Coby Kyros Tablet Logo
A
Anonymous Posted on Jan 07, 2014
How to reset my coby 1108 - Coby Kyros Tablet
Cant remember my password
A really annoying issue but your password is Your and only you are supposed to know it.
So I guess your only choice is to do a Factory Reset of your Coby tablet:
Hope this Youtube tutorial might help you:
Factory reset on Kyros MID 7012 without using Settings
Also you should read these tutorial:
Coby Kyros MID7010 hard reset
http://webcache.googleusercontent.com/search?q=cache:eQiuI75ELTMJ:resetandroid.com/coby-kyros/+&cd=6&hl=es&ct=clnk
http://www.androidtablets.net/threads/how-to-factory-reset-on-coby-kyros.24344
You can get some more information doing a google search for
factory reset of Coby kyros Tablet
1helpful
How do i factory reset a coby kyros mid8024?
There are two methods of reset Coby Kyros MID8024:
1. Soft Reset
2. Hard Reset
Steps for Soft Reset:
  • Take out the battery.
  • Reinsert the battery.
  • Press and hold the power button for 10 seconds.
That's soft reset. If your device doesn't load after this, try hard reset.
Steps for Hard Reset:
  • Switch off the device.
  • Press and hold Volume Up + Home Button + Power Key.
  • After 2-3 seconds, release the Power Key.
  • You will enter boot screen, Select Wipe Data / Factory Reset.
  • Select Yes.
This will delete all the files including apps, personal data stored in phone memory. Don't worry it doesn't wipe off the SD Card so you should make a backup of your files stored in phone memory.
2answers
How to reinstall os on coby 7" tablet?
Usually on an android device access settings : sd card and storage : select erase all or restore or factory reset and device will be factory restored . If the OS is completely gone you may have to access an image from te Coby website and install from a laptop by cable .
Coby mid8065
1. Turnn completly off the tablet.
2. With the tablet turned off, holding the return button while turning on the tablet-pressing power button. Keep holding the return button until you see the Hard Factory reset screen.
3. Confirm the hard reset procedure. Once done, simply wait until process has finished-the tablet will restart. This process can take up to 30 minutes, so it's very important that the battery of the tablet is completly charged before attempting the hard reset. If you can connect it to the charger while resetting, even better.
Regards! If that helped, don't forget to accept my answer!
2answers
Factory reset for coby MID7030
Hi Hisham,
I have this site for you on how to reset your device. It includes image as well. Hope it helps.
Hard Reset Procedure For Coby Kyros mid 7030 4
How do I factory reset my Coby Kyros 1125?
  1. Hold down the Power button for a short while to turn on the device.
  2. Go the Menu and find and select Settings.
  3. Choose Backup & Reset
  4. Select Factory data reset
  5. Select Reset device
  6. Select Erase everything
3helpful
Top Coby Tablets & eReaders Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Kolbrun...
Are you a Coby Tablet and eReader Expert? Answer questions, earn points and help others
