Power to the kegerator but the unit not coming on. Not compressor, fan or display. Checked fuse on circuit board which was fine. Looking for wiring schematic or guidance on what to look for.
SOURCE: Temperature - Is fan supposed to constantly run or is it controlled by thermostat
You said ,Top half of Danby DKC645BLS refrigerator 10 degrees warmer than bottom half. Bottom half cooling to approx. 34 degrees.
Is it running all the time without cycling off and on as it should be doing?
Sorry to have to tell you this news.
But this would mean a bad thermostat or insufficient freon in the cooling system.
The same issue with the fact that one compartment is warm and the other is cool!
Let me know that service tells you!
Thank You
Huuum
Please remember toleave a rating
SOURCE: new danby kegerator - tastes like rubber hose
There is a check valve inside the coupler of the danby kegs that cause this problem. The valve is mainly there to prevent beer from back-flowing when changing the keg. Next time you change your keg check for a little black plastic retainer and also a small white plastic ball inside the coupler. Remove those (or just smell it) and you should notice that this is the taste/smell your beer has. I removed mine after this discovery, and there isn't any issues with the taste/smell since. I've heard this is a common issue with the Danby D coupler systems. Also, you won't have any issues with beer backflow when you change the keg, provided the line going to the tap is empty (which usually is if keg is kicked).
SOURCE: need a parts list for
I can obtain part breakdowns and replacement parts on danby appliances , Erin @ Jeffreys appliance service (509) 928-7176
SOURCE: Danby Kegerator is beeping and flashing EE and won't cool
I am having the same problem seeing if you found a fix??
SOURCE: Where do I get replacement parts for a Danby
I have Danby keg cooler touch pads in stock, the touch pads are the most common failing part on the coolers, I also have access to many more parts as well as technical assistance, please ask for Erin (509) 928-7176
