Display is dead even light inside oven does not go on?
SOURCE: Problems with Jenn-Air Electric Double-Wall Oven
Try changing the clock assembly --
http://www.partselect.com/ModelFrames.aspx?ModelID=221346&ModelNum=WW30430P&mfgModelNum=&ManufactureID=1&Selected=51238&Position=1&mfg=Maytag&Type=&Mark=1
here is a link to the diagram.
PS120923
Electronic Clock Assembly (Series 10)
Help with series numbers
here is the part number.
SOURCE: panel light is out
There is a capacitor on the clock board labelled C3. It will probably have brown burns on it or "syrup" leaking around the base. You can buy a box of 10 of these for 75 cents at Radio Shack (make sure you match the label on the old capacitor, I think it's 58mf and 35V but I could be wrong) and a pencil soldering iron for $10. It's held on with 2 little wires. Before taking it off note capacitor orientation (where the blue +++ stripe is), the replacement has to go on the same way. Common problem and easy fix.
SOURCE: Oven digital lighted display is dim
I replaced the C3 capacitor on the circuit board and works fine. This was mentioned in a prior post and took 5 minutes and was under $5.00 for the part.
SOURCE: Display on my Jenn-Air electric wall oven is very dim
douglas9101,
I had the same problem and found the solution on-line.
Replace the C3 capacitor on the dispaly module. (100 UF, 35 volt, high temperature)
The local Jenn Air dealer wanted $211 for a new display module.
I purchased a Cap from a local electronics supply store for 79cents.
The only problem is that you need to have a soldering pencil/iron, a solder ******/wick and a small amount of solder.
Steps I had to take on my oven:
- Flip the AC breaker supplying the oven to off to be save
- remove 3 screws on top and 4 on the bottom of the display panel
- gently pull out the display panel and unplug the 2 cables to the display
- unclip the ribbon cable to the display module
- unclip the module itself by pushing on the 2 black tabs
- locate C3
- unsolder C3 and replace with new Cap- keeping the polarity strip the same as theh old Cap
- reasemble in reverse order.
It took me all of 20 minutes. It may sound difficult but is very easy if you have the tools
Good Luck
K
You need to replace the C3 capacitor on the control board
http://fixitnow.com/wp/2009/01/28/cheap-fix-for-a-dim-display-on-an-oven-control-panel/
You can replace only the C3 - it is 68uF / 35V and you can go to Radio Shack and get their part # 272-1028 - 100uF/35V one. It takes all but 10 minutes to re-solder the new one in place
