Lionel Cw 80 Transformer Logo
Question about Lionel Cw 80 Transformer
Lionel tct lockon
How hock up a lionel tct to the transformer?
Posted by Laura Loder on
non sequiter
    New Friend:
  • 161 Answers
1 Related Answer
Anonymous
SOURCE: Lionel train power issue
Answer a number of questions:
Is the tranformer power adequate for the train and is it a working tranformer?
Will the train run by connecting the wires directly to the two points of the train (wheels and center rail connector)?
Are the tracks new?
Is the lockon new?
Posted on Jan 07, 2009
How to remove the red handle and how to get to the fuses
You can't. These transformers aren't user serviceable. You can thank the Federal Government for that. If you can find the special tool to remove the case, you'll be able to open the transformer. For service, contact Lionel customer service or take the transformer to a Lionel Service Center.
Can two tracks be powered with the Lionel Trainmaster R 100 Watt transformer?
Track 1 as you have it connected is terminals B-F. The second track would be terminals B-C. Connect post B to the outer rails Terminal 1 ? on your lockon. THis will give you 6-16 volts at the track.
Dec 01, 2013 • Toys
1helpful
Need wiring diagram for Lionel 313 Bascule Bridge
There are 5 terminals on the bridge number them from outside to inside 1,2,3,4,5
Terminal 1 gets connected to the outside rails on a V,Z,VW,orZW transformer terminal U. The control button a #96 push button gets connected between terminals 2 and 3. Terminal 3 also gets a wire from A or B on a V or Z or Bor C on a VW/ZW. Terminal 4 gets connected to the transformer terminal D. Terminal 5 gets a wire to the lockon on the black bridge frame. The bridge needs 3 sections of track on each end seperated from the rest of the track as a stopping section remove the center rail pin on this section, This forms the stopping sections at each end of the bridge.
Oct 14, 2013 • Toys
1helpful
3answers
What guage wire should I use to connect a train transformer to the O gauge lockons on the train track? thank, E.S
I have used 18ga lamp wire but you can use wire as thin as telephone wire. My rule of thumb is to use thicker wire (lower gauge number) the more motors on the train you are running. 20 or 22ga is generally used by most.
My lionel rw transformer won't run the train unless ithe speed control is turned 3/4 way up or better . Can this be fixed ?
Yes. Find a Lionel repair shop or bring it to a local hobby store that does model train repairs. You can contact Lionel for a list of repair shops.
1helpful
Ι've just joined 2 ovals 40x60 lionel fastrack, used some other items 2 Lionel 6-12018 FasTrack O-36 MANUAL SWITCH RH, 2 Lionel 6-12017 FasTrack O-36 Manual Switch LH, A few 6-12014...
It sounds as though you may have two defective transformers. Lionel has reported problems with some of their smaller transformers. I would have the transformers and the engines checked by a Lionel service station or contact their customer service department for help.
CW 80 -Direction button doesn't work
Recent Lionel transformers are notorious for their issues. Put an old fashioned reverse switch into the circuit, an old Lionel 88 will do the wire to terminal 1 of the lockon or the wire tothe center rail needs to be cut and attached to the 2 terminals of the 88 reverse switch. Note this is ancient technology from the 30s to 50s
Connect the lionel ctc lockon to the track
The lockon is for tubular O or O-27 track. Slide the large part of the clip over the bottom flange of one outer rail....straight track works best and snap the cmaller clip onto the center rail. the two small terminals are your wire connections.
Nov 23, 2009 • Toys
2helpful
2answers
Are the tracks new?
Is the lockon new?
Top Lionel Crafts & Hobbies Experts
ADMIN Andrew
ADMIN Andrew
Tom Chichester
Carolyn Rogers
Are you a Lionel Craft and Hobby Expert? Answer questions, earn points and help others
