Question about Riccar Vacuums
Get red light off after changing filter - Riccar Vacuums
Thatvacguy.com
  • Riccar Master
  • 1,604 Answers
Depends on which model you have. If it's a red light it might be your full bag indicator. If it's glowing red you might have a clog somewhere .
Posted on Aug 11, 2014
HOOVER Freespace TFG 5123 - Red Light?
Check the entire flow path from intake to bag. You may find it is clogged.
Dec 12, 2013 | Vacuums
What is the blinking red light on the top of the vacuum
red light blinks when filter needs to b change hope this help thanks for reading
Jan 06, 2012 | Euro-Pro NV31 Infinity Vacuum
Flashing lights.
The Flashing lights indicate several different things. 1 flashing red light means its time to charge your unit. if it is still flashing after charging then you will more than likely need to change the battery. A flashing red and green light means that the unit is overheating which could happen if the filters need to be washed, or that there is a blockage or if your machine has been left in direct sunlight. Allow 1 hour for machine to cool down. 3 flashing lights indicated that the pre-filter has been put on incorrectly. I hope this helps. If you do decide to wash your filter dont use any type of soap it is not needed and allow fiter to dry for atleast 24 hours. putting a wet or damp filter in will damage your machine.
Sep 18, 2011 | Dyson DC16 Root 6 Bagless Handheld...
The red light by the on and off switch turned on . what does that mean
usually it indicates a low suction issue. Wether the hose is clogged, or either one or all 4 filters need to be changed. Usually the cone and the circular filter above the plastic cone should be replaced.
Good luck,
Mark
Nov 07, 2010 | Filter Queen Majestic Canister Vacuum
Red light is on my filter queen
The red light on the filter Queen is on to tell you to empty the canister and change the filter. It is a heat sensor that makes it come on and if it is full it gets hot. Also when you take the motor piece off of the bucket under the nylon cone shaped guard that protects the motor there is a secondary filter in there that needs to be changed from time to time and they are supplied with the cones inside the package of rep[lacement cones there should be a spare or maybe two. It is a round thin filter about 3.5 inches across and it just fits in very easily and there is a plastic ring that holds it in place. So pop out the ring and remove the old one and then replace it with the new one put the ring in to hold it...it just snaps into place.replace the nylon guard and put in a new filter cone. Put the machine back together and away you go the light should turn off and you are good to go. Thanks for your time and please try to remember to click on the yes box if this was any help to you at all.
Oct 10, 2010 | Filter Queen Majestic Canister Vacuum
The filter gives red light.Does this mean the filter must be washed or changed. How should it be washed, what does ´´washable´´ mean here?
Red light normally denoted filter is blocked. If it is a washable filter then wash it. If it liiks like a paper type filter, replace it. Washing it will make it clog up even more.
May 28, 2010 | Electrolux Oxygen Z5540 Pet Lover Vacuum
The red light on my hayden 3600 vacuum won't go off
I have a 6000 and it does the same thing. I simply unplug the unit and plug it back in after cleaning the filter and dumping the cannister. That seems to reset the warning system.
Jul 06, 2009 | Hayden Industries SuperVac 6000 Central...
Red light for HIPPA filter won't go off
Red light is sign of reduced suction due to a blokage of some sort. If you are sure the filter is thoroughly cleaned, check the hose, wand, and the nozzle connector for obstructions of any kind.
Oct 25, 2008 | Hoover S3755 WindTunnel Bagless Canister...
SEBO air belt K
You probably have a clog either in the hose, wand or the inlet down by the brush roll. Unhook the hose from the want and see if you have suction there and if the light stays off. Disconnect the wnd and look down thru it to make sure it is clear. If there is no obstruction, then the circuit board has a problem. But I would suspect a clog.
Feb 10, 2008 | Sebo Air Belt C2.1 Bagged Canister Vacuum
Vacuums Logo
181 people viewed this question
Top Riccar Vacuums Experts
brian kossman
Level 1 Expert
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Riccar Vacuum Expert? Answer questions, earn points and help others
