Question about Casio Fx-992s Scientific Calculator
How to compute for standard deviation?
Computing sandard deviation
5 Related Answers
Anonymous
SOURCE: how to do standard deviation on a casio fx-300 MS
http://www.geocities.com/calculatorhelp/casiofx300ms.htm
Posted on May 14, 2009
Anonymous
SOURCE: standard deviation
standard deviation
calculate mean of a data set:
1. Turn calc. on or press MODE SeTUP
2.Press 3 for STAT
3. Press 1 for VAR
4.Enter values for X column
5. WHen done entering press SHIFT 1
6.Press 5
7.Press 2 to calculate the mean
8.Press =
Posted on Sep 19, 2009
k24674
  • 8091 Answers
SOURCE: Standard Deviation
If you want to do statistics with this calculator you press [MODE][3:STAT]. You have then 8 options 1:1-var, 2:A+BX, etc.
For one variable statistics you press 1. Enter the values for the X variable in the template. Once finished you press [SHIFT][1](STAT) then select the value you want ( n, x bar , and the standard deviations (X sigma n) and (X sigma n-1).
Hope it helps.
Posted on Oct 17, 2009
k24674
  • 8091 Answers
SOURCE: FX-115ES Scientific Calculator: how to do standard deviation...
I assume you know the theory. I will show you the key strokes for 1-Var statistics and 2-Var statistics
Press [MODE][3:STAT] [1:1-VAR]. You are ready to enter values in the X column.
Enter a number and press [=]. Cursor jumps to second number to enter.
Keep entering numbers and pressing [=] till all numbers are in. Press the [=] key after the last one.
Press [AC] key to clear the screen.
Press [SHIFT] [STAT] (above digit 1.) then [5:Var]. Screen displays the statistical variables 1:n ;2: x bar; 3: x sigma n; 4:x sigma n-1.
Press the number corresponding to Referable you want, ex 1:n . The variable appears on screen. Press [=] and it will be displayed.
To display another variable press [SHIFT][STAT][5:Var][ 1,2, 3, or 4] .
- To access the sum of squares sigma x^2 and the sum of data sigma x press[SHIFT][STAT][4:SUM] then [1: for sigma x^2] or [2: for sigma x]. Press [SHIFT][STAT][6:MinMax] to access minX and maxX.
To perform 2 variable statistics you press [MODE][3:STAT] and any of the other regression options (except 1:1-Var). A two column template opens where you enter the X and Y values. When finished entering data, press [SHIFT][STAT][5:Var]. to access the different statistics. As I assumed above, you should be able to recognize what each variable means.
Posted on May 21, 2010
k24674
  • 8091 Answers
SOURCE: How to compute standard deviation given a set of numbers?
  1. Calculator must be in SD mode (standard deviation mode) :Press [MODE] [.]
  2. However, if [FIX] or [SCI] appears on display you must press [MODE][9] first.
  3. Data input always starts with [SHIFT][SAC], to clear the registers of old data.
  4. Type a number and press the [DATA] key, it is the [M+] key at the bottom right of keypad.
After you finish entering the data
Press [SHIFT] [9] (sigma n-1) to get sample standard deviation
Press [SHIFT][8] (sigma n] for the population standard deviation
Press [SHIFT] [7] (xbar) for the mean
Press [SHIFT] [6] (n) for the number of data entries
Press [SHIFT] [5] (capital sigma x) for the sum of values
Press [SHIFT] [4] (capital sigma x to y) for the sum of squares of the values
For additional information you might consider taking a look at the calculator manual
Posted on Jun 22, 2010
What is deviation standard
The standard deviation is a measure of how "tight" the samples are distributed around your mean.
In layman's terms, a small standard deviation indicates that most of your measurements are in the vicinity of the means; a large standard deviation corresponds to readings that are all over the place.
You could also say that the smaller the SD, the more your mean is representative of the data set.
For a better explanation, just look up Standard deviation on Wikipedia!
May 03, 2014 | Audio Players & Recorders
Deviation standard
For a sample this smaller size there are two std deviations. Sample std deviation s(n-1) = 0.550, and population std deviation s(n) = 0.541
Dec 22, 2013 | Audio Players & Recorders
How do I compute population standard deviation on the TI 84 plus?
Put the data into a list using whatever scheme you prefer. Press STAT right-arrow to bring up the STAT CALC menu. Select "1-Var Stats" and specify the list containing the data. You'll get a screen showing the various statistical values. The population standard deviation is designated by a lowercase sigma.
Jun 01, 2011 | Texas Instruments TI-84 Plus Calculator
How do you find standard deviation on the calculator?
