Question about Nuova Simonelli Mac 2000 Espresso Machine
Descale mac 2000 - Nuova Simonelli Mac 2000 Espresso Machine
Eric Ramos
    Habit-Forming:
    New Friend:
  • 103 Answers
This process should be made in a workshop depending with the extent of build up. you can use citric acid or lemon salt which you can purchase in local groceries.
Posted on Apr 02, 2019
No coffee is coming through, I guess it needs descaling. How do I do this? Note my machine does not look like the one in the picture. It does have KP2000 on it though!
remove every thing filter holder ecc then try again do not do any descaling as yet you may block the system even more first get the water to flow and make sure you clean all the filters be for hand good luck
1helpful
Why the coffee is not coming out of coffee spout?
  1. If you can get steam/water from your steam spout.
  2. Fill your tank and add descale solution.
  3. Descale according to the instruction for the unit.
  4. After descale and rise are complete refill your water tank.
  5. Your system should now work as normal.
Note: If you do not have a descale solution, run the above with just water. Remember to descale when you obtain a descale solution.
Need a descaler
instractions are from manual HD7810/00
Use the correct descaling agent
Only citric acid-based descalers are suitable for descaling the SENSEO
machine. This
type of descaler descales the machine without damaging it. For the correct amount,
see under 'Descaling procedure' below. Each descaling mixture can be used only once.
After use, the descaling mixture is no longer active.
We advise you to use the special SENSEO
Descaler (HD7012/HD7011/HD7006).
Read the instructions on the package of the descaling agent.
Never use a descaling agent based on mineral acids such as sulphuric acid,
hydrochloric acid, sulphamic acid and acetic acid (e.g. vinegar). These descaling
agents may damage your SENSEO
coffee machine.
Descaling procedure
1 Mix 50 grams of citric acid with 1 litre of water in a measuring jug. Stir until
the powder is completely dissolved.
2 Fill the water reservoir up to the MAX indication with the descaler mixture.
Then put the water reservoir back into the coffee machine. (Fig. 3)
Note: Not all SENSEO
machine types have a water reservoir with a capacity of
1 litre. If you have a SENSEO
machine with a smaller water reservoir, repeat steps
2 to 6 with the remainder of the mixture without filling the water reservoir up to
the MAX indication.
3 Press on/off button 3. (Fig. 10)
The machine is ready for use when the indicator light lights up continuously.
4 Place the 1-cup holder h with a used coffee pod in it in the coffee machine.
Close the lid and make sure it is properly locked.
Note: Always put a used coffee pod in the pod holder when you descale the
machine. This pod serves as a 'filter' to prevent the sieve or hole in the pod holder
from getting clogged with scale residue.
5 Put a bowl with a capacity of at least 1500ml under the spout to collect the
descaling mixture (Fig. 8).
6 Press the 2-cup button hhand let the machine operate. Repeat this until
the water reservoir is empty. (Fig. 25)
Never interrupt the descaling process!
7 Repeat steps 1 to 6. Replace the used pod with another used pod to filter out
the scale residue.
Note: To descale properly, you have to use 2 litres of descaling mixture.
Never descale the SENSEO
coffee machine with the lid open. Make sure the lid is
properly locked.
8 Rinse the water reservoir with tap water. Fill the water reservoir up to the
MAX indication with tap water and repeat steps 3 to 6.
Note: Do not refill the water reservoir with used hot water or the used descaling
mixture.
9 Fill the water reservoir with fresh tap water up to the MAX indication again
and repeat steps 3 to 6 once more.
Note: Always rinse the machine by letting it empty two full water reservoirs.
10 Remove the used pad and clean the pod holder after descaling to prevent the
sieve or hole in the centre from getting clogged.
1helpful
My de longie coffee has been descaled only once in over 12 months when the descale light come on .. It has not come on since and I am sure it should be descaled now . How can I start a manual descale ?
Depends on how many times you have used it, before descale light comes on. Might not be able to manual descale, read instructions. You can buy Descaler Solution from all Supermarkets, but if unit working OK, leave it for a few Months, and see what happens..
Descale how do you descale ?
Check out this tip about how to descale your Keurig coffee brewer
How to Descale your Keurig Coffee Brewer
heatman101
The machine says to descale _ How do I do that???!!
THIS INSTRUCTIONS ARE FOR THE MIELE CVA 615,
The coffee system must be descaled regularly. The time period depends on
the water hardness set. The appliance will display a reminder message and
will eventually lock if not descaled. The message window will first display:
"DESCALE AFTER COFFEES: 100".
