SOURCE: maxi cosi car seat cabriofix
What seems to be a sewn-up loop, is actually easy to unattach, but the trick is not explained in the manual.
Where the end of the strap seems to be holding to the seat's plastic shell, the plastic is not completely connected, there is a break in the plastic. Just move the strap left/right a bit and you will see that you can unattach it there. Then you can unthread the loose end of the strap and completely remove the cover.
Credits for this go to my wife who figured it out after I already thought we should return the seat to the shop. :p
SOURCE: Finding a replacement cover for MAXI COSI PRIORI XP/FIX CAR SEAT
no but you can try this ebay store they sell covers
http://stores.ebay.com/safe-your-kid
or contact the manufacture with model number and date of manufacture they can get you one. this would be the cheaper of two options
SOURCE: maxi cosi belt protectors
The supplier to John Lewis, Dorel, will ship the maxi cosi loose belt protectors out to you at a cost of £10.
Contact Dorel at:
http://www.dorel.co.uk/contact-us/
Alternatively, call your local John lewis branch and they will be more than happy to contact their suppliers for you.
I called mothercare, and they were not too helpful - the fobbed me off and said call halfords or John Lewis.
SOURCE: Where to get a maxi cosi sun canopy from?
hi if the car seat you have is the cabriofix it already has sun shade, if you look on the back there is a button under the rim at the top ( on mine the button is silver ) hope this is helpful
SOURCE: how do i remove maxi cosi car seat cover for washing please
hi bodsierpa..hope this helps..good luck!!!
• First remove the belt pads.
• Open the rim at the sun canopy as far as possible
• Remove the cover from the hooks
• Remove the cover then from under the hooks and quick adjuster button
• Pull the buckle tongue sections and adjustment strap through the openings.
