Question about Refrigerators
Electrolux will not stop making ice.
I have an Electrolux stand alone ice maker that will not stop making ice. I have defrosted and cleaned all the major components, but didn't notice a sensor that would signal when to stop making ice. This is a new problem that has been going on for the last month. The ice ben gets full and causes an ice water fall to form from the cube maker.
Posted by jonathan gass on
Paul G
    Scholar:
  • 161 Answers
Sounds like the ice level switch is either jammed on or is faulty.
Look for a flap of some kind that rests on the ice when it's made. Should be located at the back of the hopper.
Posted on Jan 11, 2014
5 Related Answers
Anonymous
  • 237 Answers
SOURCE: The water continues to drip after the ice cube maker is full.
Sounds like the water fill solenoid valve is leaking by. You will have to change that solenoid valve if the water continues to drip into the ice maker tray after a normal fill cycle. http://www.partselect.com/AdvancedModelSearch.aspx?ModelNum=JCD2295HES&mfgModelNum=JCD2295HES&fkMfgID=1
Posted on Dec 11, 2006
Anonymous
SOURCE: no water for ice maker
make sure wire is in down position this is like the on and wire up is off
Posted on Jul 14, 2007
Anonymous
SOURCE: Leaking icemaker
You may want to check that your water line isn't cracked.
Ours cracked and now we need to replace our floor. The water line is too close to the compressor which heats the plastic tubing and makes it brittle. Our refrigerator is 9 years old. Model #TPX24BRYFBB
Good luck
Posted on Dec 02, 2007
aborcass
Ron Coons
  • 2651 Answers
SOURCE: ice maker making hollow cubes
check your incoming water pressure, change the water filter recently? hollow ice cubes is a sign of low water pressure
Posted on Mar 06, 2008
George Fleming
  • 142 Answers
SOURCE: water dispenser on front of refrigerator door does not dispense water. Ice Cube maker continues to make ice cubes. Defrosting doesn't fix problem.
Water dispensing solenoid is bad. You need to replace the solenoid valve. This typically is independent of the ice maker.
Posted on Jun 02, 2009
How long once the ice maker starts making ice should we use it
What kind of ice maker is it? Is it a stand alone or is it inside your freezer? If inside your freezer it will take two days to fill the storage container. Stand alone types usually make 20 lbs of ice in 24 hrs or so.
Jul 17, 2014 | Kitchen Appliances - Others
Electrolux ice maker won't stop making ice
The bin full detector is not working--replace it.
May 21, 2014 | Electrolux 15 Under-Counter Ice Maker...
Electrolux american fridge freezer cooling problem
There is a defrost timer on the unit. It is supposed to come on and melt the ice that forms on the coils in the evaporator. IF you get a lot of ice built up or something is wrong with the timer, it wont melt the ice or it wont come back on to cool the unit.
Dec 09, 2013 | Electrolux Refrigerators
Jenn-air ice maker, stand alone unit, will not shut off, keeps producting ice.
There should be a sensor inside the ice maker bin that tells the ice maker when its full. It may be a wire or an arm on top of the ice. If you accidentally knocked that off the ice maker won't know when the bin is full and just keeps making ice
Jul 07, 2009 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
Stand alone ice maker makes hollow cubes. Any ideas?
Clean the condensing coil. Run ice machine cleaner through the evaporator coil on a wash cycle.
Jul 07, 2009 | U-Line SS95 Stainless Steel
Electrolux icon stopped making ice
You may have gotten rust or debris in the line when you turned it back on, Check water connection and clean out the screen. Air should work out of the line quickly, but can cause some delay in ice making.
I’m happy to help further over the phone at https://www.6ya.com/expert/josh_87ce33216d7b2148
Mar 29, 2009 | Electrolux ICON Designer E30WD75SS...
Kitchenaid stand alone ice does not make ice feel heat inside bin
Either has electric problem or mechanical.
way to tell is plug it up, turn it on turn on water. If its sending in water unplug it and if water stops it is electrical and the ice maker head is causing the problem if it stops the water valve is stuck open and you can disassemble and clean it out sometimes. A slight lime scale can cause this.
Hope this helps please rate me accordingly and good luck.
Mar 12, 2009 | KitchenAid KUIS18NNT 18" Automatic Ice...
Stand Alone ice maker leak
Your model number must be plumbed to a external drain.
You may have to install a condensation pump to do this.
Mar 10, 2009 | KitchenAid KUIS18NNT 18" Automatic Ice...
Bosch stand alone freezer Intelligent 32 - how to defrost
Hi
I have the same refrigerator and found the manual;
"The refrigerator compartment was programmed to defrost automatically meaning you do not have to constantly clean and dry it. Copy from the manual"
Also have a look in the back for the drain outlet - very small. If that is clogged up it also cause water on the inside.
Feb 28, 2009 | Bosch KSR34464 Refrigerator
CLR2060 Clear Ice Maker Won't Freeze
Water is not supposed to run all the time. Maybe you have a problem with your solenoid or the circuit that shuts your water. Sometimes solenoid just needs cleaning.
Aug 08, 2008 | U-Line Icemaker
Refrigerators Logo
122 people viewed this question
Top Refrigerators Experts
Marvin
Marvin
john h
