Question about Braun Thermoscan Pro 4000 Ear Thermometer
3 lines indicating low battery but new batteries installed
Karen Lynn
    Habit-Forming:
    New Friend:
  • 83 Answers
I think you can have a try with LEO Privacy app. It can speed your phone and hide your stuff: LEO Privacy Applock Hide Safe Android Apps on Google Play
Posted on Jan 18, 2017
Why doesn't the new installed battery help?
Question about Nortel T7406e Cordless W/base - Nt8b45aaap
But is not charging - as soon as the cahndset is removed from the charger, it indicates low battery, then will power off
Jul 10, 2014 | Nortel T7406e Cordless W/base - Nt8b45aaap
Err access issue
The battery indicator will flash and/or the IC recorder will display the error ACCESS when the batteries are low. Install new, fully-charged batteries to resolve this issue.
NOTE: Be sure to install the type of batteries specified in the user manual.
regards,
Bilal
Oct 09, 2013 | Sony IC Recorder
1998 Ford Explorer Low Battery/Voltage Reading
Bad alternator you should have about 14.7 volts at idle with a new alternator.
Nov 02, 2012 | Ford Explorer Cars & Trucks
JUST PURCHASED NEW CAMERA, PUT NEW BATTERIES IN AND AFTER TAKING JUST A FEW PICS, BATTERY LOW INDICATOR CAME ON AND SAYS IT NEEDS NEW BATTERIES. PUT NEW ONES IN AND AGAIN, BATTERY LOW INDICATOR CAME ON. ...
yes, The Flash mode consumes LOT of power, thats why it needs lot of batteries, use " rechargable batteries", or use camera without FLASH, and use GOOD QUALITY battaries
Jan 22, 2011 | Canon PowerShot SX100 IS Digital Camera
My scooter has a code 31 that says has to be cleared before it will run. we were gone for several months, whe nI came home we charged it up but won't start has a code 31. Book says it has to be cleared to...
Sounds like you need new batteries. This code indicates a low battery condition.
If you have a digital voltmeter measure the voltage of each battery. Above 13 volts is best, 12 volts indicates a 50% charge. The total voltage when you add the two batteries together needs to be above 17 volts for the electronics to work.
Batteries that sit for several months may not take a charge. You can try charging them separately with a car charger set to gel/deep cycle setting to bring the voltage up. Make sure they are disconnected from the scooter and do this only for a short time, keeping your eye on them. The batteries may be too old and the plates sulfated by sitting too long.
A new set of U-1 batteries is my best recommendation. They are available locally and on line at a discount. If you install them your self you could save over $100 on the labor cost alone.
To clear the code install the new batteries and turn the scooter off and on. The code will clear itself when you disconnect the batteries. Charge the new batteries fully before use. Hope this helps.
Dec 08, 2010 | Pride Mobility Victory 3 Wheel Electric...
Low battery indicator with new batteries
Dear friend please go in setting option on your camera and select your battery type there. after that restart your camera. The indicator will stop showing low battery. But also confirm that your new battery are fully charged. Waiting for your feedback.
Jan 30, 2010 | Pentax *ist DL Digital Camera
The low battery icon started coming on after I was at the car wash and my 1yr turned on all the lights and the radio was on. needless to say I needed a Jump to get home. Then the low battery indicator...
Initially and based on your description, it is doubtful if the problem is "shortage or fuse related". To my understanding, your concern is that the "low battery indicator" comes on and off. This indicator although says battery is low actually indicates that the battery is not charging. And the only component in your vehicle responsible for this is the alternator. It could possibly be then that:
  1. belt is slipping (most likely); and/or
  2. the alternator is defective (either diode or regulator) (likely)
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jul 23, 2008 | Saturn Vue Cars & Trucks
Canon eos rebel t2 battery indicator
guido462:
new batteries - brand new? fully charged per spec?
Jan 21, 2008 | Canon EOS Rebel T2 with 28-90 lens 35mm...
Low battery indication
You have either a faulty charger, a faulty battery or a fault in your camera. I purchased 2 batteries for my Sony 505v and from new one of them kept flashing an empty battery sign right in the middle of the display. Actually it was fully charged but Sony batteries have a little circuit inside them which tell you how long the batteries will last. In my case I could continue to use the battery but put up with that flashing icon. I returned it to where I purchased it and it was replaced Immediately. Please ,next time give us a little more information as to what battery type it is and which camera it goes in. Some cameras can develop a natural short circuit over time. BMW
Jul 02, 2006 | Sony Cyber-Shot DSC-U10 Digital Camera
Braun Thermoscan Pro 4000 Ear Thermometer Logo
612 people viewed this question
Top Braun Home Experts
john h
Tom Chichester
Are you a Braun Home Expert? Answer questions, earn points and help others
