Question about Canon PIXMA MP830 All-In-One InkJet Printer
MP 892 MP navigator cannot communicate with the printer or scanner
The printer prints with no problem, either wi-fi or USB connection but when I try to scan MP Navigator says it can't communicate with the scanner. I've deleted the old software and downloaded and installed the latest software/drivers from Canon but still no scanning. Error code lists as follows: Code5,156,61. Help!
Posted by herrinb on
4 Related Answers
Anonymous
  • 6 Answers
SOURCE: I can't scan anything from my MP 460
had probs with scanning at first
1.put doc in scanner
2.push scan
3.choose color or black
4.press scan again
thats what i did works ok
Posted on Dec 12, 2007
Anonymous
SOURCE: MP450 has stopped scanning
canon pxima mp450 code errior 5100
Posted on Oct 08, 2008
pineworks
Clive
  • 4345 Answers
SOURCE: Canon MX310 scanner driver not found
Hi there
You can download a driver from my website then you can use the driver to set your printer up.
Just click on this link and it will download for you, and it is best to save it on your desktop so you can find it.
This is for the MX310 it for XP and Vista.
Click Link = http://www.4all2sell.com/driver/Canon-PIXMA-MX310-All-in-One-XP-Vista.exe
Ones you have downloaded just double click on it to run it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks All files on my website are only there for a limited time.
Posted on Mar 24, 2010
Anonymous
SOURCE: Canon MP 640 not recognized by MP Navigator EX 3.0
Your anti virus software is blocking the Canon software. Restore AV default settings.
Posted on Jan 16, 2011
Will not scan to my computer
What OS are you using? Did you install the full software (MP Navigator), not just the drivers? If you have the MP Navigator installed, how are you connecting to the computer? If you are using a USB cable, try a new cable, a different USB port and a direct connection if you are using a USB hub. (If you are using a USB print server, go to a direct connection to the computer.) If you are using the all-in-one over your network, try disabling your firewall temporarily. You may need to add a rule to the firewall to allow the scanner communication. (This will depend on the software/hardware firewall involved. Please add a comment with the details for support on adding rules.) The scanner requires bi-directional communication with the computer. This can fail even though the printer works. Make sure that the monitor program is running; this listens for button presses on the all-in-one.
Next open MP Navigator and try to start a scan from your computer. If you can't scan, then you should check for a communication issue, as described above. If the scan works from the software, then you probably don't have the destination buttons assigned in the software. Use the details from your initial scan to set the defaults. Go to Preferences and then the General tab. Adjust the details for the Scanner Button Settings. Click OK to save.
I hope this helps. Please let me know if you continue to have a problem.
(one common issue for a USB connection is installing the OS default drivers by connecting the USB cable before installing the Canon software. If that is your issue, please uninstall the printer. Then with the USB cable disconnected, install the Canon software. Connect the USB cable when prompted to do so. The OS software usually only has a printer driver and thus will not allow the scanner to work.)
Feb 06, 2014 | Canon MX882 All-In-One InkJet Printer
My Lexmark Platinum PRO905 does ot print it gives me the message " Communication Not Available, The Printer cannot communicate with the computer"
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer (if usb-connected), reboot your computer and unplug/replug your printer into the power source to reset it. When the printer turns on, reconnect the printer into the computer. Try to print again.
You may also refer to this article (for Wi-Fi connection issues): How to identify a Wireless Communication Problem and Resolution Tips
Aug 09, 2011 | Lexmark Platinum Pro905 multifunction...
I can no get my printer to scan to my computer
Do you have the full software (MP Navigator) installed? Get that software here: http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mp_series/pixma_mp510#DriversAndSoftware and select your OS. Since the printer is a USB printer, is it directly connected and did you install the software before connecting the USB cable? If you didn't install the software before you connected the USB cable, uninstall the generic driver from the OS and remove the USB cable. Then install the software.
If the full software was installed before connecting the printer, try a new cable and a direct connection (instead of a print server or USB hub). Scanners require bi-directional communication with the computer and can fail when the printer works. Make sure the monitoring program is running before attempting to scan from the all-in-one.
Next try to scan from the computer first. There are buttons in the MP Navigator software that set the destination and default settings of the buttons on the all-in-one. After you scan at least one item, you will have a better idea of the settings that you need to use. See the MP Navigator help files for the details.
If you install the basic Canon driver, you will be able to scan but not from the unit directly. Windows XP and newer all come with Paint that can acquire scans (File > Import from Camera or Scanner > New Scan). Windows Vista and Windows 7 have Windows Fax and Scan that can also scan files (New Scan). Photo Gallery in Windows Live (comes with Vista) also handles scanning.
The generic OS driver usually only runs the printer.
I hope this helps.
Dec 10, 2010 | Canon PIXMA MP510 All-In-One InkJet...
My dell inspiron 531 is not wi fi compatible how do I hook up my lexmark x4550 printer/scanner/copier to it
bring usb wi-fi from market it will turn your computer to wi-fi capable, other wise you need usb cable to connect printer with you laptop and drivers as well..
Nov 01, 2010 | Lexmark Office Equipment & Supplies
Jan 31, 2010 | Canon Office Equipment & Supplies
Canon pixma mp 190 won't scan / copy and printing works!
I also have a newly purchased MP 190 that prints but will not scan at all have also tried reinstalling software.
anyone help me?? :(
Jun 06, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Canon Pixma Cannot communicate with scanner
Hello do You have a program CD Record, then pu it in Your computer and then trhy to download a scaners software.
Mar 12, 2017 | Canon Pixma MP500 All-In-One InkJet...
2.push scan
4.press scan again
Nov 15, 2007 | Canon PIXMA MP460 All-In-One InkJet...
Canon pixma mp830 will not scan
I am experiencing the same problem, from the equipment id does not scan
Oct 31, 2007 | Canon PIXMA MP830 All-In-One InkJet...
Canon PIXMA MP830 All-In-One InkJet Printer Logo
52 people viewed this question
old marine
old marine
Muntejaya Ginting
Muntejaya Ginting
Tareq Bin Mostaq...
Tareq Bin Mostaq...
