Step 1 : Identify the DVR. • Launch the Alien-DVR-Reset-Tool.exe from the USB stick. The USB stick must be present initially but may be removed once. ...
Step 2 : Obtain a Reset Code. Ring System Q on 01246 200 000 and quote the. • DVR's serial number. ...
Mar. 2, 2021 - Sannce Home - How to reset the password of DVR? · 1. Plug DVR to the router by ethernet cable. · 2. Get a windows computer that is connected to ...
Power off the DVR: Make sure the DVR is powered off by disconnecting it from the power source.
Locate the reset button: On the back or bottom of the DVR, you should find a small reset button. It is often recessed and may require a pointed object like a paperclip or pin to press.
Press and hold the reset button: Using a suitable tool, press and hold the reset button for about 15 to 30 seconds. This will reset the DVR to its default settings, including the password.
Power on the DVR: After releasing the reset button, reconnect the DVR to the power source and power it on. The DVR will go through a startup process.
Access the DVR: Once the DVR has finished booting up, you should be able to access it using the default login credentials.
Username: The default username is usually "admin" or "admin1234". If these do not work, consult the DVR's user manual or documentation for the correct default username.
Password: The default password is typically either blank (no password) or set to "4321". If none of these options work, refer to the DVR's documentation or contact Samsung's technical support for assistance.
For nearly all Samsung Security DVRs, the default password is 4321. If it hasn't been changed since setup, then you can just use that to access the DVR. The default password is included in the reset procedures for completeness. If you have changed your password or access code for your Samsung Security DVR since it was setup, or if you changed it during the initial setup, use that password in place of the default password. The password will be the latest password that was set on the DVR. If no password has ever been set, then it will be the default.
Steps to Reset your Samsung Security DVR
Samsung Security DVR Reset Procedure #1
Reset the unit to factory by pressing both [MODE] and [PTZ] button for 5 seconds
Then enter the 4321.
Samsung Security DVR Reset Procedure #2
Reset the unit to factory by pressing both [MODE] and [CH2] button for 5 seconds
Samsung Security DVR Reset Procedure #3
This reset will work on Android based DVRs only. All steps are performed on the device itself.
Turn the device Off
Wait 2 minutes
Press and hold the following buttons
POWER,
HOME
VOLUME UP
The unit should power on. Once it does, you can release power.
Use the volume UP and Down buttons to select "Wipe/Factory Reset" from the recovery menu.
Activate the reset using the HOME button.
When the DVR goes through it's setup again, it will be at factory defaults. The password will be 4321.
Samsung Security DVR Reset Procedure #4
This reset will work on SDR models. It may also work on other models.
With just the cameras showing, press the following in quick succession using the remote:
Freeze
Alarm
Freeze
Alarm
Freeze
Menu
Enter
Make sure you press them quickly, one after the other. If it doesn't work the first time, try doing it several times. It can take many tries to get the timing right. If/when it works, you should get a screen that gives you the option to reset.
Samsung Security DVR Reset Procedure #5
This reset will work on SDR models where procedure #4 failed. It may also work on other models.
Press the DVR Button to place the system in DVR Mode
Press:
Freeze
View
Return
As with Procedure #4, you may need to press Freeze, View, and Return in in quick succession a few times to get it to work. The timing can be tricky.
Samsung Security Reset Procedure #6
Courtesy Sergio Ayala
To factory reset the SDR-B74301
Reboot the DVR
Once the DVR has rebooted, enter the following sequence on the remote:
UP, RIGHT, 5, 3, 3
You will be prompted to do a factory reset. Confirm
This has been confirmed by several people. Thank you, Sergio! If this works for you, please thank him in the comments below. CCTV Networking Technical Support
If you stuck in CCTV DVR Password Reset process. just visit
CCTV & Networking Technical Support Channel on youtube.
Here is the link:- CCTV Networking Technical Support
