is rational expression of (22x +11) (10x2 +5x)
I assume the 10x2 means 10 squared. (I will show it as 10x**2)
(22x+11)(10x**2+5x) factors into"
11(2x+1)*5(2x**2+1x)
=55(2x+1)(2x**2+1x)
=(55x)(2x+1)(2x+1)
Multiplied out, it becomes 55x(4x**2+4x+1)
= 220x**3 + 220x**2 + 55x
Dec 11, 2014 | Computers & Internet
I need to understand how to divide a binomial.
Let's take 2x^2 - 10x +12 and divide it by x-2.
__2x_-_6____________
x-2 ) 2x^2 - 10x + 12
2x^2 - 4x
- 6x + 12
- 6x + 12
0
How many times does x go into 2x^2. Put the answer, 2x above the 2x^2. Next mulitply (x-2) by 2x and put the answer under 2x^2. Now subtract that answer from 2x^2 - 10x and we get -6x (-10x - (-4x)).
How many time does x go into -6x. -6 time. Write this above the line and put the answer above the -10x. Next multiply (x-2) by -6 and put the answer under the -6x. Subtract and we get 0 and we are done. If we want to check our answer we can multiply (x-2) and (2x - 6) and we should get 2x^2 - 10 x + 12.
Good luck.
Paul
Oct 03, 2014 | Office Equipment & Supplies
I have a three year old Amana ABB2527DEB. The Freezer seemed to be overworking and the fridge was 68 degrees. Took everything out of unit and unplugged it for more than 24 hours. Cleaned it inside,...
This could be a double problem.
Yes the auto defrost cycle seems to have failed allowing an ice build up.
Secondly the door seal is leaking allowing warm moist air to sneak in. You probably need a door gasket too.
Apr 04, 2011 | Amana ABB2527DEW / ABB2527DEB / ABB2527DEQ...
I have a LG GE20 DVD Rewriter Is a DVD+RW disc a format that is editable and suitable for this unit?
The LG G20 DVD Rewriter is an advanced external burner that supports 'editable' Rewritable DVD+RW disk.
As a generic comment, not all writable/rewritable media are made equal and problem with branded & unbranded disks are not uncommon, so stick to brands that work for you for your specific unit!
The following is the advertised support for your unit, hope it helps:
Reading Rate DVD-R/-RW/-ROM 16x/13x/16x/16xSL/12xDL max. DVD-RAM 2x, 3x-5x, 6x-12x DVD-Video (CSS) 4,8x max. (Single/Dual Layer) DVD+R/+RW 16x/13x max./ 12xDL max. CD-R/RW/ROM 48x/40x/48x max. CD-DA (DAE) 40x max. Burning Speed DVD-R 2x, 4x CLV, 8xZCLV, 16x PCAV, 20X CAV DVD-RW 1x, 2x, 4x, 6x CLV DVD-RAM 2x, 3x ZCLV, 3x - 5x PCAV, 12x PCAV DVD+R 2.4x, 4x, 8x, 12x, 16x PCAV, 20X CAV DVD+R Double Layer 2.4x, 4x, 10x, 12x ZCLV DVD-R Dual Layer 2x, 4x, 6x CLV, 10x, 12x ZCLV DVD+RW 2.4x, 4x, 6x, 8x ZCLV CD-R 4x, 8x CLV, 16x, 24x, 32x, 40x, 48x ZCLV CD-RW 4x, 8x, 10x CLV, 16x CLV, 24x, 32x ZCLV
Dec 28, 2009 | Computers & Internet
Hl-dt-st dvdram gsa-t20n ata burn speed for cdr changes to 10x minimum automatic soon as i put a blank cdr in. i need to do slower burn Speed (4x) and i tried with different software and its always the...
Your drive doesn't support slower burning speeds unfortuately, here are the specifications for it:
Write Speed DVD+R 2.4x CLV, 4x ZCLV, 8x CAV DVD-R 2x CLV, 4x ZCLV, 8x CAV DVD+RW 2.4x, 3.3x CLV, 4x ZCLV, 8x ZCLV
(8x Speed disc: 3.3x CLV, 8x ZCLV)
DVD-RW 1x, 2x CLV, 4x, 6x ZCLV DVD-RAM 2x, 3x ZCLV, 5x PCAV(Ver.2.2) (16x Media: Not support) CD-R 10x CLV, 16x, 24x ZCLV CD-RW 4x, 10x CLV, 16x ZCLV
(High Speed: 10x CLV, Ultra Speed: 16x ZCLV, Ultra Speed plus: 16x ZCLV)
DVD+R DL 2.4x CLV, 4x ZCLV, 6x ZCLV DVD-R DL 2x CLV, 4x ZCLV, 6x ZCLV Read Speed DVD-R/RW/ROM 8x/8x/8x max. DVD-R DL 6x max. DVD-RAM (Ver.1.0/2.2) (Ver.1.0) 2x
(Ver.2.2) 2x, 3x, 5x
DVD-Video(CSS Compliant Disc) 4x max. (Single/Dual layer) DVD+R/+RW 8x/8x max. DVD+R DL 6x max. CD-R/RW/ROM 24x/24x/24x max. CD-DA (DAE) 24x max. Sustained Transfer Rate DVD-ROM 11.08 Mbytes/s (8x) max. CD-ROM 3,600 kB/s (24x) max.
Jan 28, 2009 | Computers & Internet
New tires
ya, and all the hills make it 10x worse. i'm from pittsburgh. it all depends on how much you want to spend. but make sure they are winter performance and not all season, they are better for snow and icey conditions.
good ($150-$200):
Bridgestone Blizzak DM-Z3
Goodyear Ultra Grip SUV
Dunlop Grandtrek SJ5
best ($200-$300):
Michelin Latitude X-Ice
Pirelli Scorpion Ice & Snow
Toyo Open Country G-02 plus
Dec 28, 2008 | 2004 Lexus GX 470
Center Brake Light Not Working
Took mine apart today and found my third brake lamp had some soldier that had cracked on positive and negative causing intermittent third brake operation. Email me and I will send you pictures [email protected] oh yeah my car was a 2003 g35 coupe. Don't know if they are all the same.
Nov 21, 2008 | 2004 Infiniti G35 Sport Coupe
10 yr old Frigidaire ice maker stopped making ice
check to make sure the fill tube is not plugged with ice if it is not then i would guess the valve is shot
Oct 30, 2007 | Frigidaire FRS3R5EMB Side by Side...
Humminbird Ice35 Ice Fishing Flasher () Logo
167 people viewed this question
Top Humminbird Boating Experts
Mike
ray gallant
Are you a Humminbird Boating Expert? Answer questions, earn points and help others
