Question about Air Tools & Compressors
Maintenance tanabe compressors
Lubricant-substitute for Mobil Rarus 427 for lubrication of Tanabe compressor (emergency only, no compressor oil on board of the ship). Is it possible to use for short period of time system oil SAE 30 TBN 6 or hydraulic oil VG 100? Please kindly advise
J Rosado
  • 1,201 Answers
Looks like a four years old thread. Compressor oil has no detergent while engine oil does. I would use SAE 30 and not hydraulic fluid
Posted on Aug 17, 2018
sherlywang
    Master:
  • 425 Answers
Hydraulic oil can not be used as lubricant oil.
1. Hydraulic oil is mainly used in all kinds of hydraulic oil systems. Its viscosity grade is determined by the working condition of hydraulic system. The additives used are anti-oxygen, anti-rust, anti-wear and so on, which are quite different from internal combustion engine oils. Therefore, we must not use hydraulic oil as oil.
2. In the field of application, hydraulic oil is mainly used in the field of industrial lubricating oil, while oil is generally used in the field of automobile, which is some difference in the field of use. From the external color point of view, the hydraulic oil color is generally golden transparent body, while the oil is relatively blue in color.
3, from the point of view of manufacturing, the general hydraulic oil is a semi-finished oil, they have a remarkable characteristic of high pressure resistance, the manufacturing process is slightly worse than the oil. One of the most remarkable features of oil is lubrication. The internal microstructure of oil is smaller than that of hydraulic oil, and its viscosity is generally higher than that of hydraulic oil.
https://www.dieselgeneratortech.com/generator-sets/How-To-Choose-Lubrication-Oil-For-Diesel-Generator-Set.html
Posted on Aug 15, 2018
5 Related Answers
John Trevino
  • 1420 Answers
SOURCE: overheating? burnt oil smell
There is a seal between the compressor and the motor that in failed condition will leak oil into motor windings causing burnt oil smell. Some hitachi compressors suffered from failed valves or head gasket causing extra heat but not oil smell. These compressors also have a thermobreaker built into the windings that when failed will prevent motor from starting or would start and run for only a few moments then open. This part is not replaceable. enjoy
Posted on Nov 29, 2008
Anonymous
  • 65 Answers
SOURCE: owners manual ruined. what type of oil do i fill w before use
you should be able to find the manual online if it's available if not Sears would I'm sure be able to tell you.
Posted on Dec 20, 2008
hgpilot
  • 82 Answers
SOURCE: HUSKY PRO AIR COMPRESSOR 30 GAL I NEED TO KNOW HOW
Depends on what plan it was made in...
If you have the glass type sight... Only to the max you can see (top of site), then run it for a few mins, let it sit for a few more mins then add more if the level is near the bottom of the sight glass.
If it's the dipstick model that pushed in, there will be an upper and a lower level mark (holes, or checkered section) Keep it between the top and bottom marks.
Finally if it's the older screw-in type, remove the dipstick and wipe it. Set it back in BUT don't screw it in. Keep within the range on the dipstick from that position. Then of course screw it back in/
Good luck
Posted on May 08, 2009
Anonymous
  • 41 Answers
SOURCE: My Hitachi EC12 builds pressure, shuts off, then air escapes
the problem is in the check valve where air enters the tank.when leaking it lets air pressure up to the air piston causing the motor to stall upon restart.replace check valve.average cost of part 15 to 30 dollars.simple fix
Posted on Mar 30, 2010
Anonymous
  • 3 Answers
SOURCE: Gas/oil ratio mixture; chain oil lubricant
Call their customer service at 1-800-242-4672 there are options to choose for gas/oil ratio mixtures info.
Posted on May 26, 2010
Ingersoll rand m22
could be a few different reasons why this is happening.are you using the right lubricant?these compressors usually use a coolant type of oil.You made need a new separator filter or you have a plugged scavenger line or check valve.
Mar 21, 2014 | Air Tools & Compressors
I have a 1999 fatboy what oil do I use in engine, trans & primary?
On a '99 Fatboy, you can use H-D Syn3 20W50 engine oil in all three locations. But, you can use most any lubricant you wish as long as it meets Harley's specifications. Amsoil, Royal Purple, Mobil V-Twin, just check the manufacturer's website for compatibility. On the Evo engines, I use H-D or Mobil V-Twin synthetic 20W50 engine oil. I use nothing but H-D transmission and primary lubricant in those two locations.
Good Luck
steve
Jun 05, 2011 | 1993 Harley Davidson FLSTF Fat boy
Will ac compressor make noise when freon is low. there is a chirping sound coming from what sounds like the compressor. it has new belt , water pump, idler pulley, tesioner and alternator...
yes it can. this may mean the death of the compressor is inevitable, has been filled with the wrong refrigerant/lubricant, or it is low on refrigerant. you have to determine what type of refrigerant is needed, (usually R12 or R134) and use the correct lubricant, if the refrigerant does not have the lubricant already in it. every time a compressor is filled with refrigerant, it also needs th be filled with lubricant, and most, but not all, commercial refrigerants include lubricant. if there is a leak in your system, you can use soapy water in a spray bottle to find the leaky hose/connection.
Mar 26, 2011 | 1993 Chevrolet K1500
Noise coming from A/C Compressor, how do you change bearings?
You change the entire compressor. May not be compressor
May 10, 2010 | 2000 Nissan Maxima
Got a 79 trans am and am replacing the a/c compressor that came with no oil. have a retrofit kit that have refrigerant and oil mix together. Is that all I need or do I need to put additional lubricant in...
you will have to ad additional oil to the ac system, many use esteroil or what some call universal pag oil. get a measuring cup,dump the oil out of the old compressor and make sure you add the same amount back into the new compressor. hope that helped you!
Aug 03, 2009 | 1979 Pontiac Firebird
We have a Sullair 100 GPQ lubricant recommendation
hi mate ask the manufacturers as different compressor take different oils like im a compressed air engineer and i use rcr 32 and rcr 46 but i have never had to work on a sullair as there not common in our area
Jul 30, 2009 | Air Tools & Compressors
Air Tools & Compressors Logo
391 people viewed this question
Top Air Tools & Compressors Experts
Joe Garcia
Joe Garcia
Tom Chichester
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
