My ac & heat stopped working at the same time. My vents blow air, but in the summer it was blowing out outside temp air and now in the winter my heat is blowing out cold air. Help please.
SOURCE: 2004 kia sorento no heat
I had a similar problem with AC & Heater fan,it works on and off, and sometimes if the road was rough it runs, So I had to remove the fan clean it with a blower from dust and debris, then I installed it back and it is running ever since for more than a year without having to replace it.
SOURCE: air conditioner started blowing hot air
your a/c compressor is not working.
you have to have the system checked by an air conditioning place or the dealer as to what the cause is.
SOURCE: my kia sedona van only heats up for a minute or
Check the metal part of the heater core lines at the firewall if you can get to them and see if one side is noticeable colder than the other. At least one of them should be hot or you have a bad thermostat. If both are hot than your hot/cold actuator inside is having a problem
SOURCE: my kia spectra was making a loud squeeling noise
Look at the AC pump. See if the belt is there, slipping, or the pully clutch engaging.
The center of the AC pully can be standing still while the outside turns. There is supposed to be a magnet that grabs the outside and locks it to the inside when you turn the AC on. The magnet could be bad or its clutch slipping.
NO HEAT ON FLOOR VENTS
As
per your problem mentioned. There are few solved help links to
troubleshoot these problems. Go through the list and Click the link below:----
http://whatisbyme.blogspot.in/2012/05/2000-toyota-avalon-no-heat-on-passenger.html
http://schematicsdiagram.blogspot.in/2012/02/heater-blows-cold.html
http://repairhelpcenter.blogspot.com/2012/01/hot-air-on-drivers-side-vents-only.html
http://technoanswers.blogspot.in/2012/04/1992-toyota-camry-ac-control-light.html
http://technoanswers.blogspot.in/2012/02/no-heatblower-blows-only-cold.html
http://whoisbyme.blogspot.in/2012/06/2009-mercury-grand-marquis-ac-blows.html
http://schematicsdiagram.blogspot.in/2012/04/ac-not-blowing-through-vents-on-2007.html
http://schematicsdiagram.blogspot.in/2012/04/passenger-side-temperature-is-warm-air.html
These
will help.
Thanks.
As
These will help.
Thanks.
