Panasonic KX T7633 user manual pdf
the link above is the manual
The Panasonic KX-T7633 is a telephone that will satisfy your demand for a user friendly operation. You can enjoy the hands free conversations offered by the speakerphone facility that the Panasonic KX-T7633 features. The 2.5 mm headset jack that you will find in this Panasonic KX-T7633 phone will enable you a hands free usage for paperwork or PC. It has a 3 line LCd that gives you a readable and clear display. It is available in charcoal and white color. This phone gives you an opportunity to choose the right color that will go along with the d?cor in your home or office. This device looks professionally because of the executive design. The Panasonic KX-T7633 has 24 programmable keys with dual color LED. It also has a 3 line caller ID LCD with back light. You will love the headset jack. It supports caller ID. The Panasonic KX-T7633 has a speakerphone, Intercom, automatic redial and an LCD display. There is a chance for 8 way conference call. It also features a digital XDP (eXtra Device Port) jack. I warmly recommend this phone for your home or office. You will be extremely satisfied. Panasonic phone models are very durable and you can use it for years to come. It will serve well to your every wish. Before using the Panasonic KX-T7633, it is recommended to read the Panasonic KX-T7633 user manual. If you have lost yourmanual, you can always download one here, free of charge: DOWNLOAD PANASONIC KX-T7633 USER MANUAL PDF
Panasonic phone systems display can be changed by hitting the * or # while on hook to show various options .. good luck
SOURCE: Panasonic KX-T7456 Corded Phone - Date & Time Display
The display on the phone ... to change back and forth between the date and time,
and the extension information, press the "star" (or asterisk) key while
the phone is on-hook, this will toggle the display back and forth.
Hope this helps, David B.
SOURCE: Panasonic KX-T7730 Corded - change display
On mine I press the asterix to toggle display options
SOURCE: Change home screen display
Press the * key to switch back to date and time. Also, the SHIFT button on top will change the STA EXT FEAT.
The only way I know of changing the name is in the main phone system.
SOURCE: Changing names assigned to extension numbers
I just worked it out.
Press Program
Then **
followed by your passcode (usually 1234)
Then 004
Then press next till you find Mark
Press Shift then the button under Clr
Then enter the name so for Claire start with 2 and swing the jog button round till you get a C, then press 5 and swing the jog button round till you get an l etc..
If you make a mistake press Transfer
Then when you've got your name correct press Auto Dial.
SOURCE: KX-T7730 Time and Date
Walk up to the phone and don't touch anything but the * button. Keep pressing it and watch the display. Now you now the 3 states of the button.
Carl
when i press either the * or # key on my phone it only comes up with the options to "prog", "left arrow" , clear, or store - there is no information about switching from what I have to date and time
