Question about Refrigerators
Stuck defrost mode - Refrigerators
Posted by melvin respress on
Paul G
    Scholar:
  • 161 Answers
On the back of the fridge bottom left or right leg at the rear there should be a white knob, turn this until it starts then leave it , if it happens again you will need to replace the defrost timer.
Posted on Jan 11, 2014
Selector for air mode stuck on defrost
This is caused by a low engine vacuum, the engine vacuum is low when you accelerate, the HVAC system loses vacuum to the mode control vacuum switch and defaults to the defrost ducts for safety. You likely have a leaking mode control vacuum switch in the control panel of the heater AC system (HVAC).
Jun 16, 2016 | 2001 Ford Windstar
Why a Frigidaire freezer seems to be stuck in defrost model number LFFU17F5HWC
Good Morning Friend,
I understand that your Frigidaire freezer, model# LFFU17F5HWC, seems to be stuck in a defrost mode. Your freezer is supposed to automatically defrost for 30 minutes after every 12 hours of compressor run time. I suggest resetting your appliance, be either unplugging it or shutting the power off at your homes circuit breaker, for 3-5 minutes. Restore power and watch to see if it is still stuck in defrost mode. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your washer status has changed successfully. Hope this is helpful.
-Best Regards-
WP
May 24, 2014 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Fridge and freezer both not cooling
Yes , your fridge can get stuck in defrost mode. If you can locate the thermostat. Sometimes buried behind a panel in the freezer. There's an adjustment screw or trim screw that allows you to advance the timer on the thermostat. Sometimes they stick in the defrost mode. It may happen once and never happen again. If however it does continue you will have to replace that part.
Oct 28, 2017 | Amana Refrigerators
Defrost is stuck in one all time it not cooling or freezing
A DEFROST TIMER is a cycling device, it times the frequency and duration that the defrost heater coils melt the ice that builds up around the evaporator coils. If ice is allowed to build up, air will not be able to freely flow past them - resulting in reduced efficiency and sometimes a drastic warming of the cooling unit.
Most of the time, the defrost timer is in the cooling mode, allowing the compressor to activate when the thermostat signals it to. The remaining part of the cycle (usually less than 30 minutes)the timer is in defrost mode. In this mode, it signals the defrost heaters to melt the ice build up on the coils. This defrost action is limited by the defrost thermostat. If your DETROST TIMER go to bad, one symptom would be if your refrigerator is not cooling. Although there are many causes of this symptom, A stuck defrost timer can be one of them. The timer can get stuck in cooling (compressor activated) or defrost mode (defrost heaters activated) for usually two reasons:
- The timer motor can fail for one.
- The gears can also become locked up.
No matter what the reason is or which mode the defrost timer gets stuck in, the refrigerator can stop cooling. When the refrigerator is stuck in defrost mode, the compressor no longer comes on to cool the unit. If the timer gets stuck in cooling mode, the evaporator coils never get a chance to defrost, causing ice build-up to the point where there is a complete blockage of airflow past the coils.
The defrost timer can also cause the refrigerator to stop cooling due to failure of the internal switch which activates either the compressor or heater coils. Finally, when doing any repair on a refrigerator, check the condenser coils for dust buildup and clean accordingly.
According woth yur brand and model, look the part replacement in this link: partselect.com/refrigerator+test-defrost-timer+repair.
Good luck.
Jul 16, 2011 | Refrigerators
Wiil not cool
If the heater is geting hot and not cooling sounds like it is in the defrost mode just defrosting or stuck in defrost mode.If it is in defrost mode it should stop defrosting after a while and start cooling. They defrost every so many hours depending on how they are set.
Jul 16, 2010 | Dometic RM2852 Refrigerator
Refrigerator is stuck in defrost mode.
If the compressor is running and not getting cold I would say that you have burnt out your compressor.
If it was stuck in defrost you wouldn't hear the frig running. When in defrost the compressor stops while the frig defrosts.
Dec 29, 2009 | Refrigerators
Stuck in defrost mode after changing timer and thermostat
Amana adaptive defrost:
Press refrigerator light switch five times in six seconds to initiate defrost cycle. Pressing five more times within six seconds will cancel defrost and go straight into the run mode. Similar operation on both bottom mount and SxS refrigerators. After the defrost terminator/thermostat opens, six minutes of dwell time occurs before the compressor and condenser fan motor will operate. After defrost terminator/thermostat open, 10 minutes of dwell time occurs before the evaporator fan motor will operate.
May 05, 2009 | Amana 25.8 cu. ft. Side-by-Side...
Gets stuck in defrost cycle, new thermostat already fitted
If you would like to stop the defrost timer from intermittently causing this, the defrost timer will need to be replaced. It's a simple part to replace and not expensive. Thanks, Sea Breeeze
Apr 27, 2009 | Refrigerators
Kitchenaid refrigerator not working
it would not be likely to stuck in defrost mode but my guess would be the compressor is not running. overheated or the condenser is full of dirt. as you said , you can hear fan running, is it inside the ref or outside?..or both?..if that is the case, then it is on freezing mode because the fans would not run on defrost mode..i hope i was able to help..
Jul 05, 2008 | True T-49 Side by Side Refrigerator...
Freezer/fridge fan not turning
if the unit is stuck in a defrost mode you eould have no cooling things in freexer would be defrosting quickly
Mar 13, 2008 | Refrigerators
Refrigerators Logo
82 people viewed this question
Top Refrigerators Experts
Marvin
Marvin
john h
