Question about Casio Edifice EFA110D-1AV Wrist Watch
Need new adjustable band are extra links for casio edifice 2719 ef-106
Bad to short
6ya staff
SOURCE:
indays
johnny medrano
  • 111 Answers
SOURCE: Shorten strap of Casio Edifice EF-518 watch
good morning ! thats verry easy to make shorter !just look the possition of arow and push the pin to out use the pointed tool and anvil to releas the pin ! thank you !god bless !....
Posted on Sep 02, 2008
Anonymous
  • 58 Answers
SOURCE: adjust the band links for Casio MTP4500D-1AV ( model #4755 )
You can tap out the pins in the band with a small punch. a ground off needle may do it
Posted on Jun 22, 2009
Anonymous
  • 12 Answers
SOURCE: Adjust-a-Casio-S-1087DY-Watch-Band
On most brands, there are pins that form hinges for the links of strap. You need to push them out to remove links. Usually you would find arrows marked from inside of the metal bracelet which show you the direction in which to remove the pins. You can remove it if you have a small watch maker's screwdriver but you have to be careful. or get one of these ..
http://www.amazon.co.uk/Watch-bracelet-link-adjuster-remover/dp/B001ZKIL2S/ref=sr_1_1?ie=UTF8&s=watch&qid=1254695541&sr=8-1
which should help you to remove the link pins safely without scratching.
Posted on Oct 04, 2009
escapement
Arturs Kalnins
  • 2338 Answers
SOURCE: need to adjust length of watch band: Casio WV-57H
Check out my TIPS here and you will find out how to do that
Posted on Feb 05, 2010
Roipatrick
  • 906 Answers
SOURCE: english manual for
good day,
hope this link below will solve your problem.
watches
Posted on Jul 30, 2010
Owner's manual
Refer to link below using the module nbr (4 digit code in a frame).
Timepieces Watches Manuals CASIO
Nov 21, 2013 | Casio EF-561D-7AV EF561D Edifice...
How do I adjust casio module no. 3050 watch band-steel
Your casio MTP3050D 2AV had a module number of 2719.
If your looking for module 3050 here is the link.
If your looking for module 2719 here is the link.
I hope this will be able to help you.
Thank you for choosing Fixya
Mar 17, 2011 | Casio MTP3050D Watch
Change time in cassio edifice
Here is the link that includes step by step procedure including visuals.
http://ftp.casio.co.jp/pub/world_manual/wat/en/qw2711.pdf
I hope this will help you a lot
Thank you for choosing fixya.
Mar 02, 2011 | Casio EF-500D-2A Edifice Chronograph watch...
How do I adjust the length of the bracelet (watch band) for a Casio EF106D-2AV bracelet watch?
  • Select a clean, flat work surface where you can perform your watch band adjustment. Put down a piece of felt to protect the face of your Casio. Turn on a lamp near your workspace to better illuminate the watch components with which you will be working.
  • Lay your Casio face down on the protective felt. Look for the small arrows on the back of some of the watch links; these arrows indicate the removable watch links and the direction their pins should be removed.
  • Locate the pin hole above the arrow on the removable watch links. Insert the tip of a watch pin removal tool, or push pin, into the pin hole. Apply pressure to the link pin, in the direction indicated by the arrow, to free the pin and remove the link. A pair of needle-nose watch or jewelry pliers can be used to help pull out stubborn link pins. Remove as many links as necessary for your watch to fit perfectly.
  • Reserve the links and link pins that you remove from your Casio Edifice watch. Store the removed watch components in a small, clear, plastic zipper bag. These components can be used when repairing or expanding your Casio watch band.
  • WARNING:Casio recommends that customers have their watch bands sized by an authorized Casio watch dealer. Sizing the band of your Casio Edifice yourself may void the manufacturer's warranty on your watch. Contact Casio customer support for more warranty information.
  • Aug 21, 2010 | Casio Edifice EF106D2AV Wrist Watch
    I am trying to figure out how to shorten the wrist band on my Casio Edifice EFA-119.
    mcdevito75 here, If your Casio has a metal band, you can remove 1--2 links, this takes a special tool called a link remover, best bet is to look for a small watch repair shop in your area. If your Casio has a strap, the buckle may be able to move up the strap to fit your wrist, if so, move the buckle up the strap to fit your wrist and cut offf the exccess strap. If not, you"ll have to replace the entire strap. Hope this helps.
    Aug 03, 2010 | Casio Edifice EFA109-7AV Wrist Watch
    Aug 31, 2009 | Casio Edifice EFA110D-1AV Wrist Watch
    Sep 01, 2008 | Casio Edifice EFA109-7AV Wrist Watch
    Casio Edifice EFA110D-1AV Wrist Watch Logo
    59 people viewed this question
    Top Casio Watches Experts
    Janelle Schoonover
    Janelle Schoonover
    Ekse
    k24674
    Are you a Casio Watch Expert? Answer questions, earn points and help others
