Question about Canon PowerShot A80 Digital Camera
CANON POWERSHOT A80
There is total discolouration in all my shots ,I have read it might be the CCD and could be the fault of canon.I have the camera for about five years but didn't realise when this happened about two years ago that it was the sensor and was accepted by Canon as a free fix ,is it too late to get it done by Canon
5 Related Answers
Anonymous
SOURCE: canon powershot g3
a common problem is with the 'optical unit' shutter control part.
have to replace the 'optical unit'
Posted on Jan 31, 2008
Anonymous
SOURCE: CANON FAULTY SCREEN IMPORTANT READ ME
Only for the brave, on a warrenty expired camera.
Buy a set of jeweller's screwdrivers.
Make sure it is off, with the lens retracted, and remove the battery and SD card.
Remove the 11 screws holding it together
The metal shell is in two halves that can be pulled apart. The rubber socket cover flap has to be removed once one half is off. A rubber gasket round the eypiece lens may drop off - it is easily replaced.
Hold the inner chassis by the edges.
The lcd screen is held by one screw, half hidden under the wiring to the flash - remove it.
Push the wiring to one side just sufficiently to enable you to hinge the lcd screen up on its flexible printed circuit wiring loom.
Underneath you will see the back of the ccd pod, with a flexibe printed circuit wiring loom pinioned under a metal plate with two Y shaped holes filled with brown gunk, and held down by a torex screw locked with some holt melt adhesive, and two further screws inaccessible under the metal chassis to the right.
I hypothesised these were the contacts that become detatched in hot conditions, and (1) tried to shift the flexible printed circuit minutely from side to side using the hole in it (it didn't move appreciably)and (2) pressed down quite hard in the centre of the metal plate, having supported the chassis from below so as not to damage the lens.
I reassembled the whole thing and it worked immediately, with just a faint light smear down the left hand side of the image (the whole image had been completely smeared, then dark, before) which was only noticeable when photographing in dark conditions.
So I took a gamble and it seems to have worked. If it hadn't I was going to break the glue seal on the Torex screw and unscrew and then screw it up again.
Obviously doing this is on your own responsibility.
Posted on Oct 25, 2008
t00nz
CameraR
  • 4738 Answers
SOURCE: my Canon powershot s400 camera won't read memory card
First, remove the card, and look in the slot for any bent flash card pins. If you see any, don't fret, it's possible that you can fix this yourself. See this article on how to unbend flash card pins.
But if no pent pins are seen, then the camera's clock battery has worn out, and is likely causing this problem. Unfortunately this battery is internal to the camera. But Canon will fix this for you (for the S400 only) for free, with free shipping. Please see the Canon advisory for your camera here.
Posted on Sep 12, 2009
Anonymous
  • 691 Answers
SOURCE: Canon Powershot s60 photos have pink tint
Hello
Thank you for using
FixYa for your problem
Your camera is faulty. It should be taken to an authorized repair centre for a repair estimate. Very few digital cameras have any user-serviceable parts.
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Posted on Nov 29, 2009
Anonymous
  • 47 Answers
SOURCE: Canon Powershot SX10is All my action shots in
you should set it to a high shutter speed and f/stop also set your pictures to a RAW setting, if that made no sences let me know, and i'll say it abit more simple :)
Posted on Apr 22, 2010
When I turn the camera on (Canon Powershot A 80) purple and black stripes trouble the screen. The camera takes pictures anyway, but it is hard to see what photograph you make. Can anyone help?
This is known problem of ccd imager chip failure in Canon A80 camera and ccd imager chip will be replaced to fix picture problem.
Canon offers free of cost ccd imager replacement, click Canon CCD Imager Advisory for details.
Thanks.
Feb 04, 2010 | Canon PowerShot A80 Digital Camera
Canon A95. Image on screen flashes and is discoloured. Photo same
It sounds bad ccd image chip in your Canon A95 camera and ccd imager chip will be replaced to get correct live view in camera mode.
Canon offers free of cost repair for said problem, click Canon CCD Imager Advisory for details.
Thanks.
Dec 26, 2009 | Canon PowerShot A95 Digital Camera
Cannon PowerShot A80. Pictures come out with red tint and what appears to be horizontal lines across complete image. However, record video without problem.
If camera shows previously taken pictures in playback mode and does notshow live view to take fresh pictures then it is ccd imager chipfailure. CCD imager will be replaced in your Canon A80 camera.
Oct 27, 2009 | Canon PowerShot A80 Digital Camera
I have a canon A80 AiAF. Sreen Problems
Its known problem of CCD Imager in Canon A80 camera and Canon will repair it free of cost.
Click Canon CCD Imager Advisory for details.
Jul 19, 2009 | Canon PowerShot A80 Digital Camera
When I turn on the canon power shot a80 the screen is distorted and I cannot look at or take images.
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
Jun 06, 2009 | Canon PowerShot A80 Digital Camera
Canon Powershot A80 LCD problem
Jan 22, 2009 | Canon PowerShot A80 Digital Camera
My Canon PowerShot A80 has a metering problem I think
Your Canon A80 has problem of defective CCD Imager Sensor and this part need to be replaced.
Good news is that Canon will replace CCD Imager free of cost as per announced free of cost repair scheme.
Click on Canon CCD Advisory for details how to obtain free repair facility.
Good Luck.
Nov 06, 2008 | Canon PowerShot A80 Digital Camera
Powershot A95 ccd problem
This sounds like a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
Dec 14, 2007 | Canon PowerShot A95 Digital Camera
Light Metering Problem on Canon A80
Dec 10, 2007 | Canon PowerShot A80 Digital Camera
Canon PowerShot A80 Digital Camera Logo
Top Canon Cameras Experts
old marine
old marine
halotheracer
halotheracer
Steven Wander
Steven Wander
Are you a Canon Camera Expert? Answer questions, earn points and help others