Press 2nd [CSR] (shift-7) to clear the statistical registers. Use the Sigma+ key (just above STO) to enter data points. Use 2nd [Sigma-] to remove erroneous data points. Use 2nd [sigma x n] (shift-divide) to compute the population standard deviation, or 2nd [sigma x n-1] (just to the left of the previous key) to compute the sample standard deviation.
Jun 07, 2010 | Texas Instruments TI-30XA Calculator
Does this calculator comes with a standard deviation or population standard deviation button
Yes. The sample standard deviation is 2nd [sigma x n-1] and the population standard deviation is 2nd [sigma x n].
Apr 02, 2010 | Texas Instruments TI-30XA Calculator
How do you enter frequencies for finding standard deviation? For example, Frequency=50, total of X or raw scores = 366.5. Summation of X squared =2836.39. What is standard deviation? How do you enter the...
I am afraid I do not understand. The frequency of a PARTICULAR score is the number of times that particular value occurs in the data. It is not the number of data.
Ex: the data are:
4, 6, 5, 4, 4, 8, 9, 3, 3, 6, 7
Frequency of (3) =2
Frequency of (4)= 3
Frequency of (5) =1
Frequency of (6)= 2
Frequency of (7)=1
Frequency of (8)=1
Frequency of (9)=1
Number of data =11 (n=11)
You compute the mean M
M= (2x3 + 3x4 +1x5 +2x6+1x7+1x8+1x9) /11 =5.363636..
As you can see, if a term is not repeated it is multiplied by 1 (its frequency is one). Value 3 occurs twice (hence 2x3); value 4 occurs 3 times (3x4), etc.
To calculate by hand the sum of squares
3: (3-5.3636)^2 + (3-5.3636)^2 .................... = 2x(3-5.3636)^2
4: (4-5.3636)^2 + (4-5.3636)^2 +(4-5.3636)^2 = 3x(4-5.3636)^2
5: (5-5.3636)^2 ...................................... .= 1x(5-5.3636)^2
6: (6-5.3636)^2 +(6-5.3636)^2......................= 2x(6-5.3636)^2
7: (7-5.3636)^2.......................................... .=1x(7-5.3636)^2
8: (8-5.3636)^2......................................... ..=1x(8-5.3636)^2
9
: (9-5.3636)^2......................................... ..=1x(9-5.3636)^2
If I have not made a mistake the sum of squares is 40.5454
Standard Deviation
The standard formula above gives s= square root (40.5454/10) =2.01
Population Standard Deviation
The population Standard deviation above is S= square root (40.5454/11) =1.9198
So if you perform the calculation with the calculator the only times you need to enter the frequency is for repeated terms. When you have to enter 6 above, its frequency is 2 you proceed as follows
6 [2nd][FRQ] 2 [Sigma+]
Once you entered the raw scores, the calculator does the rest.
Hope it helps.
Nov 06, 2009 | Texas Instruments TI-30XA Calculator
Jan 15, 2009 | Casio FX-260 Calculator
Standard Deviation
I want to calculate a standard deviation on BA II plus
Apr 23, 2008 | Texas Instruments BA-II Plus Calculator
Maths & statistic
Standard deviation is the average root mean squared deviation from the average of the numbers.
Familiarize yourself with the wikipedia page on standard deviation: http://en.wikipedia.org/wiki/Standard_deviation
In this case, your question is easy. The standard deviation is 0, so this means the boys ages are all the same.
So they're all 24/3 = 8 years old.
Proof:
8 + 8 + 8 = 24 <-- satisfies the constraint that the boys ages must total to 24.
Get the standard deviation of these numbers;
8+8+8 / 3 = 8 <-- the average value is 8
The deviation of each boy's age from the average is:
boy 1
8 years old, which deviates from 8 by 0
boy 2
boy 3
So the deviations are 0, 0 and 0.
To get the standard deviation, you sum the squares of the deviations of each boy, get the average, and square root. So:
0² + 0² + 0² = 0
Average is 0 / 3 = 0
Square root of 0 = 0
So the standard deviation is 0. Which shouldn't be much of a surprise to you. We just had to actually DO the work to show that it was in fact 0.
Feb 08, 2008 | Audio Players & Recorders
Standard Deviations
This calc will do standard deviations. In the manual it is on page 2 and also on page 40.
Sep 07, 2006 | Casio FX-7400G Plus Calculator
Casio Fx-992s Scientific Calculator Logo
37 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
Marvin
Marvin
Carlo Barzo
Carlo Barzo
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
