Question about Compaq Armada 1700 Notebook
Blank screen problem witn presario v5000
hey guys can any one help me got this presario v5000 and it wont display anytyhing but a blank black screen upon booting what can i do pleaseeeeeeeeeeeeeee some come to my aid.please if you have got any suggestion that can help my situation please forward it to my inbox Vis [email protected] or [email protected] you could even beep me on 234-802-614-4703 . i will be eterenally indebted to you if you can help me
                                              THANKS
  • 3 more comments
  • salvenx Oct 20, 2007
                                                  THANKS
  • salvenx Oct 21, 2007
    thanx beni but i have got no spare screen am in a remote village away from the city wat else can i do and even when i do get thge spaare what am i supposed to change at the config
  • Tina Jansen
    Tina Jansen Dec 11, 2007
    any manuals out there that show how to take this machine apart. I have every screw taken out, but it still won't come out. I have a pale blue screen. Nothing else shows. I can get it to boot to restore, using an external monitor. Any ideas? Any links to a service manual?
    thanks
  • Anonymous Jan 18, 2009
    i got the same problem too, i was watching some videos then it crashed. soon after the hard reset whenever the laptop's power has been put to on, the screen shows absolutely nothing even if power has been put on. The power light is on, hard drive light blinks from time to time but that's about it
    halp please
  • Anonymous Apr 14, 2009
    i have blank screen problem, when i turning on the laptop ,there is nothing on the screen (dark screen) ,the system is loading, and computer working fine only blank screen . help me please
Remove HD (optional, just in case u shake up the unit too much),
(i)
Remove battery,
remove 2-3 screws found in the battery comparment
(ii)
Pry up the keyboard bezel/power button cover by accessing slots above F2 & PAUSE keys,
it will feel extremely tight but work it a little,
try not damage your keyboard (try and pry/separate the back of the cover first).
(iii)
Look top-left,
u'll see a cable leading from the motherboard to the display
(iv)
CAREFULLY unplug the white connector and replug FULLY FULLY.
PLEASE pry and push the white connector housing ONLY not the fine wires.
THAT SHOULD BE IT!
If not i can take u to more advanced testing with meter and probes.
Posted on Nov 21, 2007
Its your light inverter it need replaced if you can you a monitor to boot into that bios then you need a new light inverter you can get one on ebay for really cheep
Posted on Oct 01, 2008
  • 1,006 Answers
Put another monitor and go to the display settings settings advanced and there u can configure display settings! and it will be fixex if u dont have problem with monitor
Posted on Oct 21, 2007
6ya staff
SOURCE:
I have a compaq presario v5000 that gives me white screen help!!?
have you remembered to reconnect that small wire under the screw on the hinge?
hope this helps
Jun 06, 2010 | Compaq Armada 1700 Notebook
My screen stays black when you turn it on. model HSTNN-C17C which is located under the battery. Presario V5000
This isn't a desktop PC by the way. Do any of the lights come on? If not, try to run the laptop from the AC power. If the lights come on but no display, then your backlight or inverter on the LCD panel for your V5000 might be bad.
Oct 08, 2009 | Compaq Presario 5000 PC Desktop
My compaq presario v5000 a 5240NR was working fine
Fn+F1 Decreases the display brightness. Fn+F2 Increases the display brightness
Oct 01, 2009 | HP Compaq Presario V5000T Notebook
Compaq Presario V2000 laptop wont boot
hi it seems that ur mother board has been damaged.. and immediately u should go for replacement....
thank u!!!
Apr 09, 2009 | HP Compaq Presario V2000 Notebook
Function f4 key in B&W
You need to update the software comes along with your preserio v5000. Try to install the software again from the CD.
Jan 20, 2009 | Compaq Presario 700 470024-192 Notebook
Compaq presario v5000
Boot into Setup and run the TOOLS / PRIMARY HDD TEST / SHORT TEST.
If it fails, try another HDD.
If OK, verify Boot Order is Floppy, CD-ROM, HDD. Exit Setup.
Print Table 1 Low Level Format instructions from http://support.microsoft.com/kb/106419
Boot with a DOS disk that contains Debug. Run the Table 1 script. Turn V5000 Off.
Boot with the HP Operating System CD. XP install should now proceed normally.
Good luck.
Sep 12, 2008 | Compaq Presario V5005us Notebook
This will not kill your computer don't worry.
What would be mt suggestion for you, please get your presario v5000 reimage with all the drivers.
Thanks
Aug 25, 2008 | HP Compaq Presario V5000Z Notebook
Could be a stuck key somewhere, has anything been wasted on the keypad, tap the keys one by one to refresh is. Could also be that the keyboard is broken.
Fixya me ... thanks!
Feb 20, 2008 | Compaq Presario 2170US Notebook
Compaq Armada 1700 Notebook Logo
4,006 people viewed this question
Top Compaq Computers & Internet Experts
Ekse
Thomas F. Schneider
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
