Question about Mitsubishi WS-55511 55" Rear Projection Television
Mitsubishi television How do i change the red bulb in the mitsubishi tv mod # WS-55511? and where do i get a replacement part?
  • Hugo63 Oct 20, 2007
    thanks for replying. Whenever i turn on the television, it stays on for a minute, the screen flickers, then shuts off. I opened the back, turn it on then noticed that the red bulb didnt come on at all
  • Hugo63 Oct 23, 2007
    After unplugging HV lead, tv set cannot be turned on. It makes the clicking sound but doesnt stay on.
    Genius:
  • 1,694 Answers
!-800-553-7278 Mits parts line,however,could we go over the symptoms before you order an expensive part??? Then I will
be able to direct you.....T.
Posted on Oct 20, 2007
  • Vista Electronics Oct 22, 2007
    Define "stays on for a minute" .
    Also,when you say red bulb didn't come on,does that mean the blue and green one did??  If so , dis-able the red tube by unplugging HV lead to red CRT.And  pull red CRT socket
    module.Then turn set on and see if it runs without red color.
    Let me know by how you rate my solution..........T.
  • Vista Electronics Oct 23, 2007
    And pull red CRT module from end of red CRT!
    And dis-connect HV lead......
6ya staff
SOURCE:
TV has red lines and showing double the picture. One Sears tech suggested may have to replace bulb for $500???
yes thats a good price to replace a bad red picture tube and at the same time the convergence ic , this is for the doble picture and lines
Apr 12, 2010 | Mitsubishi WS-55511 55" Rear Projection...
Tip
Mitsubishi WS-55511 Manual Download
Download Mitsubishi WS-55511 HDTV Manual
Models: WS-B55 / WS-48511 / WS-55511 / WS-55711 / WS-65511
Models: WS-65611 / WS-65711 / WS-65712 / WS-73711
Have you misplaced your Mitsubishi WS-55511 HDTV Owners Manual?
Would you like a digital, searchable, pdf version of the Mitsubishi WS-55511 HDTV Users Guide?
Follow this link to download a pdf version of the operations manual.
I hope that helps.
____________________________________
Reset Mitsubishi HDTV VChip Password
Bypass Mitsubishi HDTV Front Panel Lock
on Apr 30, 2010 | Televison & Video
Tip
Bypass or Reset Mitsubishi HDTV V-Chip Password Lock
Would you like to bypass, defeat or reset your Mitsubishi HDTV Parental V-Chip parental lock? Have you forgotten your V-Chip passcode or password?
If you forget your V-Chip passcode, you can view the locked TV without entering your password.
When your passcode is requested, press the number 9 and the QV button on the original TV remote control at the same time. This process temporarily unlocks your TV.
When you enter the V-Chip Lock menu, pressing the number 9 and the QV button on the original TV remote control at the same time will delete your old password and prompt you to enter a new passcode. Pressing HOME at this time will cancel the entire passcode.
I hope that helps.
________________________________________
on Apr 30, 2010 | Mitsubishi WS-55511 55" Rear Projection...
COLOR GOES IN AND OUT
color going in and out, see if you have red/white/ yellow cables on the back of this tv. unplug and reconnect the yellow one. hopefully its just the cable wire or it may be bulb in the tv that is going out
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/laura_08254539050d64db
Mar 03, 2010 | Mitsubishi WS-55511 55" Rear Projection...
I have a Mitsubishi WS-55511. My red convergenge is off.
I am posting a photo of the resistors here: I will post the instructions in several parts(too long to post here in one time)
Resistors:
Dec 11, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Tip
Bypass Mitsubishi HDTV VChip Password
I hope that helps.
Tip
I hope that helps.
Mitsubishi WS-55511
Good Day;
Sounds like you have bad Convergence Output IC > 267P155010 > STK393-110, replace and it will correct the problem TV uses only ONE, make sure all resistors look good in the circuit around IC.
Good Luck, big IRISH.
Sep 19, 2008 | Mitsubishi WS-55511 55" Rear Projection...
Three color dots
check out self test first, look at threads here or ctechnicians.com
Dec 31, 2007 | Mitsubishi WS-55511 55" Rear Projection...
Mitsubishi WS-55511 55" Rear Projection Television Logo
292 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Ekse
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