This message will appear until the appliance is descaled or locks. When
the count is down to zero, the appliance will lock and the message
window displays: The appliance can only be used again
once descaling has been performed. Let the machine cool before
descaling. Remove the sleeve of the steam nozzle to avoid damage from
the descaling agent. Only use the enclosed descaling tablets for descaling.
The descaling tablets are specially designed for descaling this coffee
system. Other agents may damage the machine and affect the taste of
the coffee and hot water. The descaling tablets can be purchased
from Miele.
To prevent damage to the exterior of the machine wipe up any descaling
solution spills immediately! Add 2 liters of water to the water tank. Dissolve two of the enclosed
descaling tablets in the water.
^ Close the water tank and insert into position.
^ Close the door. The descaling will take place in the
automatic descaling program.
Automatic descaling
^ Turn the program selector
counterclockwise to the "Program
mode" position.Press e, to select "Descaling" with the asterisk. Press ENTER.
1helpful
Burnt smell is coming from steamer wand
Boiler is contaminated with milk, check the water from the tea valve, if it smells the same or has swimmers, boiler needs to be descaled, if no floaties then removes steam wand and soak in purocaff for a few hours, then clean. Always flush ssteam wand before and after every drink.
No mac driver?
Check here for MAC compatible cameras.
Manufacturer/Model Driver version Platforms Meets requirements
3com Home Connect 6.6.4 Windows 2000, Me, 98 Yes
Apple iSight (Firewire) Firmware 1.0 Mac OS X (Pantder) Yes
BTC PC 380 Intel 3.20.1001.0 Windows XP Yes
Creative WebCam Go Plus 1.0 Windows XP, Me, 98 Yes
Creative WebCam (WDM) 1.0.11.131 Windows Yes
D-Link USB WebCam(DSB-C100) 0921 Windows XP, 2000, Me, 98Mac 9.2 and 9.1 Yes*
IBM Ultraport Camera 2 Most Current Windows 2000 Yes
Intel Deluxe PC Camera 1.0 Windows XP, 2000 Yes
Intel Easy PC Camera 1.0 Windows XP, 2000, Me, 98 Yes
Intel PC Camera CS 110 6.0.0.62 Windows X Yes
Irez Kritter USB 1.02b4 Windows 2000, Me, 98,Mac 9.1 Yes*
Irez StealtdFire 1.2 Mac 9.2, 9.1, 9.0.4 Yes
Logitech ClickSmart510 7.0.0.1221 Windows Yes
Logitech QuickCam traveler 6.0.1 Windows 2000 Yes
Logitech QuickCam Web 6.0.1 Windows 2000 Yes
Logitech QuickCam Express 6.0.1 Windows 2000 Yes*
Logitech QuickCam Pro 3000 6.0.1 Windows XP, 2000, Me, Mac 9.2 and 9.1 Yes
Logitech QuickCam VC Windows - 4.1.5 Macintosh - 2.1.2
Windows 2000, Mac OSX, 9.2, 9.1, 9.0 Yes
Logitech QuickCam Zoom 8.0.3.1110 Windows XP Yes
Orange Micro iBOT Pro Firewire 4.10.22 Windows 2000, Mac OS X and 9.2 Yes
Veo Stingray 5.0.0.0 Windows XP, Me, 2000, 98 Yes
Copy this site and paste it in your web browser address bar and hit ENTER todownload the MAC drivers macam version 0.9.2 (current version)
for Logitech Quick Cam.
http://webcam-osx.sourceforge.net/downloads.html
Then to use it on the Web, do this.
Web Camera's have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype (http://www.skype.com/intl/en-gb/download/skype/windows/beta/downloading/ )
set it up as follows:
Go to Tools, then Options, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
Then click on the Video Settings.
The camera, if Installed Properly, it will come up and show a video picture.
Then, on the bottom of the page click save.
The camera and audio should function properly. Your friends and Family will now be able to see and hear you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger (http://www.soft32.com/download_30.HTML )
I have just bought this webcam for my mac but seems unable to set up
A. Skype Setup:
B. Yahoo Setup:
1helpful
Installing Buffalo Webcam on Mac
Hope this helps. Bud
Nuova Simonelli Mac 2000 Espresso Machine Logo
Top Nuova Simonelli Coffee Makers & Espresso Machines Experts
Pierre Laplante
Harrie
ADMIN Canada
ADMIN Canada
Are you a Nuova Simonelli Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
