SOURCE: dryer makes a thumping noise when drum is turning
Sounds like you have flat spots on your drum rollers.
If your machine is a front loader, remove the front of the machine, this will expose the belt and drum, remove the drum and belt, and this will expose the drum rollers.
Check the rollers to see if they have flat spots on them, if they do replace them with new ones. This should solve your thumping noise.
If the rollers do not have flat spots on them then you can try to lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil.
I hope this helps
SOURCE: My dryer will not start. When I push the star
Open the door, push in the door switch, press the start button and rotate the tub with your hand. If it starts running you have a bad motor. BE CAREFUL and this is obviously easier with 2 people but is possible with 1. Thanks for rating me after you view this.
