Question about Xerox Phaser 7750B Laser Printer
7750 toner refill
I have refilled my yellow toner on my zerox 7750 but the cartridge dose not show full what have i done wrong??
There is a metal slide on the bottom of the cartridge it needs sliding
to the out side edge of the cartridge ,so that when you when you put it
back in, the printer reads as full
Posted on Dec 11, 2008
    Scholar:
  • 78 Answers
You will need to install a genuine cartridge. the printer will continue to say the toner is low while you have the refill in the machine and there is nothing you can do about it other than replace it with a new cartridge.
Gremlin11
    Novelist:
  • 208 Answers
Most likely the cartridge has its own chip that is not resetable.
Posted on Dec 07, 2007
6ya staff
SOURCE:
Always showing toner replace
Did you replace the toner cartridge or attempped to refill it if refill the cartridge have chips on them when they are done tell the printer they are done, refill is not messing with the chip So get a new one OEM not 3rd party
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Aug 25, 2015 | Office Equipment & Supplies
I have a printer of Brother quality DCP7030..the toner life end appears on screen.but i have already refill the toner
Refilling printer toners/cartridges never show as full on the screens. Only if you buy a new toner, that will show a full cartridge.
Aug 26, 2011 | Computers & Internet
How do you reset toner counter on phaser 7750? Thanks
On the back of the 7750 toner there is a metal piece you can push in near the end that goes in to the machine first, this will tell the printer that the toner you put in has not been installed until now. I would not suggest doing this unless the toner is full and is using geniune xerox 7750 toner.. If you refill it with generic or non-7750 toner it can damage the machine and will void any warrenty you may have left on the machine.
If you switch machines with the 7750 toner the machine will not know how much toner is remaining in that toner. Xerox changed this method on the 7760 to use a toner chip to fix this.
Hope this helps, thanks
Apr 01, 2011 | Xerox Phaser 7750DN Laser Printer
Minolta 2430dl, cyan, magenta, and yellow toner cartridges all show empty. Black shows 42% remaining. How do I get printer to print?
Some printers will refuse to print _anything_, until you replace/refill _all_ of the empty toner cartridges. So, replace/refill.
Dec 30, 2009 | Konica Minolta Office Equipment & Supplies
IBM Infoprint1120 and Lexmark T520 toner cartridges.
You cannot use Lexmark toner cartridges in IBM models and vice-versa because the toner carts have a smartchip that identifies the toner to the printer. IBM printers expect to see IBM toners and Lexmark machines expect to see Lexmark toners. If you put the wrong cartridge in you will get '32' Unsupported print cartridge error.
Some refillers may swap the smartchip when they refill cartridges and this would be the only reason why you may have seen it done before.. IS your current toner a refilled one? It's technically possible to make an IBM printer into a Lexmark printer to accept Lexmark toners by replacing the System Board... but why would you bother doing that...just use the right toner.
May 19, 2009 | IBM Infoprint 1120 Laser Printer
Toner bottle does not turn to add toner
is the toner the Correct toner. If it is wrong the bottle will not Mesh with the motor
Apr 01, 2009 | Panasonic FP-7750 Black and White Copier
Brother HL-4040CN won't read or show new refilled cartridge in the LCD
I think I know what the problem is...
When you refill these toner cartridges you need to reset the "toner empty" cog wheel.
For instructions on how to do this follw this link:
http://www.proprint.co.uk/brother_hl4040.htm
It has pictures and explains how to reset the cartridge
Good luck,
Billy.
May 11, 2008 | Brother HL 1440 Laser Printer
Resetting Toner count onprint settings PRINT SETTINGS report
I don't suggest refilling cartridges as I work on printers every day but seems to me that you have done everything correctly the only thing I think you have done is either filled with incorrect toner thus giving a incorrect reading or when moving gear you have dislodged the pin that activates the reset procedure.
Thanks J
Jan 14, 2008 | Brother HL-2040 Laser Printer
Zerox 7750
Most likely the toner hopper, is bad. The auger broke or something along that ling
Oct 20, 2007 | Xerox Phaser 8500/DN Printer
Xerox Phaser 7750B Laser Printer Logo
277 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Clive
Clive
Tareq Bin Mostaq...
Tareq Bin Mostaq...
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
