Question about Mitsubishi WS-55511 55" Rear Projection Television
Mitsubischi WS-A55 no turn On.
When I plug turn on the green light for two seconds and after blink three times. I was press the input + menu buttons simultaneous and nothing response. No more lights, no signal, nothing... someone can help me... Thanks.
Posted by Jose Lino Davila on
5 Related Answers
Anonymous
  • 1142 Answers
SOURCE: Mitsubishi WS-55857 won't turn on
Thank you for posting your concern details however i would be needing few more details from your side if necessary and allow me few mins to come up with the resolution.
Posted on May 19, 2008
Anonymous
  • 3130 Answers
SOURCE: TV Won't Stay On...
fuse do not blow for no reason, th reason thy are blowing is he convrgence iC"s are going bad.
Posted on Aug 16, 2008
MICHAEL MULLINS
  • 927 Answers
SOURCE: tv mitsubishi ws-65315 doesnt turn on,only green light
Good Day, cutito35; 1. This model is equipped with a keyboard lock feature; this can be mistaken as a no power condition. To unlock the keyboard press and hold the "menu" button on the front panel for 10 seconds. 2. (Power LED may be on after plug in) check for no less than 4.4 volts DC at pin 3 of PC9A21 on the Power PCB, if low or missing replace PC9A21 part # 268P058020. 2.This model is also equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. Shutdown at power with self diagnosis error 2-2. Check for open fuses F9A04 and F9A05 part # 283P144080 on the +24 and -24 volt lines. If the fuses are open the convergence output circuit would be suspect. 2. Shutdown at power with self diagnosis error 2-1. At power on check for 12-volts DC at connector KH pin 8, if missing check IC9C51 part # 270P990010 and L9C52 part # 441D009020 on the Signal PCB. Good Luck, big IRISH.
Posted on Sep 01, 2008
Slinteriors
Sonny Berry
  • 8617 Answers
SOURCE: Model WS-55909 Green light flashes won't go out. No TV
You need the WS55909 - WS73909 DM kit. You can get it at the following link which contains the capacitors and the CD with instructions on how to do the repair.
http://www.tvrepairworld.com/
Posted on Jul 18, 2009
Anonymous
  • 11 Answers
SOURCE: mitsubishi WS-55909 dm board repair
I have the same TV and the error light code on my set is 22
Posted on Dec 13, 2009
Mitsub
The model listed has a self check: when you turn it on and green power light comes on and goes out in a few seconds, on the front of the set press and hold both the Menu and Input(input may be labeled Source) at the same time and hold for at least 5 seconds.
Release both buttons and the power light will blink a two digit error code like 2 blinks, 2 blinks, a pause and repeat for a total of 5 times.
If you have unplugged the set you will have to plug it back and turn set on, let it fail and then do the check--removing power clears all errors.
Let me know what code you find.
Dec 16, 2012 | Mitsubishi WS-55859 55" Rear Projection...
When I push the on button the green light comes on for second or two then goes out.(will not stay turned on long enough to even get a picture on the screen.Mitsibishi Model # WS-55315
This set has a self check feature--if set has been unplugged it clears the error buffer--plug in and try to turn on set.
When green light comes on and then goes off ON THE FRONT OF THE SET press and hold BOTH the menu and input(device) buttons at same time for at least 5 seconds and release both buttons.
Power light will blink a 2 digit error code like 2 blinks, 2 blinks, a pause and repeat the code for a total of five times.
Let me know what error code you find and I will explain it.
May 27, 2012 | Mitsubishi Televison & Video
Mitsubishi big screen HD 1080 series model WS-55809. it switched off one day. and when i turn it back on it switches right back off. red light in front. what part do i need to fix it/
That model does not have a red light---Green.
If set powers up for a few seconds (green power light) and goes out do the self check the model indicated has:
On front of set (not with remote) press and hold both the input and menu buttons for at least 5 seconds and release both.
Green power light will blink a two digit error code like 2 blinks, 2 blinks a pause and repeat it several times.
Let me know what error code you find (if you have unplugged the set that will clear all errors and you have to plug it in and try to turn set on again---when it fails do the self check)
Mar 31, 2012 | Mitsubishi WS-55809 55" Rear Projection...
Tv automatically powers off by itself within seconds.
This model has a self check: with the set plugged in turn it on--green power light comes on and a few seconds later goes off.
On front of set press and hold BOTH the menu and input buttons at the same time for at least 5 seconds and release both buttons.
Power light will blink a 2 digit error code like 2 blinks, 2 blinks, a pause and repeat it several times.
Let me know what error code you find and I will tell you what it means.
SD TECH
Apr 11, 2011 | Mitsubishi WS-65809 65" Rear Projection...
Have a ws 73-711 that does not turn on. If you unplug it then plug it back in you get a rapped green flashing light for a few seconds then nothing. any help would be great
Have you tried accessing the led self diagnosis by pressing the menu button and Input button both in together and hold for 6 seconds on the front panel of the set. It should then blink a two digit blink sequence from the power indicator. which will repeat several times let me know the blink sequence and I will assist you.
Feb 18, 2011 | Mitsubishi WS-73711 73" Rear Projection...
Our WS-55313 Mitsubishi Projection screen tv was on then just died. When we push power button or remote on, the green power light comes on for a couple of seconds then the tv goes off .
do the self check this model has.
When green light goes off press and hold both the input and menu buttons for five seconds and release both buttons.
The power light will blink a two digit error code like, two blinks, two blinks, a pause and then repeat it several times.
let me know what the error code you find is and I will let you know what it means.
SD TECH
Dec 26, 2010 | Mitsubishi WS-55513 55" Rear Projection...
Turns off immediately after turned on
Do the self check it should have: when shuts down and green light goes out: On the front of the set press and hold both input and menu buttons at the same time for at least 5 seconds and then release both.
Power light on set should blink a two digit error code: like 2 blink,2 blink, pause and repeat it at least 5 times total.
Let me know what error code and I will tell you what it means.
If this has helped you, rate this solution as I do this here for free.
SD TECH
Aug 15, 2010 | Mitsubishi WS-55809 55" Rear Projection...
Green lite turns on for 2 second and then turns
Please listen and try this:
When the power light comes on and goes off, on the front of the set press BOTH the Menu and Input (Device) buttons at the SAME time and HOLD them both for at least five seconds and then release both.
The power light will blink a two digit error code and will repeat it about 5 times. To get it to repeat you would have to unplug the set and turn it on again etc.
The most common error is 2 blinks, pause, 2 blinks.
Let me know what error code you find and I will direct you as to what it means and what may have to be done.
SD TECH
May 13, 2010 | Mitsubishi WS-55311 55" Rear Projection...
Mitsubishi WS-55909 dm board repair
The DM is fine if the led isnt blinking. Your set is going into protective shutdown. Try pressing the menu and the device/input buttons on the set both in together for 5 seconds to see if the set will blink a series of blinks pause then blink another series of blinks. Such as 2 blinks pause then 2 blinks, Then let me know what the blinks were and I will assist you with whats wrong
May 28, 2009 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi WS-55511 55" Rear Projection Television Logo
155 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Todd Hill
Todd Hill
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
